Old 05-05-2011, 12:27 AM   #1
Tshepp
Show & Go
Tshepp's Avatar
Drives: '10 Camaro 1SS LS3
Oracle HOD Input Needed (solution to yellow halogen)
So I really need to get rid of these super ugly stock halogen bulbs. I cannot stand the yellow tint compared to by LED fog bulbs. What does everyone think about the Oracle HOD as a solution? Is it brighter than the factory halogen bulb? I was thinking about doing a drop in HID kit but I don't want to drop $200 on a kit. I have used Xentech brand in the past and had issues with ballasts so I don't want to do that again. I am really just looking for opinions from fellow non-RS owners...Thanks!!
Tshepp is offline   Reply With Quote
Old 05-05-2011, 12:34 AM   #2
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
I have the HOD bulbs from AAC... they are brighter, and I have a thread with pics posted... try a search, it was quite awhile ago.
FL1CK is offline   Reply With Quote
Old 05-05-2011, 12:35 AM   #3
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
HOD and LED on the left, Halogen bulbs in the Right.
MagnumForceGB is offline   Reply With Quote
Old 05-05-2011, 07:16 AM   #4
Rob191288
Rob191288's Avatar
Drives: 2010 Camaro LS
The HOD bulbs are nice I have them as well. But I had them installed for 4 months and one side went out.
Rob191288 is offline   Reply With Quote
Old 05-05-2011, 09:23 AM   #5
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Same here. I just put the factory halogens back in until I figure out a better solution...
Old 05-05-2011, 10:13 AM   #6
P-ROD
Drives: 2011 Camaro V6
I also have them, but did have some issues with them. When I received them one of the bulbs did not work and one of the wiring harness that they sent me was loose, I had to send them back to get a replacement on both (paid shipping, again). I got the replacements, and the bulb worked this time, but not the wiring harness, so I decided to fix it myself this time to avoid having to pay shipping again. They do look brighter than halogen, but I do not know how long they will last. I will probably just going to go with silverstar bulbs next time, not as bright but more reliable.
P-ROD is offline   Reply With Quote
Old 05-05-2011, 11:02 AM   #7
caverman
caverman's Avatar
Drives: '69 SS Convertible
Another thing you might be able to do is to add the plug-n-play harness to get rid of the DRL. That might make the life of the bulb go longer.
However, if the HID kit is too much money you probably won't want to spend $125 on a harness to get rid of the DRL.
Build Journal
Old 05-05-2011, 06:03 PM   #8
Tshepp
Show & Go
Tshepp's Avatar
So for the money would you say they are worth it? (minus the issues) I feel that I will have more problems using an aftermarket HID kit than using the HOD bulbs even though the HIDs will be brighter...
Where is the harness available? I usually turn off my auto lights when I get in my car anyway...
Old 05-06-2011, 09:06 AM   #9
clg_98ta
clg_98ta's Avatar
In my case, the bulbs were fine. They'll come on after I jiggle the wires, but go off again (not completely off, just very dim) shortly thereafter.
When I took one apart, the white ceramic in the connector was brown and crispy. Since I perceive this as a design problem, I didn't bother getting replacements.
I might try the silverstars. I'll probably eventually upgrade to OEM HIDs, but I want to make sure all the bugs are out of the Non-RS adapter harness...
Old 05-06-2011, 12:51 PM   #10
Tshepp
Show & Go
Tshepp's Avatar
Hmm...now I kinda leaning towards an HID kit....uggghhh
Old 05-06-2011, 07:48 PM   #11
tjudah87
tjudah87's Avatar
Drives: 16 Camaro 1LT SIM
Try 2 days and one of the harnesses was loose.
Every day confirms my opinion on the superiority of a vicious life -- and if Virtue is not its own reward I don't know any other stipend annexed to it.
tjudah87 is offline   Reply With Quote
Old 05-07-2011, 09:51 AM   #12
Tshepp
Show & Go
Tshepp's Avatar
If I do decide to grab the HIDs what brands have you guys seen that work best? I hear Morimoto AND DDM throw around often...
2 in 2 out or pair of glass packs? Exhaust input needed Macrackie Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 9 04-26-2011 10:14 AM
Input Needed: TR6060 in 4th gen Fbody ATX LSX V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 04-24-2011 08:14 PM
Quick Input Needed Scott@Bjorn3D 5th Gen Camaro SS LS LT General Discussions 17 02-10-2011 03:56 PM
