Old 04-04-2011, 08:21 PM   #1
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
V6 manual tranny fluid & the 1-2 shift
Has anyone improved the 1-2 shift by changing out the tranny fluid? What brand did you use?
If you have changed your fluid but it did not help the 1-2 shift, what brand did you use?
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 04-09-2011, 01:16 PM   #2
esperman
You Can Call Me Jay
esperman's Avatar
Drives: 2010 1LT RJT Manual w/CAI & Solo
my tranny occasionally would grind in high rev speed shift.
Installed Red Line 75W-90 NS.
tranny seems to like it.
esperman is offline   Reply With Quote
Old 04-14-2011, 03:00 PM   #3
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
Can anyone provide the actual part number for Royal Purple for the LS M6 tranny? Thanks!
TheHorse13 is offline   Reply With Quote
Old 04-14-2011, 04:18 PM   #4
c_LoW29
Drives: 2011 2SS/RS, 2010 Mustang GT
http://www.google.com/search?hl=en&q...og&sa=N&tab=wf
75w90
and it is the same for your differential no Limited Slip additive needed it is already mixed with the gear oil
c_LoW29 is offline   Reply With Quote
Old 04-15-2011, 07:15 AM   #5
TheHorse13
TheHorse13's Avatar
Thanks!
Old 04-15-2011, 09:07 AM   #6
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
had a 1-2 grind, amsoil cured it.....
h2oplay is offline   Reply With Quote
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 58 12-01-2019 10:54 PM
Solo Performance V6 Mach-XL (Manual) and Mach-XLT (Auto) Exhaust Kits GOINGSOLO2 V6 Bolt-Ons & Tunes 13 07-13-2010 02:28 PM
LS3 manual trans fluid change - less noise, etc? TommyTSquared V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 33 03-14-2010 07:05 PM
ALL Our Camaros are GM Prefer Pricing (old Supplier Pricing) at MacMulkin Chevrolet! MacMulkin Dealer Camaros for Sale 0 01-20-2010 07:40 PM
Automatic faster than the manual??? 2sharp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 319 09-30-2008 10:20 AM
