Old 04-01-2011, 05:41 PM   #1
gtc352
Gtc352
gtc352's Avatar
Drives: 2010 2SS Camaro 2010 GMC Sierra
Edelbrock S/C and Fuel Injectors?
Upgrading my fuel rail with the JRE Edelbrock fuel rail upgrade. I also ordered larger fuel injectors from Jannetty for future upgrades. My question is: the fuel rail looks like it is under the top cover of the S/C. Do I have to remove the top cover to get the fuel rail off the injectors? It looks like about a 1/4 inch from the bottom of the cover to the top of the fuel rail. Anyone replace injectors with the Edelbrock S/C? Thanks
gtc352 is offline   Reply With Quote
Old 04-01-2011, 06:24 PM   #2
armysig
Catch me if you can
armysig's Avatar
Drives: 2012 IOM ZL-1
Give Ted a call. He'll make sure you get it done right. When in doubt...Ask Ted.
armysig is offline   Reply With Quote
Old 04-01-2011, 06:43 PM   #3
lock
lock's Avatar
Drives: 11 2SS/RS E-Force Supercharged
No. Need to remove cover. A few allen bolts and the rails pop right out. Quite simple on enforce.
11 IOM 2SS/RS E-Force Supercharged. 616 RWHP/578 RWTQ. Click link for my journal!!!
lock is offline   Reply With Quote
Old 04-01-2011, 08:00 PM   #4
B.Buster
B.Buster's Avatar
Drives: 2010 AquaBlue 2SS/RS
What size injectors and type did you get?
B.Buster is offline   Reply With Quote
Old 04-01-2011, 08:41 PM   #5
gtc352
Gtc352
gtc352's Avatar
Shop was closed so couldn't get a hold of Ted. I got the 85's from Ted for future upgrades. I finally got the injectors out and new ones in! Just didn't want to break them. There is a lip that the rail sits under so makes it a little awkward. But I got it now!
Old 04-01-2011, 08:46 PM   #6
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
yeah what he just said.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 04-01-2011, 08:48 PM   #7
2010 SS RS
2010 SS RS's Avatar
Nice those are the same ones I got from Ted..Work great but make sure you are sitting with the tuner when you start that bad boy up...All the setting will need to be adjusted like right away.....Huge change in flow. I hope you got the pumps to back them sprayers up.
Old 04-01-2011, 09:07 PM   #8
gtc352
Gtc352
gtc352's Avatar
Ted gave me a tune to go with everything. I'm running the MSD voltage booster. Staying with the stock pump for now.
Old 04-01-2011, 09:39 PM   #9
B.Buster
B.Buster's Avatar
I'm looking to get the same injectors in the next few weeks.
Old 04-01-2011, 10:12 PM   #10
lock
lock's Avatar
Typos and all!
Old 04-01-2011, 10:14 PM   #11
Huck1974
Drives: 2011 2SS
Won't hurt a thing to drive it to the dyno or further if needed.
Huck1974 is offline   Reply With Quote
**For Sale :: 2010 L99 Intake Manifold :: Fuel Rails + Injectors Included SonnyakaPig V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 6 11-05-2012 11:49 PM
Modifying for " Dummies" Dr Jkel Tuning / Diagnostics -- engine and transmission 209 06-18-2012 12:24 AM
FS: New Venom 424cc 40lb/hr High Flow Fuel Injectors tooNz213 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 0 12-23-2009 03:53 PM
changing injectors, how does my dash display calculate fuel economy general23cmp Tuning / Diagnostics -- engine and transmission 9 12-03-2009 09:24 AM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
