Old 03-07-2011, 08:46 AM   #1
RedVictory
Luv my LS3
RedVictory's Avatar
Drives: Summit White 2010 2SS/RS M6 LS3
Question Couple Questions about my new car
Hi guys,
i have a few questions about my v6 Camaro
I bought it in November (16k miles) but its been is storage since then so im not too familiar with it yet. Anyway i took it out this Saturday and i noticed two things, the first is that it seems to run very hot when its not moving. I am basing this on the coolant temperature function on the gauge display. I noticed it seems to hold around 210 when im driving casually, granted it was only 60 degrees that day. However when i stopped it in the garage it jumped up to 235 in a few minutes! I checked the fluid level and sure enough the overflow bottle was near empty! I paid for a synthetic oil change before i put it in storage so i assumed the they checked the fluid level. I went out and bought Prestone Dex-cool and filled it to about the middle line of the dip stick (while the engine was cool)
Has anyone noticed their coolant mysteriously disappearing?
The second thing i immediately noticed was that the engine seems to be making some strange sounds. I’m not talking about the clicking from the direct injector, but it makes kinda like a "whooping" sound like the belts are loose or something but i could not seem to find a problem. I could hear it from 30 feet away so i assume that may be an issue. Its hard to describe but maybe someone else has experienced this
This may be normal but I wanted to check with the pros before i blew this stuff out of proportion
I will probably just have to watch it and see if it gets worse, before I take it to the dealer
Thanks for any input!
RedVictory is offline   Reply With Quote
Old 03-07-2011, 08:58 AM   #2
Murph0408
Murph0408's Avatar
Drives: 2LT Black '10 Camaro, 2000 Durango
unaware of the engine sounds. doesn't sound good, man
coolant disappearing? maybe you have a leak somewhere
Murph0408 is offline   Reply With Quote
Old 03-07-2011, 09:04 AM   #3
ron10
Drives: 2010 2SS IOM L99
i would have your dealer check those issues.should not be doing either one of those things.
Old 03-07-2011, 09:07 AM   #4
RedVictory
Luv my LS3
RedVictory's Avatar
No signs of a coolant leak
I just wanted to be sure there may be somthing genuinely wrong with my car, im kinda OCD about it
Will be having the dealer install my new catback system soon anyway so i guess i should have them check these issues as well
Old 03-07-2011, 11:05 AM   #5
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
Neither of those sounds normal, and the temp should be holding at 190....210 is way to hot. The jump is a little normal, bit not a jump of 55 degrees... take it to your dealer ASAP!
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 03-07-2011, 11:17 AM   #6
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
If the additional coolant didn't help, have them check the thermostat. and the computer isn't detecting a problem as well?
Old 03-07-2011, 11:50 AM   #7
RedVictory
Luv my LS3
RedVictory's Avatar
thanks for the input guys, im glad i asked!
It just kinda bothers me that ive only driven this car 100 miles and there is already somthing wrong with it :(
Old 03-07-2011, 11:55 AM   #8
sprtplt
sprtplt's Avatar
Drives: Corvette
You better check for signs of coolant in the oil.
sprtplt is offline   Reply With Quote
Old 03-07-2011, 12:14 PM   #9
RSokie
Proud owner of Litho #195
RSokie's Avatar
Drives: 2011 CGM 2LT/RS
Check out this thread they talk about a coolant leak to check for.http://www.camaro5.com/forums/showthread.php?t=106513
Old 03-07-2011, 12:17 PM   #10
caverman
caverman's Avatar
Drives: '69 SS Convertible
Just because it's new doesn't mean everything will work 100%. That's why they give you a warranty.
This goes for anything new.....not just the Camaro.
Build Journal
Old 03-07-2011, 12:23 PM   #11
dragon22
Drives: 2010 Camaro 2SS/RS SIM
That bulletin looks like it is for the ZR1 and the Camaro SS.
As others have said, check your oil and see if it is milky, or over full. Did you notice any excessive white smoke out your tailpipe?
It is NOT normal and I would take it to the dealer regardless of what you find. No sense in doing harm to your engine.
dragon22 is offline   Reply With Quote
Old 03-07-2011, 03:01 PM   #12
RedVictory
Luv my LS3
RedVictory's Avatar
Thats what i needed to know, thanks guys i will keep you updated
Transmission output shaft hiller72 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 267 12-02-2009 09:39 PM
1st Car Show and meeting Al Oppenheiser! scrming 5th Gen Camaro SS LS LT General Discussions 44 08-17-2009 05:46 PM
#4768 - Delivered and Made Ready the Right Way! Number_9 5th Gen Camaro SS LS LT General Discussions 62 07-16-2009 03:42 AM
"The car of the future may turn out to be no car at all." Scotsman General Automotive + Other Cars Discussion 2 11-03-2007 01:22 AM
