Suffers Fools Poorly
Drives: 2010 SS/RS, CGM w/ Silver Stripes. Join Date: May 2011
Mailslot fill-in.
I'm curious what others have paid to get rid of their mailslots?
2010 2SS/RS, CGM w/ silver stripes. Hurst Shifter, long tube headers, full exhaust, CAI, tune. SAE 407 RWHP/402 RWTQ
Momma didn't bronze my shoes, but when I turned 16 I inherited a lead foot. |
knows 2 facts about ducks
I believe RPI sells paint to match mail slot deletes
Fear the Red Bow Tie
Drives: 2010 Black Camaro 2SS/RS LS3 Join Date: Jun 2009
SLP makes em too.
Show & Go
Drives: '10 Camaro 1SS LS3 Join Date: Apr 2011
I wanna see a pic of the SLP installed...
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
I am planning on getting rid of my mail slot, I am looking for a donor facia so I can cut a piece out and weld it in, when I come up with it I will post some pics.
#6 |
Not talking about the fill in piece (because IMO that looks even worse). I mean having a body shop fill it in. Trying to estimate before I get an estimate...Market research...
It's urethane...
#7 |
Drives: SLIVERICE Join Date: May 2011
Why don't u guys like the mailslot really.
#8 |
It's TEO and can be plastic welded, I already welded in the holes from the front plate mount, piece of cake, everybody replaces the facia when they can be repaired via welding at a fraction of the cost.
#9 |
#10 |
For those interested, here are a couple of photo's, one of the plate mount holes made by the dealer, and one after the welding, obviously I'm not going to paint it untill I do the mail slot delete. After welding, prep and paint it will disapear like majic LOL.
#11 |
That's not bad! Good job.
#12 |
Seems now a days everyone replaces not repairs. You can plastic weld with a hot air welder, airless welder or even a soldering iron. The key is the material has to be completely clean and identified so the proper filler rod and heat range can be used. In the case of the Camaro's front and rear facia fiber flex rod seems to work very well, they are made of TEO, Teo and PP are two of the toughest plastics to weld but not at all hard. Welding in my plate holes took about 15 min after the facia was removed.Filling in the mail slot would require a donor piece, backed by wire mesh for additional strength then the welding, filler, prep and paint. After the welding you can use a flexible filler as you would spot putty for a flawless finish.
#13 |
Its all about the U
Drives: 2010 SGM Join Date: Mar 2010
bump ... any update ??
Supposebly this person filled it with plastic too...looks great any idea how much a shop might cost to do this ??
#14 |
Switchin' n Twitchin'
Drives: 2011 Camaro Join Date: Nov 2010
I have a v-6 fascia sitting at my father's place in Ohio... for the right person wanting to part it away into mail slot filling pieces. (that is if he doesn't want it, I think he was thinking about mounting it in his garage, but ionno.)
how often do you fill up and with what gas? | aban | 5th Gen Camaro SS LS LT General Discussions | 47 | 12-23-2011 01:25 PM |
fill stations for nitrous in DENVER CO ? | Nique303 | Forced Induction - V6 | 3 | 04-22-2011 10:02 PM |
Question about custom interiors and mailslot delete. | Blakout | 5th Gen Camaro SS LS LT General Discussions | 15 | 02-21-2010 07:31 PM |
gas fill problem | darty111 | 5th Gen Camaro SS LS LT General Discussions | 17 | 02-10-2010 11:40 AM |
