![]() ![]() ![]() ![]() ![]() Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
TVS2300 oil capacity??
anyone know the oil capacity of a tvs2300?
![]() Drives: Anything Supercharged Join Date: Apr 2010
![]() ![]() ![]() Drives: 2010 Camaro SS Join Date: Oct 2008
How often does it need to be changed?
thanks, we have that in stock 118ml bottle
Normal maintenance window on that oil is between 80-120k miles. If you are running higher boost levels and/or doing a lot of racing events I would recommend doing it closer to 80k. It's like the normal vs. severe maintenance schedule for your vehicle. Also, unless you completely remove the nose cover, don't put all 205 mL in. Use an oil extraction syringe to remove as much oil as you can. Measure how much was taken out and put that much plus a tiny bit more back in. The reason for this is you don't want to overfill the nose and cause a seal issue and unless you remove the nose cover you will never get ALL of the oil out.
#6 |
![]() ![]() Drives: 700 rwhp 2010 SS Join Date: Sep 2010
Is this the same for a E-force by chance?
#7 |
#8 |
supercharger is on the bench,, can i pull the plug and stand it on end,, will this drain most of the fluid?
#9 |
That would work. It might take it a while to get all of it out as this is a very thick oil. I would also recommend taking the rear belt/pulleys off so they don't get any oil on them. Just do the best you can to make sure the hole is the lowest point so that all of the oil naturally flows towards it and leave it sitting for a while.
#10 |
thanks,, ya ill take the pulleys and belt off
#11 |
![]() Drives: 09 CTS-V Join Date: Aug 2013
i have changed the oil for my TVS2300 and put 200 ml. now, oil seeps from rear-drive pulley seal only when the unit is off. should i just leave it seeps all the extra oil?
| A NEW generation of oil, for ALL GM cars | Sir Nuke | 5th Gen Camaro SS LS LT General Discussions | 48 | 11-03-2010 10:33 PM |
| Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 10:03 PM |
| synthetic motor oil? | bigd1276 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 71 | 01-29-2009 01:28 PM |
| Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 10:47 AM |
