Old 04-22-2011, 01:59 PM   #1
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
Question What oil do I need to put in my rear end diff?
And does it hold one quart like everyone has said.
Pollock is offline   Reply With Quote
Old 04-22-2011, 02:28 PM   #2
DieselDork
DieselDork's Avatar
Drives: 2010 RS/SS
I used Royal Purple 75w-90 in mine. Yes, 1QT filled it up.
DieselDork is offline   Reply With Quote
Old 04-22-2011, 02:38 PM   #3
Nomad
Nomad's Avatar
Drives: '11 2SS/RS RJT M6
You need to use a 75w-90 gear oil. If it doesn't come with it, you need to add a limited slip differential additive. I believe Royal Purple already has the additive. I used Mobil 1 75w-90 LS which already has the additive in it (the "LS" stands for "Limited Slip").
Vararam CAI, Elite Engineering Catch Can, Separate Clutch Fluid Reservoir, Ghost Armor Full Protection Package, Chromed Turn Signal Bulbs, RPI Stealth Splash Guards, Skip Shift Eliminator, Defenderworx Chrome Bowtie Inserts, Pfadt Trailing Arms, Camaro Decal Store CGM Hood Spears with "376ci" custom text, Billet Depot/Drake Underhood Polished Caps, CGM Lug Nut Decals, Pedders Front Radius Rod Inserts, JacFab Front License Plate Bracket
Nomad is offline   Reply With Quote
Old 04-22-2011, 02:59 PM   #4
Pollock
LT4 M6
Pollock's Avatar
Should I change it after the first 1000 miles or so? I bet it is full of metal shavings already.
Edit: Looks like a pain to get to now with the flowmaster cat back system installed.
Old 04-22-2011, 03:05 PM   #5
IROCanSS
Drives: 89 IROC 350
Mine has been changed several times... dont ask... I use Mobil 1 LS. You can add the additive if you want. Read the label on the bottle it says that for "extreme performance cars" to add the additive... just depends on if you feel your driving is "extreme"
I also changed my tranny to Mobil 1 ATF... WOW major imporvement.
Old 04-22-2011, 03:06 PM   #6
Rich1
Rich1's Avatar
Drives: 2023 ZL1 Camaro Hot Red
I purchased Royal Purple also. I will be changing mine in the near future. I have almost 10K miles on mine. A lot of guys were changing it after a few thousand miles.
Rich1 is offline   Reply With Quote
Old 04-22-2011, 03:22 PM   #7
Pollock
LT4 M6
Pollock's Avatar
Did it shift smoother or something?
Old 04-22-2011, 03:50 PM   #8
DieselDork
DieselDork's Avatar
Drives: 2010 RS/SS
I changed it at like 7k miles. In all honesty I probably wouldn't have done it had I not had the extra quart left over from recently changing the Dana 80 in the rear of my diesel (like 7 qts!!!).
Old 04-23-2011, 03:15 AM   #9
Blueovalman
Blueovalman's Avatar
Drives: 2012 V6 Camaro 2010 Camaro SS
Mobil 1 synthetic 75W90
Mobil 1 synthetic ATF
Don't forget that Mobil 1 is endorsed ang highly recommend by GM engineering
for a number of reasons.Mobil 1 is a excellent quality synthetic to use.
Blueovalman is offline   Reply With Quote
Old 04-25-2011, 10:45 PM   #10
Iron Lung Jimmy
Drives: Iron Lung, Jimmy
I used Mobil 1 LS and, even though "LS" is supposed to mean limited slip, it chattered pretty badly. Changed to regular Mobil 1 and a bottle of the GM additive and all is well.
Iron Lung Jimmy is offline   Reply With Quote
Old 04-27-2011, 05:44 PM   #11
camarobrah
Drives: camaro
Owners manual is full of all fluid info.
camarobrah is offline   Reply With Quote
OIL CATCH CANS john468 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 5 09-16-2010 03:02 PM
Oil from the rear end 2PitbullSS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 06-30-2009 11:01 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
