J.Sick
Drives: 2010 Camaro SS Join Date: Nov 2010
Stock motor and 18" Drag radials equals bogggg.
STREET TIRES:
I ran a best of 13.3 with a 2.2 spinning 60ft. Stock DRAG RADIALS: I ran a best of 13.4 with a 2.1 bogging 60ft. Stock Do some mods before you get drag radials. ![]() I was hoping to get into the 12's with sticky tires but I ended up going slower. I was even doing 5k launchs and bogging. I guess I need more power now.
"J.Sick"
2010 Camaro 2SS |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 aqua blue SS/RS M6 Join Date: Feb 2010
Thats your driving man not the car! Sorry not bashing you, once you figure out how to launch with the new tires you will be in the 12s easy. A good driver should easy run mid 12s in a stocker with tires.
10.91 at 122 H/C stock block N/A
J.Sick
5K side stepping the clutch and I bog, 5K slipping the clutch and I bog. What can I be doing wrong? Now the clutch did stick to the floor twice but after waiting for a while it seemed fine. So please tell me, I hope I am doing something wrong so I can fix it but I don't think so. I had 1.6-1.7 60ft's in my 99 camaro all day. Would not having TPMS in the rears tires affect anything other than just having the warning light?
"J.Sick"
2010 Camaro 2SS Last edited by jasycz28; 03-12-2011 at 09:38 PM. |
![]() Drives: 2SS/RS Join Date: May 2009
The only time mine bogged is when I left the traction control and stabilitrac ON.
#5 | |
#6 |
J.Sick
All traction controls were off.
"J.Sick"
2010 Camaro 2SS |
#7 | |
J.Sick
"J.Sick"
2010 Camaro 2SS |
#8 |
![]() Drives: 2009 Cobalt SS/TC Join Date: Sep 2009
What size tires? What were your traps between the two. You pulled a better 60 on the dr's but ran slower so it's not the tires, unless there to big or something.
2009 Cobalt SS/TC: 10.89 at 133mph
#9 |
![]() Drives: 2011 VR 1SS Join Date: Feb 2011
How many miles on the car and have you ever done the fuel map fuse pull?
#10 |
Most likely it is either your clutch (half way up pedal) that is causing your problem or could also be clutch packs in the rear. What are the full times of your runs ie 60' 1/8 mi 1/4 mile trap speed. Mine did the same thing after racing it many times. Check for one wheel burn outs (clutch packs in rear) or weak burn outs. If the pedal keeps coming half way up I would change the clutch. You can try and change the fluid in the hydraulic system completely (at a shop) then after every few runs drain the reservoir with a syringe and refill, this may fix your problem. Hope it helps.
#11 |
Although I am in an A6, quite a few guys at the shop had the exact same issue with the clutch slicking. Andy at ADM Performance has has a fix for this - it's some kinda second spring setup. You can call ADM (214-228-8782) to find out more about it.
#12 |
No need. New clutch and rear. I would never use a "fix" like that. The clutch is designed improperly and the spring will just make things worse in my opinion. The key is clean fluid and not forcing the clutch to return.
#13 | |
| Launch control + 18" drag radials = one VERY unhappy PCM | thesubfloor | Dragstrip and Launch Techniques Discussion | 2 | 04-20-2010 08:39 AM |
| WTB: 20" Drag Radials | Supercharged SS | Wheels / Tires | 5 | 03-08-2010 07:57 PM |
| FS: Kooks headers+cats, tuners, drag radials | 1stGM | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 12 | 03-02-2010 08:30 PM |
| ALL Our Camaros are GM Prefer Pricing (old Supplier Pricing) at MacMulkin Chevrolet! | MacMulkin | Dealer Camaros for Sale | 0 | 01-20-2010 06:40 PM |
