Old 03-25-2011, 12:49 PM   #1
66olds442
Born Olds, Living Chevy
66olds442's Avatar
Drives: 2011 2SS/RS: VR A6
What size plug do i need to plug the hole where the o2 sensor goes?
I was able to remove and reinstall 3 of the 4 o2 sensors on my new headers. One won't come out and I need something to plug up one of the empty holes where the o2 sensor should go. What size screw will I need or what should I ask for? The guys at my local auto shop have no idea and don't carry o2 sensors.
Thanks in advance.
66olds442 is offline   Reply With Quote
Old 03-25-2011, 12:57 PM   #2
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
Thanks in advance.
when i did my 92 Z/28 headers i used a threaded metal pipe cap that i bought at ACE hardware. just match the threads to the threads on your sensor.
joes407 is offline   Reply With Quote
Old 03-25-2011, 01:02 PM   #3
Russell James
Russell James's Avatar
Penetrating oil overnight. Then heat up the exhaust pipe bung around the sensor with a torch. Should come out. The service manual says to take out the O2's when the exhaust is still on the car and hot from driving. They spin right out if you do that. If left in a cold pipe, quite the hassle to get out but often a torch works.
Old 03-25-2011, 01:06 PM   #4
66olds442
66olds442's Avatar
Thanks Russell james. I got 3 out while hot but this one just wouldn't break free. I let oil penetrate over night and still won't turn. Just need something to plug the hole up for the moment so I can drive my car.
Old 03-25-2011, 01:29 PM   #5
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Don't know the size. You could take one of the sensors out of your new exhaust and take it to your hw store to find a nut that fits it. Then buy a short bolt that fits the nut.
Or just find a new sensor... most any auto parts store SHOULD carry O2 sensors, and muffler shops should have them as well.
And yes, heat will help getting the old sensor out. Be careful, since the penetrating oil is flammable, and make sure you don't have a puddle of it on your garage floor.
Old 03-25-2011, 03:15 PM   #6
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
Not exactly sure, I'm at work a the moment but I'm thinking that I used an M18 oil drain plug on my Harley (which uses the same sized GM style O2 sensor). I used an exhaust RTV on the threads. You might give that a shot.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 03-25-2011, 03:20 PM   #7
Russell James
most are M18
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 07:53 PM
tire plugging OK ? shinzon Wheels and Tires Talk Sponsored by The Tire Rack 31 08-24-2010 11:49 AM
We need help with Electronics wiring diagrams 2SSRS@Gen5diy Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 11 12-13-2009 06:58 PM
