Old 03-13-2011, 03:31 PM   #1
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
VVT Cam .......... or ......... LS3 Conversion
Ok. I know this info is spread out all over the place but I want some opinions with the idea that it will be for me.
I may be doing the install myself.....
(In case anyone hasn't seen it, member robertway did a diy write-up that is second to NONE in scope, and thouroughness with easy to understand vid, text and pics. Fantastic job.)
I want to hear opinions on the pros and cons of a VVT cam and an LS3 conversion.
My relevent mods are catless long tube headers, (Borla, so 1 3/4 primaries) 2.5" exhaust (also Borla), Fastlane cai, Magnuson TVS2300 supercharger, and it's obviously dynotuned. Everything else is stock.
Obviously it's an L99.
I'm hearing conflicting ideas and possibilities. Until yesterday, I thought VERY few people were doing VVT cams.
Now, you'll need to know my goal with this.
This will be my last power mod. With respect to the engine, I won't be doing anything else. No NOS, no blower swap, no underdrive pulley, nothing.
My order of importance is power, then sound. I want as much power as I can get and not be rocking all over the place.
I'll do a stall, and possibly rear end gears later, but this is my last power mod.
So, opinions? Insights? Lessons? Any info I can get will be great. Including wether I should do it myself or not, and where to spend my money at.
Thanks in advance.
Old 03-13-2011, 03:35 PM   #2
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
VVT cam from MAST
Old 03-13-2011, 03:44 PM   #3
mikeSS
mikeSS's Avatar
Drives: 2015 c7
i am no expert, but i believe in doing the LS3 conversation, just makes things easier.
team LS3?
Old 03-13-2011, 03:47 PM   #4
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
I'm doing the LS3 converstion. I didn't want to limit my cam options so much and I am happy to put the better lifters in my car. It makes it easier all the way around. I believe the the tune is far more important anyway and I have a great tuner.
Old 03-13-2011, 03:51 PM   #5
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
This will be an interesting thread to watch. About 3 weeks ago I was trying to make this same decision. But I ended up deciding to wait and do a cam at a later date.
At first I was leaning towads a VVT cam setup (Mast Motorsports) or comparable setup.
But then I thought I had a lifter issue and the heads were going to have to come off and the lifters replaced. So at that point I figured I might as well do the LS3 conversion so I would have more options in cams to use and I wouldn't have to worry about the AFM/VVT lifters, etc causing an issue some time in the future.
I know someone just recently had an issue with a VVT Mast Motorsports Cam setup on his supercharged L99.
I see if I can find the thread.
It was actually a broken value spring. Here's the thread. But I really like the stuff Mast Motorsports is putting out.
http://www.camaro5.com/forums/showthread.php?t=132873
Old 03-13-2011, 03:59 PM   #6
PQ
Booooosted.
PQ's Avatar
Originally Posted by mikeSS View Post
team LS3?
Nope. It's like a butterfly. Yes, technicaly it's a larvea or whatever when it's in a cacoon, then it becomes a butterfly. BUT, it was always a butterfly. I'm still L99 becasue it was that way at birth.
(and we all know it's really about the tranny, lol)
If I do the install myself, It'll be easier to not do the conversion. Plus, if I find the right cam in VVT, then the number of cam options won't matter. I can only pick one. Could be I need to find the cam and THEN make the decision?
Originally Posted by Milk 1027 View Post
VVT cam from MAST
But.... why?
Yes please. Find the thread.
More options in cams is good, but if my choice were found in a VVT cam anyway, then it woldn't matter. But I haven't really looked yet.
It's the specs that I don;t have a clue what means.
I'm basically mailing down the VVT or Conversion decision before going any further. Could be that I need to approach it from the other end.
I just want to get opinions and info first.
Old 03-13-2011, 04:05 PM   #7
Dangeruss
Bayoucitymusclecars.com
Dangeruss's Avatar
Drives: Camaro LSX
You're going to get a ton of different opinions here, but I think with the blower you really have all the power you need. You can go to a smaller pulley and make more boost. Once your cam goes in it will drop your boost anyway so you'll need it.
I went with a Comp VVT cam because I really just wanted the sound. An LS3 conversion is more expensive as well, but if you're doing your own labor you'll save a bunch.
If I hadn't gone with a blower I would've gone with a larger cam and an LS3 conversion.
Just my opinion...since you have the blower already...go with a VVT cam (and a torque converter).
Old 03-13-2011, 04:09 PM   #8
SGOS252382
SGOS252382's Avatar
But.... why?
Here's the thread I was talking about. He had a VVT cam setup and the car worked fine. But when he put a supercharger on his car he ran into some issues.
Old 03-13-2011, 04:09 PM   #9
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
But.... why?
Becuse I said so. And Greg Norris approves this.
Old 03-13-2011, 04:10 PM   #10
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
This thread will be full of win... subscribed...
Old 03-13-2011, 04:14 PM   #11
PQ
Booooosted.
PQ's Avatar
The TC is definitely something I will be doing down the road.
My car is a bit underpowered considering the mods. Blown with all the components and only 471rwhp. Ya, the wheels don't help, but guys with 22s have had better numbers. I'm not neccesarily chasing a number, because I wouldn't know what number to chase, but I do think I'm underpowered now, considering. Maybe my borla headers with the small primaries is hurting? Nto sure, but If I'm gonna do a cam, I want the max power benefit I can safely get.
Old 03-13-2011, 04:18 PM   #12
mikeSS
mikeSS's Avatar
Drives: 2015 c7
My car is a bit underpowered considering the mods. Blown with all the components and only 471rwhp..
ya i agree, you only have like 30WHP on me. and you have a supercharger. you need a cam my friend.
Old 03-13-2011, 04:20 PM   #13
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Is your transmission tuned yet?
Old 03-13-2011, 04:23 PM   #14
Dangeruss
Dangeruss's Avatar
Drives: Camaro LSX
Weren't there some issues with your tune? What PSI did you end up at?
Cunningham Motorsports Cam install Packages Ryne @ CMS USA - California 6 01-26-2011 01:38 PM
cam sensor part number needed for LS3 cam swap on L99 NEGXXIS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 12-12-2010 12:21 PM
Whiteside Customs Maggie 2300 + VVT Cam Project yyz28 Forced Induction - V8 3 10-17-2010 09:46 AM
ARH Headers & MTI Cam using stock mufflers (LS3) - Help! TinyToasta Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 09-19-2010 03:11 PM
Upgraded your cam in your LS3? What are your specs? Happy? papabearcamaro Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 06-26-2010 05:53 PM
