Old 03-25-2011, 09:13 AM   #1
cmore
cmore's Avatar
Drives: 2011 Victory Red Auto 2SS
USB issues - fixed?
My 2011, 2SS was manufactured in Aug 2010 and have had issues with the USB not working consistently. Some times after starting car, the usb thumb drive would not be recognized as inserted and others it would find it and start playing where it left off when shut down. I would have to remove and reinsert the drive, for it to be recognized. Most of the time it worked correctly.
Last Monday I went by dealer and asked them to see if their were any updates. They found and installed one and the USB (knock on wood) has worked correctly since.
It took like an hour to do. I would have thought it would have been a lot quicker. I watched, from a distance, and the teck had to do a lot of screen settings even to get to the point. After which it seemed to be a automatic but kinda slow process.
cmore is offline   Reply With Quote
Old 03-25-2011, 01:20 PM   #2
2ndtimess
2ndtimeSS
2ndtimess's Avatar
Drives: 2010 2SS 6 speed Infernal Orange
Have 2010 2SS, Had problems with my USB not recognizing stick. Then It quit working altogether. Still could use CD player, radio etc, but the indash sytem would not even recognize there was auxillary input. Went back to dealer and after 4 days they found a pin on the connector had not seated correctly at factory and actually worked its way out. All is well now, since the one trip to dealer.
2ndtimess is offline   Reply With Quote
Old 03-25-2011, 01:23 PM   #3
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
same problems with mine.
I got a new PDIM module under warranty, I just have to take it in and get the labor done.
Old 03-25-2011, 01:27 PM   #4
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
What hardware/software version is your PDIM?
To find out: Plug in a USB device, press and hold the Menu button, the hardware/software version will be displayed on the radio LCD
Old 03-25-2011, 01:30 PM   #5
04Ram2500Hemi
Drives: 04 Ram 2500 & 2010 Camaro 2SS/RS
Mine acted up for the 1st time last weekend. I'm assuming it's a fluke for now, but if not I'll take it in when I get time
04Ram2500Hemi is offline   Reply With Quote
Old 03-25-2011, 02:54 PM   #6
mikel441
mikel441's Avatar
Drives: 2014 Sonic, 2010 Camaro SS
The only issue with the USB I have had was the blank screen when the radio sticks on a file name. Now when I add mp3s I always look at the file proeprties for any "wierdness" and the USB works fine.
mikel441 is offline   Reply With Quote
Old 03-25-2011, 05:53 PM   #7
cmore
cmore's Avatar
Holding the Menu/Select button causes
HW ID: CC
SW ID: CE
to be displayed.
Old 04-05-2011, 08:58 PM   #8
cmore
cmore's Avatar
Just wondering what are your hardware and software codes?
Old 05-02-2011, 04:22 PM   #9
cmore
cmore's Avatar
I thought my issues were fixed. Not as many issues but still sometimes have intermittent ones.
Such as:
After turning off engine, wouldn't start playing at all after restarting.
Won't recognize that a USB device is plugged in. Even after removing and replugging it in. Sometimes using another device will let me use the one it didn't recognize and some times that doesn't work either.
Goes through the "Indexing" after being shutdown and restarted. Even tho it had finished indexing before being shut down.
Doesn't do this every time but a lot of it.
Am keeping a log to try and pin the symptoms down.
So I guess the car will be back to dealer, again.
Old 05-02-2011, 04:56 PM   #10
fastfreddie
FreakyFast!
fastfreddie's Avatar
Drives: 2010 2SS/RS S/C NicKey #55
Mine "Indexes" every time I turn the car off and back on. I just thought this was normal operation, it's not?
FF
2010 2SS/RS #55 NicKey Stage 2S Super-Camaro custom painted by Pete (Mr. Showstopper)
Build Thread: http://www.camaro5.com/forums/showthread.php?t=250743
fastfreddie is offline   Reply With Quote
Old 05-02-2011, 08:19 PM   #11
cmore
cmore's Avatar
I don't think so as some times mine doesn't run the index step at least with the same usb plugged in.
Old 05-04-2011, 10:58 AM   #12
Chevrolet Customer Svc
Drives: GM Vehicles
cmore, I'm sorry to hear about the issues you've had with your USB system. How many times have you been into your dealership for this issue? Also, have you ever spoken to our Customer Assistance team on this issue as well? Thank you for your time.
Jeff Morris, Chevrolet Customer Service
Old 05-04-2011, 11:21 AM   #13
cmore
cmore's Avatar
Just once, so far. They updated the software. And that helped some. Am now keeping a log on what happens as the issues seem to be intermittent. Since it is, hopping the log will help with is determination of the problem.
No. Thought I would work through the dealer first. But if that is not the way to go, would be glad contact the Customer Assistance team. Assume they are the ones mentioned in the owners manual.
Old 05-06-2011, 12:01 AM   #14
xXSilencerXx
Butter Bar!
xXSilencerXx's Avatar
Drives: 2011 SS, 1998 Trans Am
Does the Music need to be in the root directory for it to work? My Usb hasn't work since the day I got it.....nor does it work correctly with my Zune.
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension
2004 GSXR 1k, Matt Mladin Edition
xXSilencerXx is offline   Reply With Quote
USB Problems? phenixdragon Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 11 09-24-2017 05:55 PM
Rally Stripe Issues and Warranty Issues MRKNJ Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 10 06-28-2010 12:59 PM
2009 issues fixed? cmcghee559 5th Gen Camaro SS LS LT General Discussions 3 03-04-2010 05:42 PM
USB Underlighting and Halos Mohrg Beast Cosmetics and Lighting Modification Discussions 1 02-04-2010 03:05 AM
Camaro issues L99, 6 speed, quality, etc. larietrope 5th Gen Camaro SS LS LT General Discussions 7 07-14-2009 11:03 PM
