![]() Drives: 2011 Camaro SS Join Date: Mar 2011
2011 SS Tire relearn TPMS
So, I was inflating my tires and the manual was in the house. The info didnt seem to be changing as I was airing them up. Not trusting my tire gauge to be accurate enough I pushed "relearn" thinking it would check the pressure. It reset all my pressures to 32psi on the display.
I searched this and there is supposed to be a method on page 9-60 but the page 9-60 in the 2011 manual is about trailer brakes. I cant find it anywhere. Any help would be appreciated. |
Drives: 2010 SS Join Date: Apr 2011
Mine are all messed up on my 2010...
in the display my rear right tire is actually taking information on my left and vice versa lol. |
I believe once you press relearn you are supposed to let the air (1psi) out at each tire starting at front driver then moving back and around. The car beeps once it recognizes the sensor and signals you to move to the next tire.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
Booooosted.
Doesn't make sense.
Relearn sets it to realearn mode. Where you'd start with the front passenger side and work your way to the rear passenger, rear driver, and finally the front driver side, each wheel you let air out unitl it beeps moving on to the next and finally it beeps twice. Then turn the car off and inflate the tires and drive it. They all set to 32? I don't get it. |
I have done this before when I put my winter tires on. Once you press relearn, you have to either deflate or inflate the tires, one by one, until the horn sounds for each tire and twice at the end. You start with the front driver, move to the front passenger, rear passenger, and rear driver. I would suggest deflating them as to not over-inflate, then once they are all learned, go around and inflate each tire. The dic should update after this process has been completed and you should be able to see each reading live.
Again, it is in the 2010 manual, 9-62. 10-62 in the 2011 Hope this helps Last edited by djb525; 05-18-2011 at 12:47 AM. |
#6 |
Yeah, they were 33psi right front, 32 left front, 38 right rear, 37 left rear. I hit relearn, the car honked twice and all tires said 32psi
#7 |
So what happened was the car went into learn mode and forgot all the sensors.
It probably would have beeped a couple more times in 2 minutes if none of the tire pressures changed. You will probably have to relearn... |
#8 |
Booooosted.
Weird. The sensors read air pressure. You got them to read it differently?
#9 | |
From the owners manual
#10 |
Also, very useful to have in digital form so you can just search...
2010: http://www.chevrolet.com/assets/pdf/...aro_owners.pdf 2011: http://www.chevrolet.com/assets/pdf/...aro_owners.pdf |
#11 |
Booooosted.
Wait. I always started with the front passenger.
![]() And I know it read the possition right becasue I still have a slow leak in the front passenger so I add air and it reads correctly. WTF? And why did the OPs pressure all set to an improper number? |
#12 |
I got one for ya. I never did this by the manual. I used my pressure gauge and filled the tires accordingly. Then i pressed the relearn and the horn beeped twice. After approx. a minute or so the DIC read the new pressure of the tires.
Now i have a '10 SS if that makes a difference? |
#13 | |
Booooosted.
I suppose I could maaaaaaaybe be mistaken but I've had to reset my sensors about 5 times now. I'm a little freaked out. BUT, I do know the sensors, like a tire gauge, already read tire pressure. You just match the sensor up to the tire possitions when you pair them. You can't change the pressure they read.
#14 | ||
| Camaro SS Spare Tire Options For Those Who Don't Know | LYCAN | Wheels and Tires Talk Sponsored by The Tire Rack | 68 | 07-13-2021 11:31 AM |
| gm tpms reset tools cheap | camaro1 | Wheels and Tires Talk Sponsored by The Tire Rack | 13 | 11-24-2017 03:32 PM |
| 2011 Camaro SS LS3 vs 2010 Camaro SS L99 exhaust | erk5000 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2 | 03-13-2011 06:54 PM |
| Winding Road's 2011 Chevrolet Camaro Convertible SS Review | Tran | Camaro Convertible Forum | 25 | 02-20-2011 05:32 PM |
| Do you want the Z28? | ChrisB | Camaro ZL1 Forum - ZL1 Specific Topics | 1616 | 09-05-2010 12:49 AM |
