Old 03-14-2011, 06:03 PM   #1
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
ls3 valves breaking becoming an issue?
Hey guys... I did a search and saw some threads of this happening, but no specific info was really found, if this is a repeat subject I apologize.
I'm just trying to gather up info and have a general discussion on LS3/L92 heads breaking and dropping their Stock Valves. Who else has had or heard of records of this happening ?
It's happened to 2 local guys here in Colorado, and a LS3 camaro over-seas that the owner lives here 1/2 the time in the year. Thats 3 I have personally heard about all happening in the last 6 months. All with LS3 heads, all with stock valves and in mild cammed cars. All breakages happened at low engine load and 2500 or less rpms, and the valve springs were ok.
I know valve springs can break due to harmonic valvetrain noise, can the same be said about these light valves? Just another avenue of thought to think about when it comes to breakage.
Again, just a general discussion, this is not to scare off anyone from modifying their engines. There are literally thousands and thousands of people out there with zero issues, I'm just wondering if this is becoming more common trend to follow here, or if this unfortunately follows under "low percentage & bad luck"
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 03-15-2011, 01:55 AM   #2
Clint@A.I.R.
Drives: 99' Camaro 404 TT
I too have heard of this lately. Perhaps we know of the same 3 people that I know of. I hope this is a very small percentage of the cars out there. Any shops/builders have any input?
I personally have not seen this in cars that we worked on, however I know a few of the people in the local area that have had this happen.
Clint@A.I.R. is offline   Reply With Quote
Old 03-15-2011, 02:15 AM   #3
Scourage
Syntax Error
Scourage's Avatar
Drives: 2010 Camaro 2SS/RS
Running a Comp Cam with .624 lift, per the vendor and Comp Cams, their 918 springs would be fine.
Had an exhaust spring break just after I pulled out of my garage and was heading out of the apartment complex, couldn't have been doing but 10 MPH at the time.
Warranty on the springs expired 2 months prior. Happened about 5K after install.
Scourage is offline   Reply With Quote
Old 03-15-2011, 02:18 AM   #4
Rockslam
The Noob
Rockslam's Avatar
Drives: 2006 QSM GTO
Ouch , thats a horrible sight!
http://www.camaro5.com/forums/image.php?type=sigpic&userid=34286&dateline=130273  5644
Rockslam is offline   Reply With Quote
Old 03-15-2011, 02:18 AM   #5
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
OUCH!!!!!!!!!!!1
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 03-15-2011, 02:32 AM   #6
walhan_qtr
..[ Z06-QTR ]..
walhan_qtr's Avatar
Drives: '10 Camaro 2SS RS M6/ 07 C6 Z06
Send a message via MSN to walhan_qtr Send a message via Yahoo to walhan_qtr Send a message via Skype™ to walhan_qtr
I guess im one of those three. It happened to my camaro. its an LS3 with about 28k miles. mods were bolt-ons (installed at about 4k miles), TSP 231/236 cam kit (installed at around 19-20k miles), and a ported fast 102 (2400miles before it happened). it happened in 3rd gear at around 5000RPM. when inspected, it turned out the valve dropped and also we found out that one of the springs broke (which we believe caused the failure). good thing the block and cylinder walls ...etc are all fine. one of the heads got damaged, one piston broke, and pretty much thats it. car was driven really hard all its life. and have seen many long cruises (hence the mileage on the car) and have seen many 6300-6400RPM shifts (almost every day it was driven on lol)
it happened but i moved on. went with stock parts and ordered some ported heads and soon i will have a 100shot installed and only use it when needed
- 07 Silver C6 Z06, Darton sleeved LS7, 441ci, H/C/I, Duel Stage Nitrous, RPS BC3, TR6060, E85. (615whp/582wtq N/A)
- 09 Blk Z06, 427ci LSX, F2 Procharger, Brodix, Holley, ZR1 TR6060, ... (1204whp/1045wtq @ 24psi)
- 06 Blk C6, Darton Sleeved LS2, 427ci, H/C/I, F1X, RPM Trans/Diff, RPS BC3. (New #s soon)
- 10 Black Camaro LS3, 2SS/RS, H/C/I, bolt-ons, Spec. (470whp/450wtq).
- 07 Black Corvette C6(SOLD).
- 98 White/Red Corvette C5(SOLD).
walhan_qtr is offline   Reply With Quote
Old 03-15-2011, 12:35 PM   #7
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
Comp 918s LOL, I almost feel sorry for you.
Spec out your valvetrain properly. A little extra seat and guide wear is a fair price to pay for using overkill valve springs, especially if you turn rpms.
Ovenmitt is offline   Reply With Quote
Old 03-15-2011, 01:06 PM   #8
Badger
Badger's Avatar
Drives: 2010 ABM SS #14 of 2,027
Just trying to learn here....so are the 918 springs a dual spring??...What's the best dual spring out there??
"One of the ordinary modes, by which tyrants accomplish their purposes without resistance, is, by disarming the people, and making it an offense to keep arms."
-- Constitutional scholar and Supreme Court Justice Joseph Story, 1840
Badger is offline   Reply With Quote
Old 03-15-2011, 01:45 PM   #9
Clint@A.I.R.
Never had issues with PRC Dual Springs... But looks as if Walhan had PRC's and he broke a valve spring.
Old 03-15-2011, 01:50 PM   #10
SSACCO
SSACCO's Avatar
Drives: 2010 SS
Single. I never had luck with them in my ls1 either
SSACCO is offline   Reply With Quote
Old 03-15-2011, 02:24 PM   #11
Commit and Conquer
Commit and Conquer's Avatar
Drives: 2010 Camaro SS
Does it it make sense to upgrade the valves when you do the heads? What are the best valves for an upgrade?
Forged 418 w/Whipple 2.9L RMCR Tune
786 RWHP 745 RWTQ[/SIZE][/COLOR]
Manley Crank, Wiseco Pistons, Compstar H Beam Rods, ARP Main/Studs, Copper Treated "hi boost" head gaskets, FI Cam & Ported Heads w/Manley Extreme Duty Valves, Lunati Link Bar Lifters, Fuel System w/LPE Dual pumps, Twin Fuel Feed line/Single return w/ boost reference regulator, NW 102mm TB, 10-Rib ASP custom pulley kit, Twin RX Catch Cans, Roto Fab CAI, TSP Stainless Headers, Spec Twin Disc P-Trim Clutch, DSS Level 5 Axles, Eibach and BMR Full suspension
Commit and Conquer is offline   Reply With Quote
Old 03-15-2011, 03:12 PM   #12
Russell James
Russell James's Avatar
Everything should match as a package. Valves, springs, keepers, retainers,lifters, pushrods... all designed for a specific purpose and rpm. Mixing and matching is where people get into trouble. Along with the snafu's like a bad batch of crap from comp cams.
Get with a very experienced engine builder, and they will know exactly what valve train parts to use for the combo you are building.
Old 03-15-2011, 03:18 PM   #13
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Great now I am worried, I cant afford to break this motor after a cam swap! :(
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 03-15-2011, 05:03 PM   #14
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
good article
http://www.hotrod.com/techarticles/e...ngs/index.html
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Engine Dyno Testing LS3 Intakes INSIDE!! LS3 vs Ported vs FAST Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 10-01-2009 01:55 PM
LS3 Engine Dyno LSA Comparison Data Inside!! Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 09-14-2009 09:26 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
LS3 Specs, and Descriptions Mr. Wyndham Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 11-06-2007 02:04 PM
