Old 03-06-2011, 01:34 PM   #1
JC0311SS
JC0311SS's Avatar
Drives: 2011 Camaro 2SS
Doing my fluids change today, question?
Okay I know this has been asked many times here but I just wanted to verify since I am changing my oil, tranny oil and diff oil today. I have a LS3 w/ M6 tranny.I got a little bit over 2k on the odometer. I got 8 qts Mobil 1 synthetic for the engine, 1qt Royal Purple 75w90 for the rear end and my question is which tranny fluid do I get, I was going to get Mobile 1 ATF and I just wanted to verify if this was it?:
Is there anything else I need? Thanks in advance for your help.
2014 Camaro 2SS/1LE. Black on black w/ NPP exhaust.
JC0311SS is offline   Reply With Quote
Old 03-06-2011, 03:06 PM   #2
Eric Baker
Drives: Black/Black 2SS/RS 6M
After a quick search, I stumbled upon an answer from Mobil directly on the subject, linked HERE. They say to use Mobil Dexron VI ATF as it's specifically formulated for late model GM transmissions. I myself used Royal Purple Syncromax as was recommended on here from many people.
Eric Baker is offline   Reply With Quote
Old 03-06-2011, 09:50 PM   #3
rb
rb's Avatar
Drives: silver '11 2SS LS3
Good catch Eric Baker. There does seem to be some confusion about using the Mobil1 synthetic ATF in manuals. I just read on another thread that someone used the Mobil1 ATF for their manual transmission and it made their transmission shift worse. They ended up going back to the GM stock fluid. Now we may know why. Thanks for sharing this!
rb is offline   Reply With Quote
Old 03-07-2011, 06:59 PM   #4
Ucantctchme
Ucantctchme's Avatar
Drives: 2010 ss. 1990 RS the faster one.
Royal purple rear diff fluid has been known to cause moaning in the rear. The gm fluid is synthetic and has the proper additives. IMO royal purple lubricants areaverage at best.
Ucantctchme is offline   Reply With Quote
Old 03-07-2011, 09:05 PM   #5
JC0311SS
JC0311SS's Avatar
Thanks for the responses but which transmission fluid should I put it in the car, Im thinking of just sticking to Mobil 1 products for all three, my main concern is what tranny fluid do I put in there, if I want to stick with Mobil do I use the one that I posted up. Any input form guys running Mobil 1 in their trannys would be really appreciated, thanks.
Old 03-07-2011, 09:14 PM   #6
Capthowdy
Capthowdy's Avatar
Drives: 2010 2SS RS IOM
Send a message via Yahoo to Capthowdy
RP is far better as a synth oil product than most anything on the market...Far better than Mobil 1...only thing close in amsoil or redline which is Really expesive...
THE "MENACE"
Capthowdy is offline   Reply With Quote
Old 03-07-2011, 10:44 PM   #7
rb
rb's Avatar
You might check out this thread, especially the post from ssmike. Looks like he tried the Mobil1 synthetic ATF and didn't like the results.
http://www.camaro5.com/forums/showthread.php?t=132989
Old 03-08-2011, 08:32 AM   #8
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Get the right fluid!!! The Mobil 1 synthetic ATF you want for your Camaro manual tranny is based on the older Dexron 3 ATF fluid that was specified on the bottle for OLDER GM automatic trannys. The bottle says otherwise I know. Ignore that!
Some of the confusion comes from Mobil changing the product offering recently. They used to have 2 synthetic ATF formulas (1 for DEX 3 specified on the bottle for older GM cars and 1 that was specified on the bottle for newer DEX VI cars) but it seems they only have one true SYNTHETIC formula now. The Mobil 1 synthetic fluid you want should have a definate smell (gear oil smell) to it unlike the original GM fluid that comes out of your tranny. You want the DEX 3 based formula that says on the bottle it is for OLDER GM cars, not the Dex VI version that is specified on the bottle for Newer GM cars.
Also - The current Mobil 1 DEX VI ATF version (specified on the bottle for newer GM vehicles) does not apper to be synthetic. This fluid will not help your notchyness and should not be used.
-Mark.
Old 03-08-2011, 09:13 AM   #9
Russell James
Russell James's Avatar
For the M6 TR6060 trans, use 4 qts of Royal Purple Synchromax. I tried several different brands of synthetic, RP worked the best for me. Most noticeable when cold, it's a bit less notchy.
Some work good when hot, not so great when cold... RP was the only one I found that worked best hot or cold. Pricey, but worth it if your looking for the best.
Old 03-09-2011, 09:45 PM   #10
rb
rb's Avatar
-Mark.
Okay, I'm really confused. Are any of these the "right" fluid?
Old 03-11-2011, 06:14 PM   #11
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Can't read the bottle, but I'm pretty sure you want #3 (Mobil 1 Synthetic ATF - should say DexIII somewhere on the bottle)
Old 03-11-2011, 06:24 PM   #12
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Yes.
Old 03-22-2011, 01:15 PM   #13
camaro52010
Camaro4ever
camaro52010's Avatar
Drives: 2010 Camaro SS/RS, 1978 Z28 Camaro
Just did the same. Researching the (TREMEC TR6060 ) M6 tranny fluid though I could not conclude using Mobil 1 Synthetic ATF was acceptable. The factory fill was Texaco Dexron III with a warning not to use the new Dexron VI. Now that GM did not renew licensing of Dexron III they now recommend Manual Tranny Fluid Gm 88861800 ( not synthetic) which I bought to be safe. I could not find any Mobil 1 ATF meeting DEXRON III. http://paceperformance.com/i-5132104...rs-trucks.html
camaro52010 is offline   Reply With Quote
Old 03-23-2011, 09:47 PM   #14
JC0311SS
JC0311SS's Avatar
I just ended up changing my oil(mobil 1 synth), rear end fluid (mobil 1 75w90 w/ gm additive), and Gm manual tranny fluid. I got to admit this was real easy and it only took me an hour and a half and had fun doing it. I used a pump to get the tranny fluid in the tranny. The car runs great and I have the piece of mind that I got it all done properly.
Question about Halo Ring, color change JJSoCrazy Cosmetics and Lighting Modification Discussions 31 09-06-2015 12:57 PM
Oil change today at dealer ... question SummitWhiteLS Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 47 03-05-2011 08:59 AM
Gear change question macwest V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 08-28-2010 12:28 AM
Oil Change Question, What would you do??? tjbusa Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 9 08-19-2010 01:19 PM
V6 Oil Change Question WVCamaro10 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 6 07-07-2010 06:03 PM
