Old 03-07-2011, 04:27 PM   #1
alssiri
alssiri's Avatar
Drives: 2017 ZL1 A10
Pedders help !
I foud one of the adjustment knobs on my rear XA coilovers was missing when trying to adjust & found it hanging on the coil is there anything could be done ? Thanks.
Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir
Glassskinz rear window valance .
2012 ZL1 A6 (SOLD)
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
alssiri is offline   Reply With Quote
Old 03-07-2011, 05:40 PM   #2
mws444
mws444's Avatar
Drives: 701 RWHP Lingenfelter/Pedders Beast
It is actually an extention to make it easier to adjust. Should be able to put it back on. I would add some locktight to the setscrew to keep it from getting loose again. I would also check the others. Also a good idea to retourqe everything on suspension everyonce in a while.
Lingenfelter forged balanced and blueprinted LS3, Maggie TVS 2300 LPE 9.5" Rearend 3.73,LPE dual disk clutch,10/14 rib belt drive,
MTI shifter,RPM Level VI,Corsa stainless cat back, Racing Brake Rotors, LPE calipers, LPE twin fuel pumps, American Racing long tube headers, GT9 cam Port and polished heads and an ADM majic tune.
701 RWHP,Fully Pedderized w/complete bushings and Sportsryder Supercar Remote resevior coilovers.
CCW 505t's Nitto Invo's and DR's
Beware of the LPE Brotherhood!
mws444 is offline   Reply With Quote
Old 03-07-2011, 05:50 PM   #3
Rob@WretchedMS
Drives: His Wife Crazy
+1
put it back on, tighten the set screw so that it's tight,
loctite is always a good idea.
any troubles let us know
Rob@WretchedMS is offline   Reply With Quote
Old 03-07-2011, 06:22 PM   #4
RichJ.
Shop Owner
Drives: 1 ton silverado
+ 2
RichJ. is offline   Reply With Quote
Old 03-07-2011, 06:30 PM   #5
RichJ.
Shop Owner
We have made up longer adjusters and treaded them into the trunk. That way the rear shocks could be adjust from in the trunk and you do not have to reach under the car to adjust them.
Old 03-07-2011, 06:45 PM   #6
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
sounds like they covered it.If you need anything let us know.
Bruce@raymondsperformance is offline   Reply With Quote
Old 03-07-2011, 08:02 PM   #7
Jaysin
Jaysin's Avatar
Drives: 2015 Chevrolet SS
Did you do the install yourself? Not sure how it came all the way out like that. If installed properly, it should have remained in the upper shock mount hole, not fallen out and been hanging on the coil.
You're most likely going to have to remove the rear shock and partially disassemble it to get access to the adjuster knob on the shock.
Jaysin is offline   Reply With Quote
Old 03-07-2011, 09:11 PM   #8
Rob@WretchedMS
Now that's what i call Pedders Support!
3 Dealers and 2 Customers
Old 03-07-2011, 09:23 PM   #9
Tyler@JDP
Tyler@JDP's Avatar
Drives: Chevy cobalt
Late for the party... LOL
Featured Products | Magnaflow | Airaid | Pedders | Hurst
Follow JDP Motorsports for NEW Releases and Special Promotions!
Tyler@JDP is offline   Reply With Quote
Old 03-07-2011, 09:37 PM   #10
Rob@WretchedMS
lol, welcome
where is the beer?
Old 03-08-2011, 12:15 AM   #11
alssiri
alssiri's Avatar
Thank you guy's will be removing them from the car to see what can be done, great support
Ahmad
2012 ZL1 A6 (SOLD)
Old 03-10-2011, 09:14 PM   #12
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
Pics?
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6
Jeanius is offline   Reply With Quote
Old 03-10-2011, 09:39 PM   #13
Rob@WretchedMS
it's top secret,
lol
Pete has them on his car, but i don't have pics, Pete might.
Old 03-11-2011, 12:22 AM   #14
JusticePete
Drives: Camaro Justice
I had them on the G8 and the Camaro. In the end, i decided to take them off the Camaro and just use the short version. The longer cable run lost some of the feel. I was never 100% certain I had 17 clicks of 18 or 16. The longer the cable run the less feel there was. It is so easy and positive to just reach up behind the rear wheel and feel the very positive clicks and know you are at 17... and since the bound adjustment was under there any way... short and to the point is the best solution.
Pedders Xa Coilovers and Springs | In stock | Free Shipping | Best Prices JDP Motorsports Suspension / Chassis / Brakes 115 02-16-2015 09:42 PM
Major Pedders Event in Houston! Saturday, Jan 30th! Meet DMS Info@PeddersUSA.com USA - Texas 9 01-11-2010 06:55 PM
