![]() ![]() ![]() ![]() ![]() ![]() Drives: 1997 30th Ann. Z28 & 2010 2LT RS Join Date: Jan 2010
Location points for "Timing " Bushing
Installing my Pfadt Lowering spring today and wanted to know is there a picture anywhere that shows the points of interest " Bolts " that have to be loosen to " Time " the bushing at the Alignment Shop ?
Just want to make sure the Alignment shop hits all the right pivot points . It's there 1st Camaro on the rack ! Any help would be Great . Thanks
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
http://www.camaro5.com/forums/showthread.php?t=71994
Go through this thread (which happens to be a sticky at the top now) and specifically look at post #45.
Build Journal ![]() |
"Camaro Joe"
Simply put any rubber bushing that connects the wheels and subframes
Drives: 2010 1SS Join Date: Jan 2010
FRONT:
Thanks for all the input !
#6 |
Show & Go
Drives: '10 Camaro 1SS LS3 Join Date: Apr 2011
So, this is damn near impossible to do in your own garage I am thinking??
Sold: Blk/Blk 2010 SS M6 - Speed Inc SI5V2 Cam & Tune, TSP Underdrive balancer, XS Power LTs, XS 3" Exhaust, Roto-Fab Intake, BMR 1" Drop Springs, and more. Only 5600 miles!
#7 |
:chevy:
Drives: 2LT/RS Join Date: Jun 2008
So if your installing this in your own garage, you would have to install the springs, then jack up the car, loosen all these bolts, lower the car. Roll it around. Bring it back, raise the car and tighten bolts?
CAMARO
Consult your doctor before taking Camaro Side effects include Sudden increase in Heart Rate, Insomnia and occasional hallucinations If you experience Permagrin exceeding 4 hours after taking Camaro, seek immediate Camaro5 Help CAMARO Bringing excitment back into the Garage |
#8 |
:chevy:
Can someone do this in their own garae and then bring it to an alignment shop to avoid the fees and ensure it is actually done?
CAMARO
#9 |
![]() Drives: 95 bbb impala ss Join Date: Apr 2009
You could do it yourself I did mine myself I put the car up on my 2 post lift loosend everything up then drove it to the alignment shop and I know the guys there so they let me tighten everything up before they did the alignment if you had a 4 post lift or ramps you could do it all yourself
| BMR launches New Product - Rear Cradle/Diff Bushing Kit - PRO version (BK030) | BMR Suspension | Suspension / Brakes / Chassis | 4 | 07-28-2010 09:48 AM |
| C5-Fest Caravan Rally Points Across the US | Rookie13 | 2010 Camaro5 Fest (I) | 433 | 04-15-2010 08:20 PM |
| C5 camarofest rally points during the trip. | edog | USA - Mid-Atlantic | 160 | 04-14-2010 08:51 PM |
