Old 05-31-2010, 07:24 PM   #1
Rage
TRI-COUNTY CAMARO... FTW!
Rage's Avatar
Drives: 2010 Camaro 2SS M6 Cyber Grey
Fuse pull?
I just read about a mod called a fuse pull.....Any elaboration?
"The sound is better, but as for the power, I would say most of the gains came from the CAI and fuse pull."
Any info would be great! Thanks
CAI inc. cold air intake, LG G6x3 cam, Patriot Gold Extreme Dual springs, Titanium retainers and locks, LG SuperPro 1 7/8 Long Tube headers with full 3" exhaust, DynoMax VT mufflers, SLP 4" tips, Moroso catch can, Race Ready electronic exhaust cut outs, Full painted Razzi body kit, Headlight Armor Smoke taillight and marker blackouts, T-Rex aluminum upper and lower grille, Polished aluminum front and rear bowties. Professionally installed and Dyno Tuned by HorsePower Sales, Pompano Beach FL.
Rage is offline   Reply With Quote
Old 05-31-2010, 07:27 PM   #2
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Read : http://www.camaro5.com/forums/showthread.php?t=38964
Old 05-31-2010, 07:50 PM   #3
1badtie
1badtie's Avatar
Drives: 2018 Camaro ZL1
will this do anything for an ls3?
1badtie is offline   Reply With Quote
Old 05-31-2010, 07:58 PM   #4
firefighterEMT33
firefighterEMT33's Avatar
Drives: 2010 IBM 2SS/RS
I've done it to mine numerous times and haven't noticed a difference in regards to power. It does seem to run a bit smoother when I first leave the house though in that the herky jerkies it normally has are a little less severe.
IBM 2SS/RS, M6, Polished Wheels, 3M Clear Bra, 27% Windows, CAGS Eliminator, Barton STS
Upcoming Mods: Cold Air Inductions CAI, Kooks 1 7/8" LTH, and 3" Exhaust, Tune.
1100 Order accepted at dealer: 3/15/2010 - NVTZ1X
3300 Scheduled For Production: 3/17/2010 TPW 4/5/2010
3800 Produced: 4/7/2010 2G1FT1EW3A9208281
5000 Delivered To The Dealer: 4/21/2010
6000 Delivered To Customer: 4/23/2010
firefighterEMT33 is offline   Reply With Quote
Old 05-31-2010, 08:02 PM   #5
jordan 572
jordan 572's Avatar
Drives: none
do you have to do the pull or will it eventually adjust on its own? on an ls3 you just disconnect the battery? don't the windows need reprograming?
jordan 572 is offline   Reply With Quote
Old 05-31-2010, 09:16 PM   #6
Camaro2SSLS3
Drives: 2010 Camaro 2SS LS3 6 speed IOM/IOM
Also curious on this question.....
Camaro2SSLS3 is offline   Reply With Quote
Old 06-05-2010, 11:48 AM   #7
Camaro2SSLS3
anybody??
Old 06-05-2010, 11:56 AM   #8
jordan 572
jordan 572's Avatar
Drives: none
anybody?
Old 06-05-2010, 12:06 PM   #9
rharp
rharp's Avatar
Drives: 2010 SVT Raptor/ 70 Chevelle SS 396
The computer will not adjust by itself, just disconnect the battery and let sit over night. As far as reprograming the windows, yes you will have to but it's in the manual and it takes about 30 seconds to do.
rharp is offline   Reply With Quote
Old 06-05-2010, 01:05 PM   #10
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Disconnecting the battery will NOT reset the fuel table to high spark timing. You have to pull the 5 and 20 fuses.
As far as reseting on it's own, yes. It was mainly an early build problem. If you have an early built car, by all means, pull the fuses. Then take it to the dealer and get the updated flash to fix the problem.
See the sticky in the technical section. Long read but worth it. All you need to know is the problem has been adressed. As long as you keep high octane gas in your car, you won't have to worry about it anymore. If you do end up with low octane in your car, run some high grade through it and it should reset. I'll pull my fuses anyway to get an instant reset.
Old 06-05-2010, 01:09 PM   #11
PQ
Booooosted.
PQ's Avatar
Yes. If you disconect the battery you will need to reprogram the windows. Takes all of about 90 seconds.
Old 06-05-2010, 01:12 PM   #12
PQ
Booooosted.
PQ's Avatar
Originally Posted by SlingShot View Post
the link SlingShot referenced here will take you to a lot of info and proof of it working.
I spoke with John Fitspatrick at the fest and verified that it has been taken care of. There should be no further issue with this.
Again: If you have an early build and haven't gotten the updated computer flashes from your dealer, take it in and do it. Just tell them you want all current updates.
Old 06-05-2010, 01:15 PM   #13
greenrail
Comic Curmudgeon
greenrail's Avatar
Drives: 2010 Camaro 2SS-2010 VW CC Sport
I have an early LS3. While, it was always a question as to whther or not this would help, I did the fuse pull anyway. (Especially since my sales guy, put regular gas in before delivery).
I don't do the numbers testing, etc. But it sure seemed to wake my car up.
Member Illinois Camaro Club
His Name is Rosie - "Speak Softly and Carry a Big Stick!" - If you know who said that, then you know the genesis of his name.
greenrail is offline   Reply With Quote
Old 06-05-2010, 01:17 PM   #14
PQ
Booooosted.
PQ's Avatar
If your dealer put low grade fuel in, and yours is an early build, I GAURANTEE it made a difference.
Mine was not necessarily a night and day difference by the 'Butt Dyno' but the numbers didn't lie.
Something wierd after fuse pull shroomjohn 5th Gen Camaro SS LS LT General Discussions 13 12-15-2009 12:02 AM
FUSE PULL CJ Offshoredude Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 11-26-2009 02:59 PM
Fuse pull snap??? fourmz Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-01-2009 09:42 PM
Anyone tried a Fuse Pull on LS3 95RedCamaroz28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 09-12-2009 03:33 PM
