Old 03-29-2010, 10:33 PM   #1
KFH
1SS Victory Red Manual
KFH's Avatar
Drives: 2010 1SS 6 Speed Manual
Caution! Centering Rings On After Market Winter Rims
Just a heads-up for those of you who installed winter rims that came with plastic centering rings. When I was taking my winter rims off, and put the first summer rim back on, I noticed it wasn't seating properly when I tried to tighten the lug nuts. Then I realized that the plastic centering ring was stuck on the hub due to rust on the flange. I did some damage to the ring and had to spray on some lubricant and use a small screwdriver to remove the ring from the hub. All four rings were stuck on the hubs the same way, so next year I think I will apply some grease to help prevent this from happening again. If you have a garage do your change over, you should warn them about the rings, because the rust stains kind of hides them and they might not notice they are stuck there.
1st Camaro - 77 Type LT Rally Sport, 3 Speed Manual, Inline 6 2nd - 94 Z28, 6 Speed Manual LT1 V8
3rd - 2010 1LT, 6 Speed Manual LLT V6 4th - 2010 1SS, 6 Speed Manual LS3 V8, RX Catch Can, Holley iNTECH CAI, Flowmaster Force II Exhaust
KFH is offline   Reply With Quote
Any market for 4 20x8 MS front rims w/tires? rdread Wheels / Tires 0 03-18-2010 06:23 PM
Just a word of caution about buying after market parts! coolman 5th Gen Camaro SS LS LT General Discussions 21 03-03-2010 06:31 PM
Winter Tires and rims CWHGonzo Wheels and Tires Talk Sponsored by The Tire Rack 14 11-01-2009 01:04 PM
Winter tires - Quick question about rims CamK18 Wheels and Tires Talk Sponsored by The Tire Rack 1 10-04-2009 01:00 AM
Cheap 20" rims for winter driving Arch Wheels and Tires Talk Sponsored by The Tire Rack 12 06-05-2009 08:49 PM
