Old 05-06-2011, 02:59 PM   #1
tom692010
Drives: 4 wheels
Trailing arms
Anyone start to have a clicking noise once they installed trailing arms? Comes from both sides. Dealer replaced the drive shaft and claim to have put the spacers in the hub but it's still there if not a little worse. I'm brining it back to them but I'm afraid once they see the trailing arms that they will say it's that. They blamed the clicking on my exhaust system when I installed cutouts last summer. I had to bring in the TSB to show them it wasn't the cutouts...
tom692010 is offline   Reply With Quote
Old 05-06-2011, 03:14 PM   #2
Synner
Drives: cars
If they're tight there's nothing to click or move around.
Old 05-06-2011, 05:09 PM   #3
tom692010
Drives: 4 wheels
They were installed and torqued correctly.
Old 05-06-2011, 05:12 PM   #4
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
You might check this thread out. Could be this.
http://www.camaro5.com/forums/showthread.php?t=136330
Old 05-06-2011, 07:24 PM   #5
tom692010
Drives: 4 wheels
whew just went out and checked, not it thankfully thanks.
Old 05-06-2011, 07:28 PM   #6
StreetStrip
Tyranny is Closing In
Drives: 2010 Camaro SS
I had that issue after mine were installed, it turned out to be the emergency brake cable rubbing against wheels weights on the inside drum of my wheel. Check to make sure the emergency brake cable is clamped into its retaining clip (both sides).
StreetStrip is offline   Reply With Quote
Old 05-06-2011, 07:46 PM   #7
Beescuz
Beescuz's Avatar
Drives: 2021 ZL1 1LE
I had Pfadt trailing arms installed and no noise.
Beescuz is offline   Reply With Quote
Pfadt Race Engineering Rear Trailing Arms At Apex Motorsports!!! Apex Motorsports Suspension / Chassis / Brakes 174 08-09-2012 05:43 AM
BMR Rear Trailing Arms, Tie Rods, Bushings, and More! | FREE Shipping!! AJ@ECSMotorsports Suspension / Chassis / Brakes 19 11-13-2010 03:55 PM
LMPerformance, Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Polyurethane Bushing LMPerformance V8 Bolt-Ons & Tunes 3 10-19-2009 03:33 PM
LM Performance, Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Spherical Rod Ends LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 01:59 PM
LM Performance, Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Del-Sphere Pivot Join LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 01:34 PM
