Old 04-25-2011, 08:15 PM   #1
dcarlos55
dcarlos55's Avatar
Drives: 2017 HBM A10 ZL1
Line Lock installed
I put the solonoid and lines in for my line lock today. Haven't ran the wiring yet.
I was looking around inside trying to decide where to put the primary power switch and light. Trying to find somewhere to put them besides in the top of the console. Just looking for suggestions.
My build thread http://www.camaro5.com/forums/showthread.php?t=224342
Go is good. Stop is better.
dcarlos55 is offline   Reply With Quote
Old 04-25-2011, 08:46 PM   #2
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Must .......................have ........................pictures!
Old 04-25-2011, 08:59 PM   #3
Macrackie
Macrackie's Avatar
Drives: 2011 Camaro LS Stripper model
I saw soom nitrous switch photos of switches to arm and power bottle heaters installed in the center consile under the arm rest. I think they used power tapped off the 12volt outlet thats right there to make for easier installation.
What line lock kit? Easy install? Photos please? Cost? This is something i would like to do.
Macrackie is offline   Reply With Quote
Old 04-25-2011, 10:18 PM   #4
dcarlos55
dcarlos55's Avatar
SLP line lock kit. Had a couple of issues with the lines fitting around the shock towers but over all it was an easy install. I have the newer style shock towers with the threaded holes for a tower brace which I think are a little bigger than the earlier ones.
Wiring it up shouldn't be a big deal either if I can just decide where to put the switch and light.
I'll post pictures tomorrow. Too dark to take them now and I'm supposed to be working.
Old 04-25-2011, 10:23 PM   #5
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
So, can this be used on the v6? Because u r in the v6 section...
Old 04-25-2011, 10:26 PM   #6
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
i wired mine to the cruise control, works like a charm...turn on cruise, hit brakes hard while pushing in cancel cruise botton..let off brakes while holding in cancel..give gas -spin tires -let go of cancel button lets front brakes release..your on your way, and no does not affect cc either..
mikepage0007 is offline   Reply With Quote
Old 04-25-2011, 10:43 PM   #7
dcarlos55
dcarlos55's Avatar
Oops, didn't mean to put it here. Must have been paying attention to work and not the more important Camaro stuff.
Can't see why it wouldn't work on a v6 car. The fusebox and abs block are still in the same place.
Old 04-25-2011, 10:45 PM   #8
usa1camaro1969
Back on the dino-juice
usa1camaro1969's Avatar
Drives: '10 LS + a few more
Yes, it can, but I really think they either can't read or don't give a rat's ass where they post.
I wake up in the morning and I piss excellence.
-Ricky Bobby
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
usa1camaro1969 is offline   Reply With Quote
Old 04-25-2011, 10:49 PM   #9
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
So intelligence doesn't increase with horsepower?
BaylorCamaro is offline   Reply With Quote
Old 04-25-2011, 10:50 PM   #10
The_cartoonist_88
Turbine Cowboy
The_cartoonist_88's Avatar
Drives: 2010 Yellow 2LT Camaro
instead of the consol you could put it in the spot where you can put a dash plaque at. that "D" shaped indention thats on the dash kind of behind the key
2010 YELLOW 2LT
The_cartoonist_88 is offline   Reply With Quote
Old 04-25-2011, 11:02 PM   #11
PoorMansCamaro
Drives: Really Slow
So where the HUD controls go for the 2011 camaros
Old 04-25-2011, 11:27 PM   #12
dcarlos55
dcarlos55's Avatar
SORRY ALREADY. If I could delete it, I would. If I could move it, I would. Please feel free to if you can. I guess the only time you ever made a mistake was the one time you thought you made one but really didn't.
Once again, sorry if I pissed in your pool.
Old 04-26-2011, 10:25 PM   #13
Macrackie
Macrackie's Avatar
Sorry you "pissed in the pool" I am a v-6er and still want to see your install of the switches when done. I will check out the SLP kit thanks. Piss on these guys and just PM the install out come to me as they were "just a bit critcal" (insert eye roll)
Old 04-26-2011, 11:21 PM   #14
usa1camaro1969
With all the v6-v8 bashing that seems to roll through here yes we get more than a bit butt hurt. There's been plenty of line-lock threads roll through the drag racing section or maybe a search. I located a wrecked Camaro and got the brake line running from the master to the ABS and cut/flared in some fittings and installed a Hurst. I don't have a light and I use a momentary switch that has a 2-wire plug so I can unplug it when not in use.
-Ricky Bobby
line lock question paslag Suspension / Brakes / Chassis 3 09-23-2010 06:36 PM
Line Lock / Roll Control Fishdadddy Suspension / Brakes / Chassis 40 05-05-2010 02:51 AM
2010 Camaro SS & V6 Line Lock/Roll Control Meister@Torq Suspension / Chassis / Brakes 0 02-23-2010 12:27 PM
now logging actual line pressure in A6, less than 100psi in 3rd parish8 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 02-20-2010 10:46 PM
FYI - Rally Stripes Will Be Factory Installed talwell Camaro Price | Ordering | Tracking | Dealers Discussions 13 08-28-2009 10:35 AM
