Old 05-19-2011, 10:23 AM   #1
NVMYSS
NVMYSS's Avatar
Drives: 2010 Camaro SS
PFADT Rear Control Arm and Trailing Arm Alignment
After I install these on the car this weekend, do I need to bring it in to a alighnment shop to check the toe or any other alignment issues?
NVMYSS is offline   Reply With Quote
Old 05-19-2011, 10:30 AM   #2
Jaysin
Jaysin's Avatar
Drives: 2015 Chevrolet SS
Yes, you need to have the rear toe aligned since the alignment bolts had to be removed for the install.
Jaysin is offline   Reply With Quote
Old 05-19-2011, 12:50 PM   #3
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
It's a really good idea to have the alignment checked after installing these. The trailing arm does effect toe, and it's a lot cheaper to have the rear alignment checked than buy another set of tires if it's too far out of spec.
Old 05-19-2011, 01:21 PM   #4
NVMYSS
NVMYSS's Avatar
What are numbers for correct alignment? Or should they know?
Old 05-19-2011, 02:51 PM   #5
PfadtRacing
We recommend these alignment specs for different uses and modification levels. They are a little more precise than the factory specs, but once dialed in feel really good.
Camaro Alignment specs
Old 05-19-2011, 05:34 PM   #6
NVMYSS
NVMYSS's Avatar
what are the factory specs?
Old 05-20-2011, 12:16 PM   #7
PfadtRacing
Had to break out the ol' Factory Service Manual for this one...
Stock alignment settings for a V8 -
Front Camber: -.8, +/- .75
Rear Camber: -.4 +/- .75
Cross Camber: 0 +/- .75
Front Caster: 6.4 +/- .75
Rear Caster: 6.6 +/- .75
Cross Caster: 0 +/- .75
Total Toe: +0.2 Degrees +/- .2 Degrees
Thrust Angle: 0 degrees +/- .3 Degrees
Setting up an IRS/Drivetrain for Drag Racing Kyle2k Suspension / Brakes / Chassis 44 06-05-2010 10:17 PM
Suspension guys out there - lets talk wheel hop Crowley Suspension / Brakes / Chassis 14 10-09-2009 01:06 AM
