![]() Drives: 2011 Black 1LT RS Join Date: May 2010
What is YOUR LLT operating temp?
I'm curious to collect info on what temps our cars are running and what effect ambient temp may have on that.
Let's list the following and I'll compile a spreadsheet and see if there's any pattern. Average coolant temp: Low "warm" temp: High Temp: Ambient temp during monitoring: Here's mine for yesterday: Avg: 205* Low: 203* High: 207* Ambient: 68* (Note:199* is when the cold start idle drops. after that, I rarely see anything below 203, with frequent trips to 207 in stoplight traffic.) Earlier this week: Avg: 205* Low: 204* High:207* Ambient: 85* (Note: Fans kicked on A LOT! Almost every stop had the fan start.)
Midnight => 2011 1LT/RS, A6, Roto-Fab CAI & W/W Relocate, MPD Hood, 25%/18% Carbon Tint
See my build journal here. |
I have no life
Drives: 06' Subaru STI, ex-Camaro V6 LLT Join Date: Apr 2010
Interesting! I wanted to know as well. I thought I had a broken car!
Today: April 29, 2011 58 Ambient temp. Lows: 197 High: 204
![]() ![]() ![]() ![]() Drives: 2019 Chevy Equinox Premier AWD Join Date: Mar 2011
My car has gotten as high as 214 in 70+ degree ambient idling in traffic. Low is like 200-201.
Track > 1/4 Mile
I haven't looked at it real close but it's usually low 205ish. I'll keep an eye out for it though.
![]() ![]() ![]() ![]() ![]() Drives: 2011 LS Join Date: Oct 2010
I don't stay in High traffic, but when I am running I am around 200 and at idle at a light it goes to approx 209
#6 |
Drives: 2010 Camaro 2SS/RS 6MT Join Date: Apr 2010
Cruising on the highway or local roads without long stops = 194-199 degrees
Idle for extended periods of time (15 mins or more) = has gotten up to 224 degrees City stop and go driving = 199-204 |
#7 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
All of the temps you guys have posted are right.Mine is the same 199-205. When at the Fest in 95 degrees, and in the desert where it got to 102 doing 85 mph the hottest with the air on was 205. IMO, G.M. tuned the cars as they did the LS engines, and since the LLT is also aluminum, the best water temps for max power for these is 195-205 degrees, and all tuners set temps right in that range.
So dont worry, all is good. |
#8 |
Drives: jealous vendors mad!! HAHA!! Join Date: Jan 2011
200 on avg
#9 |
![]() Drives: 2012 2SS/RS M6 AGM Join Date: Jan 2011
199 to 201
Ashen Gray Metallic w/factory Hurst shifter
Previous: 2011 2LT/RS M6 |
#10 |
| LS3 Engine Operating Temp | Jeff5886 | 5th Gen Camaro SS LS LT General Discussions | 9 | 12-10-2010 05:38 PM |
| LS3 standard operating Temp | thewebb | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 8 | 11-18-2010 11:17 AM |
| Wow, LLT & low temp air | h2oplay | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 11 | 11-15-2010 03:11 PM |
| LLT engine specifications | Tran | Wiki | 2 | 03-29-2010 11:06 AM |
| Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 10:03 PM |
