Old 03-31-2011, 06:46 PM   #1
shayes
Drives: 2011 Camaro SS Manual
Installed Gauge Pods. Now I need some info about them.
Hey Guys,
I just installed the gauge pod on my 1SS. I was wondering if you could give me some numbers of what all the different gauges should be at operating normal and when to be concerned.
Thanks
shayes is offline   Reply With Quote
Old 03-31-2011, 06:54 PM   #2
Cbrenthus
Drives: 2011 VR 1SS
Pretty much pointed straight up when warmed up. As far as normal, you'll get used to what they should read based on the outside temp and your current driving to know why they should be. Oil pressure will fluctuate when warm. Outside of all that you'll get used to wants normal and if you have a reading outside the norm, then you have an issue.
Cbrenthus is offline   Reply With Quote
Old 04-08-2011, 09:30 AM   #3
porkrind
Unapologetically American
porkrind's Avatar
Drives: 2018 Camaro ZL1 M6
Under acceleration, will the oil pressure get to 70? Mine does and then goes back to 30. This is normal right?
porkrind is offline   Reply With Quote
Old 04-08-2011, 01:21 PM   #4
Cbrenthus
Drives: 2011 VR 1SS
I don't knwo exacktly on the V6, but that doesn't sounds like anything to worry about to me.The oil pressure always goes up the higher the rpm
Old 04-09-2011, 11:19 AM   #5
shayes
Thanks for all the information guys!!!
Camaro Dove Tail Spoilers Compilation daphatgrant Cosmetics and Lighting Modification Discussions 473 07-11-2025 10:07 PM
4 gauge pack installed cmyzfly 5th Gen Camaro SS LS LT General Discussions 174 06-26-2011 12:30 PM
**Camaro5 Exclusive First Look** AutoMeter air bag compatible pillar pods!! Team STILLEN Cosmetics and Lighting Modification Discussions 4 05-27-2010 04:07 PM
AEM AFR Gauge installed MKS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 12-30-2009 06:10 PM
