![]() Drives: 2011 LS V6 6spd manual Victory Red Join Date: Aug 2010
Has anyone out there installed the BF XENON fog-light kit on an LS with no factory fogs? Just curious if there is factory wiring already in place or do I need to wire everything based on a wiring diagram that I received from the manufacturer?
I spent almost $380.00 on this kit only to find that there were no install instructions in the box. When I emailed BFX they referred me to a post on the forum. All well and good but it was for an install with existing factory fogs: http://www.camaro5.com/forums/showthread.php?t=56238 I then received this wiring diagram jpg in an email from BFX: This wiring diagram is way too generic and doesn't help as to wiring the ballasts as well as where to even mount them let alone where to run the switch wiring. The forum post does mention that but is also vague as to the switch install. I guess what bothers me the most is that BFX is a forum sponsor, sells great products (I already have their HID headlights that had great install instructions and when I had an issue their customer service was on top of it) and I can't imagine why there would not be specific install instructions included in the box for the fogs. I need some help and guidance so I don't screw this up. I have a Heritage grille install planned for next week that will require me to remove the front facia and was planning on installing the fogs at the same time. Any response from someone who has already installed these would be appreciated. Maybe pix or at least some directions as to the wiring? Regards, Dave aka 40AGAIN |
I put some fogs w HIDs in my LS. The ballasts go in between the fogs and the relay. And u run the switch into ur cabin thru the firewall, drivers side.
Dave I'm about to install fogs in mine this weekend, I'll let you know and give ya a hand
Thanks! I really want to get them in before the 23rd along with my Heritage grille. Please let me know how the install goes regarding the wiring process and where you mounted everything. Please either post here or on the SMCC site.
Post some pics, getting the same ones from BFXENON 2011 LS package hid fog light kid for 450 $
| DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) | robertway | Camaro DIY & HOW-TO instructions & discussions | 313 | 12-16-2023 07:53 PM |
| The truth behind the birth of the LS motor.... | danhr | Off-topic Discussions | 3 | 01-12-2011 07:55 PM |
| 4.10 or 3.73 Gear & Install Kit Combo | Apex Paul | Transmission / Driveline | 21 | 08-21-2010 02:55 PM |
| DIY : Install catback on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 3 | 08-09-2009 05:36 PM |
