AwesomeBillDawesonville
Drives: CGM 2SS/RS =) Join Date: May 2009
The "DO's and DONT's" of driving a clutch
I'm still fairly new to driving a clutch. Are there any rules I should follow strictly?
Things I've herd from friends (myths?). Sounds like BS to me.... -Dont skip gears -Push the clutch all the way down when shifting -DONT sit at a light with the clutch in while in gear, better to stay in neutral -downshift to save your brakes
Order placed on 1/13/11 - Purchased 2/22/11 2SS/RS CGM |
#2 | |
![]() ![]() ![]() Drives: 2014 2LT Red Rock Metallic Join Date: Jul 2010
Definitely push the clutch all the way down. I put my car in neutral when stopped at a light, but I'm not sure if this one matters. Downshifting to save your brakes works, but you're not supposed to do this while you're in your break in period. That's all I got for ya.
![]() Drives: IOM 2010 L99 Join Date: Mar 2011
Well in UK or somewhere like that they make you use your emergency brake if your in neutral in case your hit and pass out when at a stop light. So usually i just have it in 1st and the clutch in so it will die if i get hit
![]() Drives: 2010 Camaro 2SS/RS Black Join Date: Feb 2010
Never understood downshifting to save your brakes?? Brake pads are relatively inexpensive whereas the transmission is not. I'd rather have more wear on the brake pads myself.
![]() Drives: 2010 1SS/RS M6 Join Date: May 2010
Skip all the gears that you want... hell, GM put the 1-4 skipshift in there, I'm sure if it was bad to skip gears then they wouldn't have.
You can get away with pushing down the clutch just far enough to disengage it, anything past is just an extra motion that's not 'required'. Personally I don't think it matters if you sit at a light with the tranny in gear, the clutch is fully disengaged and there won't be any contact, thus no wear. However, if you sit there on a hill, for example, and are riding the clutch to stay still, then that'll cause excess and unneeded wear. And finally, this I never got. Brake pads compared to a clutch, which is cheaper to change out? I'd much rather use my brakes to slow down. |
#6 | |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
If you're new to manuals, then I'd stick with pushing the clutch down all the way until you get more experience. Sitting at a light either with or without the clutch depressed is your choice. Personally I sit in neutral at lights. As for engine braking....It does save your brakes, but not any extent that you'll notice on a street car, and not worth burning out your clutch prematurely. Brakes are easier and cheaper to change out than a clutch is. |
#7 |
![]() Drives: 2011 camaro 2ss/rs ls3 Join Date: Jan 2011
Holding in the clutch causes the throw out bearing to wear out faster, skipping gears = fine hence 1st to 4th skip from the factory, much easier and cheaper to change brakes then transmission parts, if ur new to a stick I would push the clutch all the way in during shifts until u learn the point on ur car where the clutch is completely disengaged.
#8 |
Tall Guy
Drives: '11 LS SGM, '96 BK, '88 S10 Join Date: Jan 2011
So when you say downshift to break, does that mean you are rev-matching to the new lower gear and letting yourself coast down? Or are you letting the clutch out without rev-matching, and in turn slowing the vehicle and forcing the engine to rev?
#9 |
I rev match to save on the clutch/tranny as should everyone else. It won't really wear the clutch that much and it just sounds cool. If I need to stop a little quicker than normal I just use the brakes/downshift combo.
#10 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
When you get really good at driving you can shift without pushing in the clutch.
#11 |
1 do is to occaissionally burn rubber when going into second.
#12 | |
![]() Drives: 2016 2SS, Yellowjacket, A8 Join Date: Oct 2009
GeorgeM |
#13 |
![]() ![]() ![]() ![]() Drives: 2013 2LT/RS Summit White Join Date: Feb 2011
yup - what I was taught; plus braking is visible to the car behind, while downshifting is NOT.
#14 |
Black Ma6ic
Drives: 2011 Camaro LS M6 Join Date: Dec 2010
I was taught not to stay in neutral while at a light, because you have to be ready to react if something was to happen. If in neutral you would have to clutch in and shift to first. If you're already there you can just move.
DT Headers l MRT v2 l Injen SRI l Hurst STS l Resonators Delete l Lowered 1.25'' l 35% Tint l Black Bowties l Tinted Tail Lights l AAC lighting l Debadged
| Silver Camaro Dos and Donts | soughi | Camaro Photos | Spyshots | Video | Media Gallery | 44 | 09-02-2012 07:15 PM |
| Supercharger Do's and Dont's | jty03 | Forced Induction - V8 | 46 | 02-17-2010 07:20 PM |
| do's and dont's of owning new camaro | babyjulie83 | 5th Gen Camaro SS LS LT General Discussions | 59 | 10-18-2008 01:46 AM |
