Old 04-11-2011, 10:59 AM   #1
JAB
C_H_E_V_Y
JAB's Avatar
Drives: Velocity Yellow C6 Z06
Engine Block Swap ?
This may be a very Stupid Question and if so, My bad . Is it posible to just swap out my 6.2L L99 Block for a LS7 7L Engine block or would i haft to buy the complete Crate Motor from GM ? And if so what would i haft to do to make this work ? My plan is as of now to just Supercharge My L99 with a Vortec and i just came by a 7.0 Liter LS7 Z06 Block and thought it would be sick to make the SS a 7.0L But had no idea if it was posible to just swap blocks or is there more to it ?
Thanks for the Answers
Heritage Grill
Flat Black Full Body Stripes
Flat Black Tail Light Bezels
Flat Black Camaro Emblems
Flat Black / Red SS Emblems
Flat Black Side Markers
Chevy Bowtie Delete
Led Grill Lighting
Interior Led Lighting
Near Future ( 1'' Drop Springs, GFX and *headers,Xpipe and 3in catback with an CAI is on it way* Getting ready for the PROCHARGER
JAB is offline   Reply With Quote
Old 04-11-2011, 11:22 AM   #2
HumanWiki
Drives: Car
I assume by block you mean the whole engine right? People have put in 7.0L and 7.4L in their Camaros, but I think you're looking to spend some $$$$$$ doing it.
HumanWiki is offline   Reply With Quote
Old 04-11-2011, 11:29 AM   #3
sspaul
sspaul's Avatar
Drives: 2010 ss camaro, imperial blue
Send a message via AIM to sspaul Send a message via Yahoo to sspaul
yes it can be done, i think it would be easier to just put a complete crate motor or a built motor from a reputible engine builder. also talk to you local performance shops and see what they recomend. also what are your performance goals. also remember anything can be done for the right amount of $$$$
my youtube
my facebook
www.myspace.com/1djchampagne
www.twitter.com/1djchampagne
mods: borla long tube headers, borla atak catback, lingenfelter gt-9 cam, ported heads, ecs base kit running 11 psi on top end, 1" bmr drop spring, aam 3.70 gears, ported throttle body, 160* thermorstat, lethal racing tune
750/641 rwhp/rwtq
sspaul is offline   Reply With Quote
Old 04-11-2011, 12:44 PM   #4
kpwalls06
Cory
kpwalls06's Avatar
Drives: 2010 Camaro 2SS/RS M6;
If you have a good performance shop near you, the engine swap isn't that hard. An LS9 motor is pretty difficult, but the LS7 is easier. It does require proper tuning and programming, though.
kpwalls06 is offline   Reply With Quote
Old 04-11-2011, 12:59 PM   #5
Russell James
Russell James's Avatar
A ton more to it. The LS7 is a pretty unique engine. Different heads, block, intake, oil system... A crate motor would be easier
Old 04-11-2011, 01:49 PM   #6
VictorySS
Edit now 5th Camaro
Drives: 2016 2SS
You can re-use your stock oil pan and pick up with a LS7 no problem, you would need to get sum custom headers to fit the exhaust ports but other then that its not that bad. Jus sayin
1995 V6 First Car - Sold
2000 Z/28 11.12 @ 125mph Sold
2000 SS - Sold
2001 ZO6 - Sold
2010 Camaro SS Sold
AEM Intake / 1" Drop / Forgeline / TSP Headers / AMT Catback / 20% Tint
Current Whip 2016 2SS Hyper Blue!
VictorySS is offline   Reply With Quote
Old 04-11-2011, 06:51 PM   #7
kpwalls06
Cory
kpwalls06's Avatar
If the OP is talking about swapping a whole motor, then no, there's not a ton more to it. It just takes a knowledgable shop and good tuner. If he's talking about just the LS7 block with no internals, then obviously it would cost more, but still not bad with the right shop and tuner. All the LS motors are based on the same platform, so the biggest problem is programming the computer, IMHO.
Old 04-12-2011, 08:17 AM   #8
VictorySS
Edit now 5th Camaro
Drives: 2016 2SS
Tuning is also very easy, its not some dark science. Like you said you just need the right shop or just the right tuner
2000 SS - Sold
2001 ZO6 - Sold
2010 Camaro SS Sold
Old 04-12-2011, 09:09 AM   #9
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
Also the snout of the forged LS7 crank need to be shortened and a keyway cut into the nose. Easier to use an aftermarket forged LS3 crank or factory L99 cast crank. Also, you will drill the block to provide for a dip stick unless you stay dry sump. Some other details as well.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 04-12-2011, 09:40 AM   #10
CC Performance
Drives: 99 Camaro SS, 79 z28, 70 GTX
They way I read it you want to use the LS7 cylinder block to repalce your L99 and make a blower engine out of it...
Not a good idea.... on a few levels
CC Performance is offline   Reply With Quote
Old 04-12-2011, 01:12 PM   #11
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
No need for custom headers...ARH worked just fine.
Cam 427 is offline   Reply With Quote
BREAKING: 2012 CAMARO ZL1 - 6.2L LSA Supercharged - 6MT Revealed! Tran Camaro ZL1 Forum - ZL1 Specific Topics 756 05-01-2013 06:22 AM
Oil Leakage! franknbeans Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 21 09-27-2010 04:39 PM
Anyone notice oil residue everyone oil change? speeD3m0n2010 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 6 09-23-2010 07:22 PM
LLT engine specifications Tran Wiki 2 03-29-2010 10:06 AM
AirAid Cold Air Intake anyone? FLYNNZL1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 01-01-2010 09:05 PM
