Old 07-07-2010, 03:23 PM   #1
WVCamaro10
WVCamaro10's Avatar
Drives: 2010 Camaro 1Lt RS Victory Red
V6 Oil Change Question
I have a 1LT V6 what oil does it use or what kind would be best to use... im sure this has been talked about on here...
WVCamaro10 is offline   Reply With Quote
Old 07-07-2010, 03:44 PM   #2
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
do lwat makes you feel good, either put the REGULAR oil in that is recommended or go with Mobil1 or any of the good synthetics. I have a 2LT and I also have a addy STS that has the same engine, Caddy recommends the Mobil1 for our engine, so that is what I am putting it it.
Old 07-07-2010, 03:48 PM   #3
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
i put mobil 1 synthetic in mine.
Old 07-07-2010, 03:50 PM   #4
Spiffyguitar
Spiffyguitar's Avatar
Drives: 2010 Camaro 2SS/RS
You'll get a bunch of different answers from different people, but bottom line is synthetic oil is proven to protect an engine better in the long run. The SS comes stock with Mobile 1 but other cars I've owned that came with standard oil, I switched after 5-7K miles. Mobile 1 is great... if you don't mind spending more, Royal Purple and Amsoil are both good too.
2010 Camaro 2SS/RS -6M
397whp/393 ft/lbs
Spiffyguitar is offline   Reply With Quote
Old 07-07-2010, 04:03 PM   #5
WVCamaro10
WVCamaro10's Avatar
thanks everyone looks like the synthetic is they way to go and from what i have been reading its about 6 qt of oil just wonder how much it would be at a dealer... i have heard that the v8 takes 7 to 8 qt of oil and it was 200 for an oil change witch is crazy..
Old 07-07-2010, 05:11 PM   #6
Spiffyguitar
I buy my Mobile1 by the case at Costco... It's about 30 (ish) bucks for 6 quarts. Changing oil yourself isn't too hard... I've been doing it for years. Get a friend to help you if you've never done it. Doing it yourself you're looking at 35-50 dollars (for a v6) per change with filter.
397whp/393 ft/lbs
Old 07-07-2010, 06:03 PM   #7
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
Mobil1 Syn right now... but i'm moving up to Castrol Edge for my next =p
jagan323 is offline   Reply With Quote
Another V6 Oil Question ToyotaCamaro Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 11 06-27-2010 10:51 PM
Cars ready for it's first oil change, quick question zerox Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 8 04-13-2010 11:01 PM
V6 Oil Filter Housing - Fill w/ oil when changing oil? bono83 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 15 12-06-2009 09:46 PM
Oil change question??? J Lambert Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 51 12-02-2009 07:38 AM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
