Old 03-21-2011, 11:20 PM   #1
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Has anyone broke one of these yet? (Rear Lower Control Arm Endlink Tab)
I was under the car the other day and decided to inspect the entire underneath. Well, I found this broken braket peice that is basically the control arm. It is the peice welded onto the control arm that the end links to the sway bar connects to.
Pete, at Pedders, has gracefully offered me one he's had at the shop from early testing. So I didn't have to go buy one but I'm curious if anyone else has had a problem with this piece.
As you can see, the end link tore through the braket. Also pictured is the other side that seems to be good.
There is a split in the other side braket and I don't know if it's a crack or is it supposed to be that way?
Anyway, any feedback would be cool.
UPDATE: Repaired........
Ok, last night I replaced the LCA and puet Pedders end links and sub-frame bushing inserts on the car. I'll do the CA bushings today.
As you can see, it’s NOT a good idea to break one of these. The end link was completely outside of the LCA and had separated the whole ball joint.
Here you can see material from the LCA bracket between the end link nut.
Another pic of the damage from the top. Is it my imagination, or does the new arm bracket look a tad thicker?
More damage. You can clearly see how it broke through.
The ball broke clean from the assembly. Lol
No doubt this is tight. LMAO, I torque this with my body weight pretty much.
Here you can see where my old end link had come lose before and I moved it to the inside. (stiffest) And yes I moved the other side then as well. Lol
I attached the Pedders end link before I installed the LCA.
My professional work area.
I set the end links to the shortest setting possible. The set nuts could be tighter but I did the best I could. They like to separate on the other one when tightening the first one.
As it turns out, when the finish is worn away, there IS a joint here. Can’t imagine why but I confirmed it on both arms. The coating disguises it but it’s definitely there. THIS IS NOT A CRACK. It’s an absolutely PERFECT joint. WAY to perfectly straight and true to be a crack.
Pedders most definitely more ‘Robust’ as Pete put it.
Ok, so inspect my work………. Lol
Front sub-frame insert.
Rear sub-frame insert. See that pin at the top? That was a BITCH to get to go back right. The struts were not wanting to align with the LCAs and the front cradle joint was up so I had to wedge something between them to hold it down to balance it backward and zip tie the struts to a position in the LCAs to get them to guide in place………… OMG, that was a pain.
Nother Update:
Second arm is failing......
Old 03-21-2011, 11:32 PM   #2
Indpowr
Drives: Corvette C6
PQ + Bonnie on the hood = split in the other side braket
Just saying...
Old 03-21-2011, 11:33 PM   #3
PQ
Booooosted.
PQ's Avatar
Just saying...
It's a rear braket......... LMAO
Which would actually make more sense.
Old 03-22-2011, 12:44 AM   #4
Camaro21
Drives: SOLD - 2013 M6 ZL1
I will have to look at mine, but I haven't noticed anything like that before....
Camaro21 is offline   Reply With Quote
Old 03-22-2011, 12:48 AM   #5
Silver2SSRS6spd
Prefer to be blown!
Silver2SSRS6spd's Avatar
Drives: 2010 Silver/Black 2SS/RS Manual
Wow, that is not good. I'm putting my car on jack stands tonight for some other mods and will be checking mine out to make sure the same hasn't happened to my car.
MagnaCharger TVS-2300 550rwhp 540 rwt and a radical suspension under the car.
Silver2SSRS6spd is offline   Reply With Quote
Old 03-22-2011, 01:04 AM   #6
LightningSS
Drives: WAS '10 SS IBM, NOW '14 BRM ZL1
That's a pretty poorly designed bracket from a strength and loading stand point. The amount of material on the upper side vs the diameter of the fitting is way too small. I'm willing to bet other people will find this broken too.
When load is applied to the rod it will twist the fastener in the hole. Since this is a suspension part it obviously sees many many loadings and unloadings everyday (every time you drive it actually). You can clearly see how repeated loading made the hole oblong shaped until the fitting pulled out.
When I changed out my sway bars my first thought was this style of rod should have a forked end instead of the single-sided end.... Now you can see why.
LightningSS is offline   Reply With Quote
Old 03-22-2011, 01:48 AM   #7
LightningSS
Son of a b!!!
I just went out to look and mine, and look at what I find on the driver's side:
The nut is gone, but bolt undamaged it seems. The passenger side nut was loose, I could turn it with my fingers....
I hated these tierods the moment I installed my sway bars. To torque the nut you have to use a hex key to hold the bolt or the fitting just spins. Which is ok, but apparently I didn't do a good job.
I can't believe I didn't feel the problem, but it is winter around here and I haven't been ripping around much...
This is my fault for not checking the instl after a time, but those lower fittings are still a crap design (but mine look ok for now).
If anybody makes tierods with forked ends let me know I'll be the first in line... Time for a locking nut or some safety wire too.
Old 03-22-2011, 01:56 AM   #8
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
wow are you guys serious?!
Pq, did the pfadts cause it or no? Not sure if you would know or not but im just trying to figure out whether I should do drop springs or not because of a poorly designed piece that will or may eventually fail
CAMARO
Old 03-22-2011, 04:59 AM   #9
MIQ
A Dichotomy
MIQ's Avatar
Drives: 2011 Camaro 1LT
I'll be installing my rear springs today and will inspect them. I only have 500 miles on it right now so I don't expect to see anything wrong. Or will I? :(
2011 Camaro 1LT Auto
Inferno Orange Metallic
Mods--Magnaflow Axle Back, Eibach Pro-Kit, RX Catch Can
MIQ is offline   Reply With Quote
Old 03-22-2011, 11:11 AM   #10
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
Well that sucks.
I would chalk that up to a rare and unusual production failure. I have not seen that yet, and I wouldn't consider that to be the norm by any stretch.
Regards
IPS Brandon is offline   Reply With Quote
Old 03-22-2011, 11:12 AM   #11
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
PQ doesn't have the Pfadt end links. He has the Pfadt springs and sways. His end links are stock.
I have the Pfadt end links (with springs and sways) on mine and I don't seem to have this problem... right Brandon?
Old 03-22-2011, 11:20 AM   #12
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
I have run the Pfadt bars on stock links with no problem for 5000mi before deciding to switch to their links (still no problems).
I hate to say it, but in looking at the pics, I see rust around the mounting holes which usually indicates they were run "loose" and that will chew sh1t up real quick!
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 03-22-2011, 11:21 AM   #13
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Hey PQ, are your springs binding? I was looking at the first photo and noticed the ring of rust on the coils like the paint had been worn off by rubbing on each other. Just something you may want to consider. Good Luck.
Old 03-22-2011, 11:24 AM   #14
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Yeah those springs do not look good at all. Something is very wrong.
Scott@Bjorn3D is offline   Reply With Quote
Now i broke the rear drive shaft bolts and alot of damage. Vinnysrt8 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 93 09-20-2019 11:23 AM
Broke Something - Help Identify smaegley V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 44 02-08-2011 06:03 PM
Headlamp Broke phenixdragon Cosmetics and Lighting Modification Discussions 1 12-10-2010 10:35 PM
Stock Gears Broke NickeyStage2 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 21 09-14-2010 05:11 PM
2010 Camaro 2SS Needs Repair Bumleb 5th Gen Camaro SS LS LT General Discussions 164 04-27-2009 11:09 PM
