Hail to Pitt
Drives: 2016 Charger R/T Scat Pack Join Date: May 2011
MRT V2 with Resonated X Pipe
Does anybody have the MRT V2 with a resonated x pipe installed? I'd like to hear a sound clip of this setup and I haven't been able to find anything.
I'm leaning towards the MRT V2, but it sounds like it might be a bid loud for my taste. I think the resonated x pipe might put it right where I want it to be, but I'd like to hear it. Also, if anyone near Pittsburgh has the MRT installed, I'd love to hear it in person. |
having FUN now 13.66@101
Check this thread for what you are looking for first.
http://www.camaro5.com/forums/showthread.php?t=33104
Hail to Pitt
Yeah I've looked through that thread, searched the site, search YouTube, and searched Google. I haven't been able to find this setup.
Only people that have used resonated x-pipes are the ones who wanted freer flow with the longtubes and reduce the rasp caused by a regular x-pipe at the same time.
If you think its too loud, I would look into flowmasters or magnaflow exhausts. Because I don't think adding a resonated x-pipe will make it less loud, it just changes the sound effect to a more muffled tone. But I don't think volume is going to go down.
Formerly owner of:
2012 2SS/RS Build Thread - Totaled by red light runner 2010 LT/RS Build Thread - Traded in for 2012 2SS 2007 Acura TSX 1992 Oldsmobile Achieva V6 1992 Mercury Sable |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Member BlackBee has this setup, but with Doug Thorley shorty headers. He may be able to get you some help, but with the headers his would sound slightly different than with out...a tad bit more aggresive but not much.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
#6 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
I dont know how much help I can be as I have the Injen long tube intake, D/T shortie headers and mrtv2 so the sound is louder. If you go on youtube or the exhaust sticky and listen to Scrming's vid of his car going up and down his street(the one with snow on the ground) with headers and mrtv2, my car sounds like that but mellowed down a bit at those low speeds/rpms with the res x pipe. The res x mellows a bit, deepens and smoothens the sound, not as high pitched anymore.But I will say that the mrtv2 is alot louder then the magnaflow mufflers I had with the same setup.I had to put the stock resonators back in due to the drone and loudness of the mrts.
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 2011 LS Join Date: Oct 2010
Actually I put my magnaflow exhaust on first and then added the resonated x-pipe in place of stock resonators. I almost removed it because it did quiet it down a bit and I thought it was too much, but when I listened to the take off the hint of rasp that was there before was gone. So I sucked it up because I knew I wanted headers which I am putting on in a week or two.
#8 | |
Maybe in the meantime I should just remove the stock resonators and keep them for later?
#9 |
Hail to Pitt
Thanks for all the help guys. Seems like I can't find that exact setup, but I've got a few ideas on where I want to go with this now. Thanks!
#10 | |
| OK...I'm starting a better V6 exhaust examples thread!! | KMPrenger | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 612 | 09-06-2024 09:00 AM |
| Magnaflow resonated X pipe !NEW! (#11386) | rocketman | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 4 | 10-04-2011 07:18 PM |
| when replacing H pipe with resonated x pipe should I remove mufflers? | CamaroC-17 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 2 | 02-21-2011 12:14 AM |
| Is this a resonated x pipe? | CamaroC-17 | 5th Gen Camaro SS LS LT General Discussions | 8 | 02-19-2011 04:56 PM |
| Magnaflow Delete, then Resonated X Pipe, then X Pipe (with video) | Bumble_Bee | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 22 | 08-05-2010 04:53 PM |
