Old 03-28-2011, 03:15 PM   #1
first one
first one's Avatar
Drives: SSRS - black, GFX, SSX wheels
Catch can location
I am getting ready to purchase an RX catch can which, with 12000 miles on my car, I know I should have done it sooner. Anyway, can someone tell me which is the better location for the can, on the driver's side near the CAI or the other location on the passenger side near the fuse box. You need to state where you want to locate the can when purchasing so they can send the correct bracket.
Are there any add-ons that may conflict with the placement like my roto-fab CAI? I may do the ADM scoop and roto-fab water bottle relocation and not sure if these will dictate where I need to place the can. Also, is one location better than the other in terms of running the hoses to and from the can?
Thanks for your input!
first one is offline   Reply With Quote
Old 03-28-2011, 03:24 PM   #2
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
I didn't know they started offering a driver's side options. I went with the passenger side. It doesn't conflict with anything. I would think the driver's side would be tighter since you have the air box over there.
I see you have the V8 so that might be different. But on the V6 nearly everyone puts theirs on the passenger side off the radiator bolt.
[B]
Old 03-28-2011, 03:25 PM   #3
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Mine (not the RX version) is mounted on the bottom side of where the stock CAI used to go next to the battery cable. Worked out pretty good as far as routing lines for the L99
Sorry the pics aren't any better...
Old 03-28-2011, 07:59 PM   #4
bmbbl be
bmbbl be's Avatar
Drives: 2010 CAMARO SS
mine isnt a rx ,,,but mounted on drivers side
bmbbl be is offline   Reply With Quote
Old 03-28-2011, 08:12 PM   #5
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Passenger side radiator bolt is a good spot as mentioned earlier. Based on what you said about the ADM scoop etc, passenger side makes the most sense,
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 03-28-2011, 09:15 PM   #6
first one
first one's Avatar
I've seen that pic on another thread bmbbl be, very sharp. I was thinking the passenger side made more sense too, indeedss1, I just wanted to hear from others that have installed one on an L99 V-8 and which location looks the best without conflicting with any current and future mods. The passenger side has more void space to fill up which seems like it will look better there and may be easier to get to when draining.
Old 03-28-2011, 10:22 PM   #7
Tom D
Tom D's Avatar
Drives: 10 Camaro SS/RS RJT
Here is how I did mine. If you plan on a E-Force later this is the best place. Lots of room.
2010 2SS/RS RJT, ADM CAI, Borla Shorties, Borla "S" Cat Back, Edelbrock E-Force Supercharger, GMS Wires, GMS Rear Trailing Arms, GMS Rotors, GMS End Links, GMS Tunnel Brace, GMS Rear Tie Rods, GMS 1G Suspension Package, GMS Stage 3 CNC ported heads, GMS Spec'd R12 Custom Ground Camshaft, Snow Meth Injection, GMS Custom Tuned, Norris Catch Can, MTI Brake Lines, Pfadt Coilovers, Sway Bars, Camber Kit, and Rear LCA Reinforcement, , AAC Footwell, Trunk, DRL and Dome LED Lighting, Technostalgia Tail Lights, RED B/A Pedals, Kompression Custom Wheels with Nitto tires, 621RWHP/584RWTQ
Tom D is offline   Reply With Quote
Old 03-29-2011, 08:05 AM   #8
SC2150
Here's the drivers side location:
Pass side radiator shroud mount:
V8 pass side tensioner bolt mount:
Old 03-29-2011, 08:49 AM   #9
first one
first one's Avatar
Thanks SC2150! That's what I wanted to see so I could compare the different locations even if they all aren't the V-8. Are you still running behind on your catch can orders. I'm looking at ordering a gloss black one with breather.
Old 03-29-2011, 09:56 AM   #10
first one
first one's Avatar
Ordered from SC2150
DIY: PCV catch can install lawdogg149 Camaro DIY & HOW-TO instructions & discussions 57 11-05-2018 04:15 PM
Elite Engineering Catch Cans Now Available At APEX Motorsports! Multiple Colors! Apex Motorsports V8 Bolt-Ons & Tunes 136 06-30-2011 05:24 AM
catch can routing on top mount blowers bilydean Forced Induction - V8 12 01-11-2011 07:48 PM
Elite Oil Catch Can flht99b Vendor and Seller review / feedback / experiences 20 06-08-2010 05:00 AM
New Install Oil Catch From Elite Engineering BUMBLEB Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 04-21-2010 07:34 AM
