Old 04-21-2011, 06:12 PM   #1
ATX LSX
ATX LSX's Avatar
Drives: '01 WS6
Arrow Input Needed: TR6060 in 4th gen Fbody
I'm picking up a TR6060 from a '10 SS this weekend for my twin turbo project, and wanted to see if some of you all could help me with some questions.
- It apparently does not have a slip on style yoke; has anyone been able to convert these transmissions to a slip on yoke? If so, what is needed for the conversion?
- Is the tailshaft interchangable with a T56 tailshaft?
- Is there any problems with these trannys I should know about before I dive into all the work involved in putting this tranny in a 4th gen? How much power do they usually hold before something gives?
Thanks for your time.
2014 Red Rock Metallic 1SS | K&N Cold Air | CXRacing Coilovers| Z28 Spoiler
ATX LSX is offline   Reply With Quote
Old 04-21-2011, 06:19 PM   #2
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
The tail shaft is not interchangeable, what most have been doing is buying our billet
plate and then we make a CV Driveshaft like the one we make for the 2010 Camaro
if you want some real advice i would call Tj at RPM Trans
shaft looks like this
Driveshaftshop is offline   Reply With Quote
Old 04-21-2011, 08:06 PM   #3
ATX LSX
ATX LSX's Avatar
Drives: '01 WS6
Thanks for the reply. How much is a setup like that going to cost? And what are those driveshafts rated to? I am planning on making 1000whp+.
Old 04-24-2011, 01:38 PM   #4
Rick@RKT56
Rick@RKT56's Avatar
Drives: Corvette
It would be a lot less work to convert a T56 Magnum (TR6060) to fit your application. RPM Transmissions does make a drop in conversion where they replaced the tailshaft housing to the older T56 housing machined to accept the bigger output shaft and has the slip yoke. I have been looking into this conversion but haven't pulled the trigger yet.
Rick@RKT56 is offline   Reply With Quote
Old 04-24-2011, 08:14 PM   #5
Steve1968LS2
Drives: 1968 LS2 powered - Bad Penny
To be honest it's less work to just buy a T56 Magnum and call it a day.
Besides messing with the yoke you'll also have to fight the shifter linkage and a few other hassles. The Magnum is almost a direct swap and has the same internals as the 6060.
Tech Editor for Camaro Performers Magazine
1968 Camaro - 461 RHS LS 700hp, various stuff, called Bad Penny
1968 Camaro - In progress, called Track Rat
2010 Camaro - DSE Suspension, Baer 6S Brakes, Boze Wheels, Nitto NT05 Tires, JBA Exhaust and long tubes, Magnacharger TVS, 660rwhp Forged Eagle 416 LS3 short block, ADM fuel system, Lingenfelter GT-9 cam, G-Force axles, Anvil and Seibon CF parts, Centerforce Dual-Disc Clutch
www.fquick.com/steve1968ls2
Steve1968LS2 is offline   Reply With Quote
4th Annual GM Performance Parts LSX Shootout!! nmcajeff Dragstrip and Launch Techniques Discussion 3 07-30-2010 01:05 PM
So I thought I'd get a 4th gen...any advice? Emher 4th Generation Camaros 19 07-11-2010 06:43 PM
4th Gen, an acquired taste? 5thGenOwner 4th Generation Camaros 82 05-14-2010 05:14 PM
5th gen ?s in relation to a 4th gen ws6jim 5th Gen Camaro SS LS LT General Discussions 1 03-27-2010 12:43 AM
