Thread Killer
Never use quick connect wire splicers [tach kits]
Never use quick connect wire splicers.
Thank God for TomP over a TGO who over many many years has fill in those important blanks. He posted a tip about those quick connect wire splicers that come with most Tach's and that his coil wire got cut clean through after time. Low and behold my 50 and under runs great, dies over 70 n gets all pissed off mystery problem was due to that I only have 4 wire stran's left, all the rest were cut / broken. Had put it away last July not running. Fix that wire today and the first try it start up and purred like a kitten.
2013 5th Gen Firebird on order.
86 Pontiac Firebird [a work in progress] [68 Firebird hoodscoops, custom notchback[1-3 built]rear mounted tach, inverted wing] http://www.thirdgen.org/techboard/v6...-all-over.html ![]() ---------------------------------------------- "In certain extreme situations, the law is inadequate. In order to shame its inadequacy, it is necessary to act outside the law. To pursue... natural justice. This is not vengeance. Revenge is not a valid motive, it's an emotional response. No, not vengeance. Punishment." |
![]() Drives: Rally Yellow 2SS 2010 Join Date: Mar 2009
Totally agree!! C R A P!
![]() Drives: '90 RS 427ci LS-1, '86 IROC 305 TPI Join Date: Apr 2011
Those are often called "Scotch-locks". They suck! If you must use a "Tap" style connector, use 3M "T-taps". Much better and the choice of professionals.
I recognize your 'bird from TGO! |
| DIY Raptor Dual Stage Shift Light. | ThunderSS | Camaro DIY & HOW-TO instructions & discussions | 47 | 05-27-2019 09:48 AM |
| 2010-11 Camaro ACC LED Side Marker Mods for Turn Signals | GearHeadPeter | Cosmetics and Lighting Modification Discussions | 44 | 03-13-2015 03:25 AM |
| How To Wire Dual Halos On Single Switch | kismyss | Camaro DIY & HOW-TO instructions & discussions | 54 | 05-06-2014 12:18 PM |
| Installed subs in my 1Lt without the boston acoustics package | Iomcamaro | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 9 | 03-25-2010 09:04 PM |
| DIY: Here it is Dashboard ambient lighting ABL | Tecca | Camaro DIY & HOW-TO instructions & discussions | 356 | 09-03-2009 11:46 AM |
