View Poll Results: Your Axles:
Stock, and holding up fine. 59 64.13%
Aftermarket: Replaced for peace of mind. 21 22.83%
Aftermarket: Replaced due to failure of stock components. 12 13.04%
Voters: 92. You may not vote on this poll
Old 05-20-2011, 09:28 AM   #1
EvoWake
SSTOCK
EvoWake's Avatar
Drives: 2010 Camaro 2SS/RS
Broken Axles: Hype or Reality
Okay...
I hear a lot of people saying axles axles axles... and I see many people swapping for peace of mind, BUT I'm having a hard time finding many cases of legitimate broken axles.
So here it is... broken Axle Poll.
Please detail your power level and what ya did to kill them if you did.
And I apologize if there is an existing thread like this, I tried searching around with not a whole lot of luck.
2010 Camaro 2SS/RS
EvoWake is offline   Reply With Quote
Old 05-20-2011, 09:46 AM   #2
Turbobitt
Drives: 2010 2SS
Definetly not a mith. Took mine to the track and experienced bad wheel hop. Shortly after they broke doing a burnout. Mine was all stock at the time but now upgraded to stiffer rear suspension components.
Also not a mith is the stock Posi being a POS. Noticed it stopped holding after the axle broke.
Allan G.
Turbobitt is offline   Reply With Quote
Old 05-20-2011, 10:26 AM   #3
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Uhm.... stock axles have no chance in my car... I changed them out before they broke and stranded me somewhere... There are numbers of them....broken and scattered around the country at various "race" tracks...
I'm praying my diff holds together until I can replace it... My tranny is out of the car right now being gone through... Carbon fiber synchros, steel forks etc... and with the Diff comes a one piece drive shaft....
Old 05-20-2011, 10:44 AM   #4
Camaro21
Drives: SOLD - 2013 M6 ZL1
I have 625rwhp and 595rwtq on Stock Drive Line and Drive the SH~T out of my car at the track and haven't broken anything YET !!
Camaro21 is offline   Reply With Quote
Old 05-20-2011, 11:01 AM   #5
EvoWake
SSTOCK
EvoWake's Avatar
That makes me feel a bit better. I'm at 612/580 and going to be hitting the track soon. So far the poll is showing exactly what I imagined... lets give it some time
2010 Camaro 2SS/RS
Old 05-20-2011, 11:21 AM   #6
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
Wheelhop seems to be the culprit, not strength of the axles. Fix the wheelhop and less worry about axles (until certain power levels). Also fix the alignment and you'll worry less about one-wheel burnouts and the posi-mod.
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 05-20-2011, 11:26 AM   #7
Coop
Drives: 2010 Camaro 1SS
Padre what is the alignment fix? Never heard about this.
2010 Camaro 1SS Inferno Orange Magnusson Supercharger Installed and Tuned by ADM Performance, Roto Fab CAI IOM painted, MBRP Cat Back Exhaust, Barton Industries Short Shifter, Clear Image Headers, Pedders coilovers, BMR Front/Rear sway bars Trailing Arms and End Links, VMax ported TB
Coop is offline   Reply With Quote
Old 05-20-2011, 11:53 AM   #8
Padre
Padre's Avatar
Just getting a good alignment, as JusticePete says, "The cheapest and most overlooked drag strip modification is rear wheel alignment. The less negative camber you have at rest, the better your rear tires will bite as your 5th Gen squat-ts."
Here's a good wheel-hop thread:
http://www.camaro5.com/forums/showthread.php?t=130950
Here's a thread that discusses a problem that misalignment causes mis-distribution of weight and one-wheel spin (also did the posi-mod, but mainly because of so much power):
http://www.camaro5.com/forums/showthread.php?p=3061186
Padre
Old 05-20-2011, 12:05 PM   #9
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Quite sure this is my weak link now at 610hp... however the Autos have a much smoother launch without wheel hop. I've seen plenty of stock M6 cars break axles.
My motto is why replace good parts, break em first, although that didn't work so well at C5Fest..
Padre is dead on...
Old 05-20-2011, 01:09 PM   #10
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
We have a bit of insight on this, We have been making performance axles for over 12 years and this is what we have to say. there are some people that can launch a car with the talent of a well seasoned team, being able to feel the car out and knowing the limit to each part and the ability to coordinate the clutch-gas-suspension and everything else that can make a car stay together. We had a Pro-FWD Honda driver from Canada that was using a set of 600Hp axles on a 900hp car running low 9 second passes. I saw him at PRI one year (this was some time ago) and i asked him how he managed to keep the car together. He said his clutch foot was like one of the finest tools in his tool box, he knew how to use it properly so it didn't damage anything else.
Then there are people that should remove there various pedals and put in switches in place of the Gas pedal-Clutch pedal and so on. In big league racing they use slipper clutches, the reason is if there were to put all the power they had to the ground they would have parts falling out from under the car. so launch technique is paramount in this discussion.
On top of this there is the quality of the part itself, the Stock Axles are made from a high carbon material and has allot of retained austinite (for lack of a better term its bad cholesterol for metal) its has chunks of material that never really get flowed out properly in the heat treat process and this inconsistent problem is what will cause a Factory shaft to either last or fail quickly. The higher grade materials like 4340 and 300m are a cleaner blend and do not have this problem.
so the reason some stock axles last and others done have a 2 part answer, it could be the driver is a bit harder on launching or its possible the material had been poorly heat treated with more retained austinite causing failure.
Take a look at this stock axle, this was in mercurymans car, he changed the axles as a safe guard. good thing he did. check out how far the spline was twisted. most will break the center bars before this will happen but its a good example of what I'm taking about with the material/Heat treat issue of the Stock parts.
Driveshaftshop is offline   Reply With Quote
Old 05-23-2011, 12:39 PM   #11
carguy
Carguy
Drives: 57Chevy,67,80,2@10's camaro's,04SSR
Not a Myth...Actually spun the axle in the CV Joint grabbing second gear.
Could have been done another time I guess.
Also broke out put shaft on tranny as well.Also grabbing a quick second gear.
I put stock CV's and axles back in under warranty. At least until I get a rear fix because something has to be the weak link and right now I would rather it be the axles and CV's than the whole rear.
I have been waiting for a 9 inch upgrade and am now saving that for the next upgrade before pushing any more HP through the stock driveline.
Just have to go easy on those second gear shifts I guess.
568 RWHP 540 rwtq
2010 SS/RS LS3, 21" Rims, SLP lowering Kit & sway bars, TVS2300, Hennesy CAI, Kooks LT Headrers & Cats, Corsa Exhaust, RIP Shift ST shifter, SLP Hood & Spoiler, Slp Black out package - Grill SS & Rear SS Emblems, ADM Dual Fuel Pump , 3.6 upper Pulley, 10% overdriven Innovators West Crank Pulley& Pin Kit.
carguy is offline   Reply With Quote
Old 05-23-2011, 01:02 PM   #12
Steve
Ancalagon The Black
Steve's Avatar
Drives: 2013 Silverado 4X4, 2010 RJT 1SS
568 RWHP 540 rwtq
I've done the same damage (half-axel and tranny output shaft) on a stock machine. The output shaft was last year during a launch attempt. The half-axel went this spring when I was power shifting into second. My VIN is 13279 so I figure it may have a little to do with being an early car. Maybe I am too hard on the clutch release?
Steve is offline   Reply With Quote
Old 05-23-2011, 05:37 PM   #13
Driveshaftshop
568 RWHP 540 rwtq
great point
Old 05-23-2011, 06:17 PM   #14
GFORCE1320
Drives: 05 GTO
This is a question we get allot, back when we started manufacturing GTO axles we had a bunch of the OEM axles and axle stubs analyzed for material composition and hardness.
What we found was they tend to use a mixture of materials that fall into the 1050 material range. Great for economical mass production and great for holding stock power but not great for putting any kind of power to.
We use aircraft grade 4340 and 300m material for our axles, it is a much more pure blend of steel and is made in a controlled vacuum process to keep out any impurities.
What we also found was most all of them were induction hardened. Induction hardening doesn’t penetrate nearly as deep as the through hardening process like we use and is very inconsistent.
On our Shop car (05 GTO) We had a set of stock axles that we were able to run high 9's on believe it or not but that with a carbon fiber driveshaft that absorbs a bunch of the drivetrain shock.
We also had stock axles that would break on 12 second passes, it was just luck of the draw.
GFORCE1320 is offline   Reply With Quote
Driveshaft Shop axles, The real reason they work so well.... Driveshaftshop V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 52 03-11-2014 02:01 PM
Best Deal on DSS Camaro 2010 - 2011 Axles & Powder Coated Paschal Performance Transmission / Driveline 2 07-15-2011 11:31 PM
Gforce Engineerings 4340 and 300m axles for the 5th Gen Camaro GFORCE1320 Transmission / Driveline 12 12-04-2010 09:53 PM
Best Deal on DSS Camaro 2010 - 2011 Axles Paschal Performance Transmission / Driveline 8 09-19-2010 12:23 AM
Hot Deal For DSS 2010 Camaro Axles Paschal Performance Transmission / Driveline 3 03-04-2010 09:36 PM
