Hub Centric Rings?
Hub Centric Rings....Good idea or not needed? I just got new 20" A/R Torque Thrust M's. I attempted to get the wheel/tires road-force balanced when I had the factory pirelli's mounted on the wheels, however, they said the fronts would not balance out (the rears did balance out, but it was still close). 3 out of the 4 wheels have a "ton" of stick-on weights hiding behind the spokes now. They are now balanced, just not to the degree required for "road-force" balancing. I thought for sure the problem would be because of the cheap Chinese heavy cast wheels, but I was really surprised when they said it was because of the Pirelli tires and not the wheels. Anyway, I was thinking maybe a set of Hub Centric Rings would give me a little more reassurance that my wheels are running true? It's better to have the wheels "Hub Centric" instead of "Lug Centric", isn't it??? I do not have any major vibrations that I can feel or anything right now, but just wondering if these rings are a good idea.
Anyone know where I can find 66.9 - 74.1 rings??? I found one place online that will custom make some really beautiful aluminum rings for me, but they want $125.00!!!! That's ridiculous!!! I can't find them pre-made for the size I need, any suggestions? Thanks. Last edited by blazzin1; 04-15-2011 at 03:40 PM. |
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro LS M6 Inferno Orange Join Date: May 2010
try justforwheels.com
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers Find me on Facebook: http://www.facebook.com/gahammerle |
Is the Camaro 66.9 or 66.6? I had emailed them a while back and they said I would need 66.6 which they had.
Gordy
#6 | |
376 cubic inches of fun
Did the dummies who sold you the wheels lose them? |
#7 |
I don't think these wheels normally come with hub centric rings, I think that must be something that Tirerack includes with the sale of their wheels. There are just too many possibilities, every different car will have a different I.D. And I did not buy my wheels from tirerack, so no, they did not come with any rings.
#8 |
So nobody has any suggestions on where I can buy these rings, or any advice about using these in the first place? I'm guessing there must not be very many people using them then, must not be too important!
#9 |
All blackkk
Drives: 2010 2SS/RS LS3 Join Date: Oct 2011
Any updates? I can't find hub rings in the US for less than 100$ for 74.1 bored wheels...
Drivin it like I stole it.
#10 |
Jeez, that was almost 2-years ago!!! I believe....(back when I had those wheels), I just went without the rings. Didn't have any issues.
#11 |
![]() Drives: 2012 Infiniti G37S Join Date: May 2011
Don't think I can help you on price, but I was looking at getting some custom built rings from Motorsport Tech. I've only looked at their website for now but I like what I see. Plus they're made in the U.S.A, out of Sparks, NV. Another option worth looking into.
#12 |
![]() ![]() ![]() ![]() Drives: 2010, 2LT, RS, 6M, ABM (#1893) SOLD Join Date: Mar 2011
got mine at amazon
2010 2LT/RS; 6M, ABM, Torq Thrust M w/custom center caps, Solo MachX-LLT, Blue Anodized Pedals, Barton Shifter w/UMI blue anodized pistol grip, Ported IM from Mace, 25mm isolator/spacer from Mace, Vararam CAI, Euro Rear Fascia, RX Breather Cap. SOLD 4/23/13.
Now have a 1965 Chevelle 4 dr wagon!! |
#13 |
![]() ![]() ![]() Drives: . Join Date: Nov 2012
I got mine from Jegs.
#14 | |
All blackkk
| DIY - de-chroming and painting tail light trim rings | themossman | Camaro DIY & HOW-TO instructions & discussions | 140 | 10-02-2011 10:53 AM |
| SPEC Clutch/Flywheel Upgrades | Single & Twin Disc!! | AJ@ECSMotorsports | Transmission / Driveline | 21 | 11-13-2010 04:58 PM |
| Unbeatble Prices on ACT / Fidanza / Hurst / Mishimoto / MTI / SLP / Spec / More | maperformance | Transmission / Driveline | 18 | 10-26-2010 03:16 PM |
| Caution! Centering Rings On After Market Winter Rims | KFH | 5th Gen Camaro SS LS LT General Discussions | 0 | 03-29-2010 10:33 PM |
| Attn: Vendors, Piston Rings for L99 | jpetro | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 21 | 11-03-2009 02:09 PM |
