Old 04-06-2011, 12:11 PM   #1
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Exclamation Spring Install affected my car's weight - NOT GOOD for racing
Anyone who's installed springs might be interested in this.
Been having problems getting off the line at the track lately. I've got trailing arms, swaybars, lowering springs and 18" Mickey Thompson DR's and still can't break a 1.9 60'
First thing we noticed was only the right tire was spinning on burnouts so we installed the JRE posi mod and went straight back out to the track.
Spinning both tires now, but at launch and every shift the car would break loose and not run in a straight line. Had to fight it all the way down the track to the point it was scary...
Owen at ARD suggested we put it on the scales and check all the suspension parts. The results totally shocked me (not him) as you can see in the pics the left rear mounts were not tightened down in the original factory position and there is a lot of play up there.
I've had lowering springs for a while, the car is perfectly aligned and drives great. The recent round of HP upgrades and running at the track exposed this one in a couple of ways. Left tire would not spin and car would not leave straight. We also have GoPro video somewhere that shows the car diving to one side on takeoff.
I would have never know this without scales... Check out the left rear at 490lbs... a simple loosen bolts and pry back over brought it to 886 which was much better. Then we put a 1/8 shim under each bolt and got it even closer.
EDIT: Quite sure my ONE WHEEL BURNOUT was attributed to this, however the posi mod does work quite well. I now do much better burnouts and getting 1.70 or better 60' times
Old 04-06-2011, 01:25 PM   #2
bmwdon
I refuse to go smurfy
bmwdon's Avatar
Drives: 2009 Challenger SRT8, 2010 Camaro
that's some badass info...thanks!
-Bill...the Camaro was my wifes, now she's got a minivan
Challenger- 2009 Dodge Challenger SRT8 Procharger D1 Supercharger: 10.895 @ 126.720 MPH
bmwdon is offline   Reply With Quote
Old 04-06-2011, 01:41 PM   #3
WadeWilson
How U Doin?
WadeWilson's Avatar
Drives: 2014 CTS-V Coupe
Thanks for the info Mike! I'm curious to know if I'll experience the same issues.
Old 04-06-2011, 01:52 PM   #4
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
wow great info, so how exactle would one look out for this when installing drop springs? Sorry if it sounds like a dumb question. do I just make sure they ine up with the intial markings?
CAMARO
Old 04-06-2011, 02:27 PM   #5
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Get a sharpie and draw circles around the bolts before you loosen them.
If your racing I would find someone with scales like these to see where you are at... It's a pretty quick job but finding scales might be a problem
Here's one video of a slightly crooked run, but the go pro on the front of the car really shows it last week.
Old 04-06-2011, 02:33 PM   #6
motorhead
Why did the overall weight go up 6lbs just from making an adjustment?
Old 04-06-2011, 02:44 PM   #7
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Damn... you had me thinking on that one...
We swapped the rear tires and wheels while we had them off adjusting springs. The 18" Mickeys are getting packed in the trailer for C5Fest and I have a set of Nitto DR's on the stock rims. Now I have to swap them all out at home to roll on the 22's to AZ
And I did weigh the tires while they were off.
58 lbs for the 18"
61 lbs for the 20"
and it even adds up...
Old 04-06-2011, 02:51 PM   #8
13 ZL1
13 ZL1's Avatar
Drives: 2013 IOM ZL1
How will coilovers prevent this? Don't they mount to the same holes?
13 ZL1 is offline   Reply With Quote
Old 04-06-2011, 03:02 PM   #9
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Mainly just an excuse cuz I want some..
...but you would be able to adjust them up or down to change the weigth distribution.
I was also suprised at the effect a small amount of air pressure does...
Old 04-06-2011, 03:05 PM   #10
ADV.1 Matt
Drives: N/A
Interesting info! Thank for posting it up.
ADV.1 Matt is offline   Reply With Quote
Old 04-06-2011, 03:15 PM   #11
13 ZL1
13 ZL1's Avatar
It sounds like whichever you use, checking the weight distribution is necessary.
Old 04-06-2011, 03:29 PM   #12
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Yeah... either way you would never know...
I also noticed the last Total weight is one lb more. That was the small shims... These scales are pretty damn sensitive.
Old 04-06-2011, 03:53 PM   #13
Sawyer
Sawyer's Avatar
Drives: '13 5.0
for coilovers - What brand were you thinking of going with?
Sawyer is offline   Reply With Quote
Old 04-06-2011, 04:00 PM   #14
MAD600SS
Bayou City Muscle Cars
MAD600SS's Avatar
Drives: 2010 Camaro SS/RS 427LSX w/ 2 Kits
Owen knows some stuff, doesn't he!
MAD600SS is offline   Reply With Quote
PFADT DROP SPRING INSTALL QUESTION ... BLACOWT Suspension / Brakes / Chassis 14 04-06-2011 12:48 PM
Brembo install and weight specs Beauwulf Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 8 12-26-2010 07:17 AM
Crash tests downgrade small cars KILLER74Z28 General Automotive + Other Cars Discussion 0 12-19-2006 04:31 AM
