Old 05-13-2011, 09:51 PM   #1
jgentry
jgentry's Avatar
Drives: 2011 Camaro 2SS/RS CGM
Engine break-in question
The manual says to not drive long periods of time at the same speed. I have about 800 miles on my camaro (SS) and need to drive about 100 miles one way (returning later in the evening) tomorrow. Most of the drive is 65 mph. I was planning on setting the cruise and enjoying the drive. Will this cause any damage?
jgentry is offline   Reply With Quote
Old 05-13-2011, 09:54 PM   #2
1BADLS3
1BADLS3's Avatar
Drives: Sold: 2011 2SS/RS
It won't cause damage, but won't provide optimal conditions to continue seating the rings. I wouldn't set the cruise, but rather drive with the flow of traffic which usually has an ebb and flow. Mix up your speed a little bit and you'll be fine.
I can't remember the break-in period, but isn't it 500 miles? Or is it 1000?
1BADLS3 is offline   Reply With Quote
Old 05-13-2011, 10:00 PM   #3
jgentry
jgentry's Avatar
The highway I'm driving has very little traffic but I'll see what I can do. Break-in is around 1500 I think.
Old 05-13-2011, 10:04 PM   #4
1BADLS3
1BADLS3's Avatar
No worries either way. I've broken in cars by flogging the ever-living **** out of them, and also by babying them for the recommended period. Neither of those methods seem to have a noticeable difference on performance or longevity.
What I mean by mixing up your speed is, cruise a few miles under, then do the speed limit, maybe a few over if you're daring, then a few under. Keep yourself and the car entertained. But in the long run it shouldn't really matter unless you're obsessed with following the recommended procedure by the book's standards.
Old 05-13-2011, 10:10 PM   #5
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
Don't cruise, as has been said, but just switch up gears to vary speed. That way you maintain speed but vary load on the motor, which is what the break-in needs.
No worries.
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 05-13-2011, 10:34 PM   #6
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
You want to vary your RPMs, don't hold at a constant level for extended periods of time. Manual or Auto? Either or, vary your speed and change gears to avoid being in an RPM range for too long. Absolutely no cruise control. Have a little fun, but don't redline it.
Dizzy82 is offline   Reply With Quote
Old 05-13-2011, 10:36 PM   #7
jgentry
jgentry's Avatar
Manual. I've been keeping it under 4000 rpm anyway.
Old 05-14-2011, 01:31 AM   #8
rberns
rberns's Avatar
only 1500 mile for a break in? i was thinking it would be like 3 to 4 thousdand. Once I get back home and get my car, I am taking a trip to be in a parade with my camaro and my dads challenger. It's a 200 mile round trip plus the small parade, so I am wondering how this will work with my break in time.
rberns is offline   Reply With Quote
Old 05-14-2011, 07:56 AM   #9
evan
ready...
evan's Avatar
Drives: 2010 Camaro 2SS/RS
http://www.mototuneusa.com/break_in_secrets.htm is what tips I used to break in. My camaro ran better every day.
evan is offline   Reply With Quote
Old 05-14-2011, 08:50 AM   #10
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Please don't take this as sarcasm - just drive the car and enjoy the nice trip. I love taking mine for long road trips. Very nice cruising car. If your right foot gets a little tired - use the cruise control thats what it for. Use it - just don't set it a 65 and leave it for 10 - 15 minutes constant. Use the steering wheel button to bump the speed up and down a few MPH while in cruise mode if you'd like.
Bottom line - modern engines are engineered to pretty tough standards and tolerances - including the LS3. Its not fragile and it won't seize up if you shift at overr 4K on the occasion or leave it at a certain PRPM for a little while.
Now go and drive that 100 miles with a smile - it'll be fun
SSDan is offline   Reply With Quote
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 08:26 PM
Pfadt Engine Mounts installed, first and second impressions... robertway Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 03-03-2010 09:35 AM
Transmission output shaft hiller72 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 267 12-02-2009 08:39 PM
Why i think you cant do a Dyno in the same day 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 123 10-22-2009 07:37 PM
Engine Cover Question ShAgMaN 5th Gen Camaro SS LS LT General Discussions 10 07-10-2009 05:25 PM
