Old 04-27-2011, 11:25 AM   #1
Captain McFunk
Break Necks, Cash Checks
Captain McFunk's Avatar
Drives: 2010 black Camaro 2SS/RS
Fuse pull AFTER tune?
Hey guys, this might be a silly question but I'm not sure. I have the SCT Jannetty tune on my car right now, 93 octane tune. Well I went on a road trip and the highest octane I could find when stopping for gas was 92. Could this cause the computer to go to a lower octane table? Could this cause issues with the engine since the tune is for 93? It's almost all gone one and I'm about to fill up with 93, so hopefully it'll be okay, just wanted to check with you guys!
Thanks
-Adam
2009 CTS-V - White Diamond - intake, exhaust, wheels, visual mods
Captain McFunk is offline   Reply With Quote
Old 04-27-2011, 12:13 PM   #2
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
A fuse pull won't change the tune at all. And running 92 octane shouldn't cause it to switch to the low octane table.
IndeedSS1 is offline   Reply With Quote
Old 04-27-2011, 12:31 PM   #3
aj2ssrs
Drives: IOM 2SS/RS
I believe the high octane tables are copied over to the low octane tables anyway so in essence they are the same. Running 92 octane gas won't be a problem. I doubt that every time you fill up with 93 octane, you're actually getting 93. Depends how long the gas is sitting in their tanks. Make sure you go to a station that has high traffic flow, this should lower the chance of getting poor gas. I definately wouldn't put 87 or 89 octane in the tank, but you're fine with 92. The knock sensors will kick in and compensate.
ADM race intake, Dynatech lt headers w/hi-flo cats, Jannetty Racing dyno tune, VMax CNC ported TB, MGW short throw shifter, Elite Engineering catch can
aj2ssrs is offline   Reply With Quote
Old 04-27-2011, 01:23 PM   #4
JANNETTYRACING
JANNETTYRACING's Avatar
Thanks
-Adam
The Knock sensor constantly protect the engine so you have nothing to worry about.
Although I would not recommend racing your car on Lower than 93 octane fuel Normal driving is Fine.
A fuse pull does nothing with a tune.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 04-27-2011, 01:32 PM   #5
IndeedSS1
IndeedSS1's Avatar
That doesn't seem like a good Best Practice.
Old 04-27-2011, 02:19 PM   #6
Captain McFunk
Ted.
Thanks for the info!
Old 04-27-2011, 03:27 PM   #7
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Ted.
Never really got a tuners opinion on the fuse pull. Ted, is the LS3 and L99 the same as far as the fuses? Or does the LS3 need a battery cable disconnect too?
Old 04-27-2011, 04:11 PM   #8
JANNETTYRACING
Fuse pull works on Stock cars.
Old 04-27-2011, 04:13 PM   #9
PQ
Booooosted.
PQ's Avatar
Cool. That's what I figured. I assumed most tuners take the low table off.
Old 04-27-2011, 08:10 PM   #10
Slowhawk
Drives: 1999 Trans Am
I hope not. Good way to wreck a motor.
Slowhawk is offline   Reply With Quote
Old 04-28-2011, 08:18 AM   #11
JANNETTYRACING
ONLY if you modify and or disable the Knock strategy, too many tuners do this and it is dangerous..
And or if you Forcefully run it on 87 octane when it is tuned for 93.
Ted.
Old 04-28-2011, 08:32 AM   #12
IndeedSS1
IndeedSS1's Avatar
Agreed.
That's a safety net. What about the accidental bad gas, or someone unknowingly putting 87 in. On some platforms, MAF sensor failure will default to the low octane table. There's a reason GM doesn't rely on the knock sensors only. If one runs good 93 all of the time, there is no reason to ever worry about the low octane table anyway.
So making the low octance table the same as the high has what benefit under what circumstances?
Old 04-28-2011, 08:48 AM   #13
JANNETTYRACING
Agreed.
Old 04-28-2011, 10:58 AM   #14
PQ
Booooosted.
PQ's Avatar
Agreed.
Ok, so terminology.
My point was a good tuner will set it up so as to not need to pull the fuses.
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 02:41 PM
Fuse pull? Rage 5th Gen Camaro SS LS LT General Discussions 22 06-06-2010 02:08 AM
Something wierd after fuse pull shroomjohn 5th Gen Camaro SS LS LT General Discussions 13 12-15-2009 12:02 AM
FUSE PULL CJ Offshoredude Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 11-26-2009 02:59 PM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 10:10 PM
