Old 04-27-2011, 03:11 PM   #1
Old Guy
Old Guy's Avatar
Drives: 4 Chevy's in the Driveway
Dumb question....
What's the purpose of filling up tires with Nitrogen? I noticed that on the window sticker of a vert I looked at the other day that the tires were filled with nitrogen. Does anybody besides dealers fill tires with nitrogen? What type of costs are associated with this? Thanks in advance...
01/28/2011 - (1100)
01/28/2011 - (1102)
03/14/2011 - (2000)
03/15/2011 - (2500)
03/16/2011 - (3000)
04/08/2011 - (3100)
04/08/2011 - (3300) TPW 4/18
04/13/2011 - (3400)
04/21/2011 - (3800)
04/21/2011 - (4000)
04/21/2011 - (4150)
04/21/2011 - (4B00)
04/25/2011 - (4200) Shipped
05/01/2011 - (4B00)
05/01/2011 - (4800) Rail ramp unload. Vehicle has been unloaded from train
Old Guy is offline   Reply With Quote
Old 04-27-2011, 03:21 PM   #2
outlaw2
outlaw2's Avatar
Drives: 12 SS/RS Conv, 66 Impala SS Conv
Navy/USMC aircraft tires use nitrogen, The atmosphere is 78% nitrogen 21% oxygen and 1% argon and other gases but for use in a daily street machine I think is a bunch of hot air that costs $$$ not like your coming in for a landing at 100+ mph. Question? Do the dealers really have a nitrogen cart in the bay just for tires or are they using an air compressor and charging nitrogen prices?
outlaw2 is offline   Reply With Quote
Old 04-27-2011, 03:33 PM   #3
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
In theory, the variation in pressure caused by changes in temperature is slightly more predictable with pure gas than a mix of 78%N, 21%O, and .93%Ar.
The real reason is that depending on all kinds of meteorological factors, water vapor can make up anywhere from 0 to 4% of the atmosphere. (The above percentages are for "dry" air). If you just use compressed air, water vapor in the air will cause condensation inside your tires anytime the temperature inside your tires falls below what the dew point temperature was when they were filled.
It's really just a minor issue with street cars, but something small like that can have an effect where more precision is needed, like on race cars, or aircraft, etc....I just use an air compressor, but try to only add air on days with lower relative humidity.
2022 1SS 1LE (Arrived 4/29/22)
"The car is the closest thing we will ever create to something that is alive."
. 2022 1SS 1LE (Coming Soon)
fielderLS3 is offline   Reply With Quote
Old 04-27-2011, 07:07 PM   #4
OrangeVert
"Catharine"
OrangeVert's Avatar
Drives: '11 2SS/RS LS-3 IOM/IO vert
Nitrogen fill was free with my new tires at Costco on my Toyota pickup a few years back. They used green valve stem covers to indicate they were filled with nitrogen instead of air.
OrangeVert is offline   Reply With Quote
Old 04-27-2011, 09:52 PM   #5
FirstandFifthGen
FirstandFifthGen's Avatar
Drives: 68 Camaro, 48 Chevy truck, 36 Chevy
Nitrogen pressures won't vary as much with temperature changes as air, and it's molecules are larger and thus will not tend to leak as easily over time.
2011 2SS/RS IOM convertible
FirstandFifthGen is offline   Reply With Quote
Old 04-27-2011, 11:42 PM   #6
Sttt5126
Sttt5126's Avatar
Drives: 2011 2SS/RS Vert
I have nitrogen in all of my vehicles tires...cadillac srx and gmc sierra.
Sttt5126 is offline   Reply With Quote
Old 04-28-2011, 04:28 AM   #7
wilmaya
wilmaya's Avatar
Drives: 1970 Chevelle SS396/496
That's my understanding.
wilmaya is offline   Reply With Quote
Old 07-21-2011, 02:09 AM   #8
Btmonty2
Btmonty2's Avatar
Drives: 2011 2SS/RS white with IO vert
you also get better gas milage. I have a V8 and I'm currently getting around 18.5 city mpg...I have gone on a long trip yet
Btmonty2 is offline   Reply With Quote
Old 07-21-2011, 02:28 AM   #9
CruznSS
CruznSS's Avatar
Drives: 2SS/RS Camaro ABM - Silver Ralleys
Dealership charges $59 to replace air with nitrogen. Might not tell a difference. It will extend life of tire if your the type that forgets to check tire pressures. The dealership will check & refill for free as needed.
Sent from my PC36100 using Tapatalk
CruznSS is offline   Reply With Quote
Old 07-21-2011, 02:38 AM   #10
Btmonty2
Btmonty2's Avatar
mine cost 40 bucks,,,, and they will refill for life of my car....even when I get new tires
Old 07-21-2011, 10:07 AM   #11
Dr_Doom
Dr_Doom's Avatar
Drives: 2011 2SS/RS Convertible
I run Goodyears on my truck and at my last tire rotation, I asked the Goodyear people about nitrogen and he told me that unless the tire was designed and tested to run with nitrogen, that I shouldn't use it. He said it could cause uneven tire wear because some of the materials in certain model tires shrink and expand in varying temperatures and it was made and designed to react with how air volume responded with temperature swings.
I dont know if that was a sales pitch or not, but the answer he gave when telling it seemed to me like he had been well informed (whether its factual or not) priorly about the subject and I didnt get the impression he was making it up on the spot.
Dr_Doom is offline   Reply With Quote
Old 07-21-2011, 06:36 PM   #12
Keith.M
Keith.M's Avatar
Drives: '11 2SS/RS Vert, w/Hurst shifter
I think it's mostly about the molecule size of Nitrogen, in that you'll not experience the gradual loss of air pressure over time that is typical of radial tires now. Whatever gas you put in your tire, will be subjected to the effects of temperature change, whether the heat of driving or just sitting exposed to the high temps of a summer day on an asphalt surface. Not sure it's worth much of a premium expense, since the car has pressure monitoring, unless you don't have an easy method to inflate. Remember, you've no spare, so keep the 4 on the road properly inflated.....
Keith.M is offline   Reply With Quote
Really Dumb newbie USB memory stick question whippetrun Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 7 04-08-2011 07:48 AM
If this is a dumb question I apologize kdlove 5th Gen Camaro SS LS LT General Discussions 17 03-01-2011 09:01 AM
Dumb question but... 8ty8 ls1 Wheels and Tires Talk Sponsored by The Tire Rack 6 11-24-2009 03:02 PM
probably a dumb question shad2009 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 6 10-04-2009 12:29 PM
Dumb License Plate Question MightyT USA - California 6 09-27-2009 09:24 PM
