Old 03-10-2011, 02:00 AM   #1
iom
Drives: 2010 camaro iom ss rs
SOLO HIGH FLOW CATS MAKING VERY STRANGE & UGLY NOISE !
this is a radle / suction type noise .
this only happens at take off & when i rev at 2000 rpms .
the entire car shakes .
anybody know what the heck is going on here ?
l99 with ground fx
iom is offline   Reply With Quote
Old 03-10-2011, 06:18 AM   #2
CFD
Drives: 2SS/RS L99 BLACK
Check to make sure everything is tight and seated properly. I had a similar noise in my car, I also noticed it after I had my Solo's for a while, it turns out that it was my resonator, doesn,t mean that's what's wrong with yours but you might want to check it out. I had mine on the rack and could easily hear it was from the resonator
CFD is offline   Reply With Quote
Old 03-10-2011, 08:18 AM   #3
jtzako
Drives: 2010 IBM Camaro SS
Make sure it is actually bolted properly
Make sure it is not touching the silver metal shielding under the car
Make sure the exhaust is not in contact with the Tunnel Cross Brace (metal panel that goes under the exhaust around the middle of the car)
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 03-10-2011, 12:57 PM   #4
Alfieboy
Madman
Drives: 2017 1SS
what ya find?..anything yet?
Alfieboy is offline   Reply With Quote
Old 03-10-2011, 06:52 PM   #5
iom
i took it back to the guy who installed & he thinks its the resonator !
so i took it off and welded a straight pipe .
1. is the sound any better YES !!!!!
2. did this fix my problem NO !!!!!
Old 03-10-2011, 06:54 PM   #6
iom
well the only thing it could be is the cats them selvs , maybe i just got a bad set .
this kinda stuff always happens to me !!!!!!!!!!!
Old 03-10-2011, 06:56 PM   #7
iom
I am most sure that its the flex pipe itself , it raddles real bad at 2000 rpms .
so 1 out of 2 things .
1. this is normal with a l99
2. i got a set of bad cats !!!!!
I WILL CALL SOLO TOMORROW AND SEE IF THEY CAN DO SOMETHING FOR ME !
Old 03-10-2011, 07:22 PM   #8
CFD
It is not normal for anything to rattle. I can't see how the mesh could rattle. I believe that Solo's have the cores welded in multiple spots to prevent them from loosening but it is possible. Did you listen to it on the lift to see if you could hear it from underneath? All was not for nothing, you got rid of the resonator and I'm sure it sounds much better without it, I know mine did.
Old 03-10-2011, 10:04 PM   #9
first one
first one's Avatar
Drives: SSRS - black, GFX, SSX wheels
Sorry to hear this! Let us know what Solo does for you to help resolve the problem. How much louder does your exhaust get when deleting your resonators with solos?
first one is offline   Reply With Quote
Old 05-01-2011, 08:46 AM   #10
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
Did anyone find out what the rattle is? I am getting a loud vibration upon accelleration, which just started two days ago. It is not normal.
edog is offline   Reply With Quote
Old 05-01-2011, 08:52 AM   #11
Scott@Bjorn3D
Did he put an X-Pipe in where the resonator was? If not you just lost alot off the line since you are now down low end torque and HP.
Scott@Bjorn3D is offline   Reply With Quote
Old 05-01-2011, 12:52 PM   #12
edog
edog's Avatar
I will complete my Thorley system. Time for catback.
Old 05-06-2011, 12:43 AM   #13
AzTeK
AzTeK's Avatar
Drives: 2011 Camaro SS
I would check the entire system from the cats all the way to the tips, because I had a similar noise on my passenger side and the problem was the High-flow cats have a slightly less clearance then the stock cats and my catback was touching the heat shield underneath which made a awful raddle on start-up and while driving but when I adjusted the catback to clear the heat shield the noise was gone completly
AzTeK is offline   Reply With Quote
Old 05-06-2011, 02:45 PM   #14
Dosin
Dosin's Avatar
Drives: 2010 2SS RS black ground effects
I am installing my SOLO cats this weekend on my L99 A6. I hope I don't have the same problem. Keep us updated when you fix it regarding the cause.
Dosin is offline   Reply With Quote
WTB >> Solo L99 (auto) high flow cats Entaille V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 2 11-28-2010 06:24 AM
for sale ***NEW SOLO HIGH FLOW CATS*** bmbbl be V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 3 10-29-2010 07:02 PM
Solo High Flow Cats Installed Strokedhog Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 08-08-2010 03:42 PM
Solo Performance Bolt-On High Flow Cats Group Buy GOINGSOLO2 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 07-01-2010 01:31 PM
New Camo shots of a Camaro bballr4567 Camaro ZL1 Forum - ZL1 Specific Topics 150 02-18-2010 01:13 PM
