Old 05-18-2011, 01:19 AM   #1
Maro99
Maro99's Avatar
Drives: Heel toe express..
Question Need help.. What is the thickness difference between V6 brakes and V8 brembos?
Long story short I bought some wheels that would not clear my brembos in the rear. I had to space them out so far that I had to get longer studs (thats another whole issue) the rear tires are also sticking out further than the rear quarters which I have grown to dislike. So im thinking of just downgrading to v6 brakes so I wont need spacers at all or at least wont need such big spacers. I know certain wheels that wont clear the brembos will clear the v6 brakes.. So my question is how much clearance would I gain by downgrading to a v6 brake setup? Any help/info is appreciated.
Thanks
Camaro SOLD :(
Maro99 is offline   Reply With Quote
Old 05-18-2011, 02:19 AM   #2
Tbanks
The Stangs kryptonite
Tbanks's Avatar
Drives: 2010 1LT CGM Camaro
hey let me know if you get rid of your brembros ill trade you my v6 brakes and throw in some cash
TBANKS
Tbanks is offline   Reply With Quote
Old 05-18-2011, 07:38 AM   #3
garcmol
garcmol's Avatar
These are the specs from the Wiki page. Hope that helps!
2010 LS/LT OEM Brakes:
ABS
ventilated front and rear rotors
single piston front calipers / single piston alloy rear calipers
Rotor diameter (front) (in / mm): 12.64 / 321
Rotor diameter (rear) (in / mm): 12.4 / 315
Rotor thickness (front) (in / mm): 1.18 / 30
Rotor thickness (rear) (in / mm): 0.9 / 23
2010 SS OEM Brakes:
ABS
four piston fixed Brembo aluminum front and rear calipers
Rotor diameter (front) (in / mm): 14 / 355
Rotor diameter (rear) (in / mm): 14.4 / 365 / 315
Rotor thickness (front) (in / mm): 1.26 / 32
Rotor thickness (rear) (in / mm): 1.1 / 28
Old 05-18-2011, 12:27 PM   #4
Maro99
Maro99's Avatar
Will do, you will be the first I talk to if I decide to get rid of them.
ABS
2010 SS OEM Brakes:
ABS
Thanks for the info but it dosent say the thickness of the calipers on that list. Im hoping that someone that switched to a v6 brake setup for drag can tell me how much clearance they gained.
Thanks
Camaro SOLD :(
Old 05-18-2011, 12:53 PM   #5
Tbanks
Tbanks's Avatar
Thanks hope someone on here can help answer your questions
TBANKS
Old 05-19-2011, 01:59 AM   #6
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
Thanks
My question is WHY? would you want to downgrade to V6 brakes?
Just send back the rear wheels and get the right offset. Much cheaper to exchange the wheels than to completely change the brakes.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 05-19-2011, 11:26 AM   #7
Maro99
Maro99's Avatar
I cant send the rear wheels back because they were bought used.. They are iforged 3 piece wheels with a carbon fiber lip. It would cost me an arm and a leg to buy another pair for the rear. My car has been sitting for almost two months now so im just trying to see what all my options are to have them fit and look right.
Thanks
Camaro SOLD :(
Old 05-19-2011, 11:33 AM   #8
Elite1
Elite1's Avatar
Drives: BMW 335i
Send a message via Skype™ to Elite1
unforunate it sounds like you have a wheel issue
Elite1 is offline   Reply With Quote
Old 05-21-2011, 04:50 PM   #9
Tbanks
Tbanks's Avatar
any news on the thickness?
TBANKS
Old 05-22-2011, 11:12 PM   #10
Maro99
Maro99's Avatar
No nothing yet..
Camaro SOLD :(
Anyone swap v8 brembos for v6 brakes ? SATXLS3 Suspension / Brakes / Chassis 10 03-21-2011 01:06 PM
TRADE V8 SS BRAKES FOR V6 BRAKES jrpxxii Suspension / Chassis / Brakes 7 08-03-2010 10:50 PM
WTT Stock LT Brake SETUP for BREMBOS V8 Brakes! xpanda305x Suspension / Chassis / Brakes 1 07-09-2010 06:02 PM
Jay leno hints to the z28 in video!!! tru imperial blu Camaro ZL1 Forum - ZL1 Specific Topics 103 11-27-2009 10:56 AM
V6 vs V8 Brakes Doc Suspension / Brakes / Chassis 3 11-04-2009 10:54 PM
