Old 04-22-2011, 01:03 PM   #1
Soloshawn
Drives: 2011 Camaro 2SS/RS
How Often Oil Change?
I have only put 5,700 miles on my 2011 2SS/RS since I bought it in July 2010, and I do use it as a daily driver. I just don't drive very much. The On Starr system used to tell me that I had 55% left until an oil change. Now it tells me on my monthly report that I have 99% left until an oil change. So the question is when to change for a low mileage daily car and what type of oil? Thanks everyone. Bloody On Star.
Soloshawn is offline   Reply With Quote
Old 04-22-2011, 01:05 PM   #2
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I go with the every 5000 miles ...
Old 04-22-2011, 01:16 PM   #3
paultheman2007
SWFLGENS
paultheman2007's Avatar
Drives: 2011 Camaro 1SS
i go with every 4,500 to 5,000 miles so no later then 5,000
SWFLGENS on facebook.
paultheman2007 is offline   Reply With Quote
Old 04-22-2011, 01:25 PM   #4
Chevy Fanatic
Drives: 2011 2SS/RS IOM/PEARL STRIPES-6M
If I understand this correctly, On-Star was reporting 55% remaining before next oil change, then suddenly switched to reporting 99% without you changing the oil? If so, it sounds like there was an accidental reset of the oil life monitor.
Chevy Fanatic is offline   Reply With Quote
Old 04-22-2011, 01:33 PM   #5
TAPSHIFT
TAPSHIFT's Avatar
Drives: '11 IBM 2SS/RS '16 1GB Z51 ragtop
Oil changes
So far you're about 5 months past due. You shouldn't be gauging your change intervals by mileage alone. And, I'd be sticking with full synthetic.
TAPSHIFT is offline   Reply With Quote
Old 04-22-2011, 01:40 PM   #6
Trailnut
Trailnut's Avatar
Drives: '15 Colorado, '73 C/10
Mobil 1
Wanting a FIFTY
Trailnut is offline   Reply With Quote
Old 04-22-2011, 03:54 PM   #7
Soloshawn
All the drive thrus around here serve Pennzoil oil. is that any good? If not one of them said to buy the Mobil 1 and they will put it in. In a wheelchair so can't change it myself.
Old 04-22-2011, 03:56 PM   #8
SlingShot
SlingShot's Avatar
Just take it to the dealer, they will check all your fluids and you'll have a work history on the car.
Old 04-22-2011, 07:31 PM   #9
Kermit1
Kermit1's Avatar
Drives: 2011 Callaway 2SS/RS
Just follow the DIC reading. When it gets blo 20% or 1 year which ever comes first then it's time to change. Mobil 1 prefered. I change mine once a year just before winter storage (my past Corvettes) and will follow the same routine with this car. Any sooner is a waste of money but do what makes you feel better. Today's high tech engines for the most part can go much longer between changes. Enjoy your car in any case.
Kermit1 is offline   Reply With Quote
Old 04-22-2011, 09:01 PM   #10
jbp-ohio
jbp-ohio's Avatar
Drives: '11 IBM 1LT
At 1000 miles since break-in dirties oil faster than normal wear. Then at 5000, 10,000 and so on.....
jbp-ohio is offline   Reply With Quote
Old 04-25-2011, 10:57 PM   #11
Slick1
New Guy
Slick1's Avatar
Drives: Black 2011 1SS.
I've been getting on it pretty good lately and changed the oil today at 1652 after reading a bunch of posts about getting the metal out. Oil looked nice and clean. I almost regretted it when I saw that but better safe then sorry and now the car won't be getting any for 5000
Slick1 is offline   Reply With Quote
Old 04-26-2011, 09:07 AM   #12
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
every 5000miles or 6 months imo.
jagan323 is offline   Reply With Quote
Old 04-26-2011, 01:01 PM   #13
TOMS1SS
Drives: NA
The manual says change whenever the oil sensor tells you to or after 1 year.
TOMS1SS is offline   Reply With Quote
Old 04-26-2011, 01:37 PM   #14
Camaro21
Drives: SOLD - 2013 M6 ZL1
I changed my oil with Mobil 1 every 5,000 miles.
Camaro21 is offline   Reply With Quote
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 07:11 PM
AFM turned off by my dealer???? fastfreddie 5th Gen Camaro SS LS LT General Discussions 95 08-25-2012 03:55 PM
A NEW generation of oil, for ALL GM cars Sir Nuke 5th Gen Camaro SS LS LT General Discussions 48 11-03-2010 10:33 PM
