Old 05-25-2011, 05:11 PM   #1
G.E.
G.E.'s Avatar
Drives: black on black twenty ten ss/rs
Loss of power/jerk somewhere between 45-55?
anytime i romp on it from a low speed and it hits about 50 I guess I'm switching a gear, however it pauses and then resumes acceleration. U have the torque pushin you back then you have a large gap and you actually get pushed forward and then it kicks back in. It doesn't do it on any other gear. I have a predator tune on my car, could that have anything to do with? if so what parameter do i need to adjust?
any comments are appreciated. thanks!
O and my car is an Automatic (L99).
I GOT MINE! Where's yours? :(
G.E. is offline   Reply With Quote
Old 05-25-2011, 05:51 PM   #2
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Drives: Black & Yellow 2SS/RS LPE LS7 427
I'd say your bouncing off the rev limiter when shifting from 2nd to 3rd. Your probably spinning the tires in 2nd and the revs get up there real fast.
LS7 427 is offline   Reply With Quote
Old 05-25-2011, 08:18 PM   #3
Ron66Vette&10SS
Plays with Hot Wheels
Ron66Vette&10SS's Avatar
Drives: '17 Jet Black ZL1
Is it with Traction Control on, off, or in "Comp Mode?
My first guess would be that it's probably your traction control kicking in when your car is making the 1-2 shift.
Previous Cars: '78 Z28, '92 Z28, '95 Z28, '85 Corvette, '01 SS, '96 Z28, '04 Z06 Corvette, '10 SS, '13 SS Hot Wheels
Current Cars: '17 ZL1(daily driver), '04 Trailblazer (rain & snow), '66 Corvette (restoring)
Ron66Vette&10SS is offline   Reply With Quote
Old 05-25-2011, 08:19 PM   #4
slickmetal
slickmetal's Avatar
Drives: 2013 Black ZL1 A6
Try turning off ALL traction control...hold down the TC button for about 7 seconds...then give it a go...with your tune and/or mods might be making the car think the wheels are going to spin more than usual so the TC pulls timing then gives it back...I hope this works for you.
- 2013 Black ZL1 - A6 - Lingenfelter/Cordes Stage 2.5 packages E85 - FORE Fuel System - Kooks LTHs - Magnaflow Cans - Rotofab CAI/Big Gulp/Coolant Tank - Savini 3pc Forged - Underhood Dress Up (ACC & Drake & Moroso) - Hurst Shifter Kit - Custom Audio w/ JL Audio Sub/Amp/Stealthbox - Hand Polished Brace - Oracle Ghost Sidemarkers - LEDs everywhere - 624/617 on E85 & 545/548 on 91 (Sept 2015) - 693rwhp (Dec 15)
slickmetal is offline   Reply With Quote
Old 05-25-2011, 08:20 PM   #5
slickmetal
slickmetal's Avatar
hehe great minds think alike in the same minute...
Old 05-25-2011, 08:45 PM   #6
Snake Slayer
Snake Slayer's Avatar
Drives: Awaiting 2014 C7
Sound like your tune is off a bit. Had a similiary issue and my shift point needed to be tweaked. Is this happening in D or M?
Awaiting 2014 C7
Snake Slayer is offline   Reply With Quote
Old 05-25-2011, 09:10 PM   #7
G.E.
G.E.'s Avatar
to answer the questions. it is in Drive. and everything is regular, traction control on and NOT in comp mode. and i don't think my wheels are slipping to be honest.
Old 05-25-2011, 09:21 PM   #8
Ron66Vette&10SS
......traction control on and NOT in comp mode. and i don't think my wheels are slipping to be honest.
Either turn everything off, like slickmetal suggested, or if you want to leave active handling on but have the Traction Control off, just momentarily push the TC button once. I think you'll be pleasantly surprised on the 1-2 shift
You got that right, even more so when I saw you're Air Force.
What's your AFSC? I was a KC-135 Crew Chief for 20 years.......retired in 2007. I was TDY at DM when I dropped off my last "A" model (56-3621) at the boneyard in '94 with barely 10,000 hours on it.....what a waste of a perfectly good Tanker....sad day :flag1:
Old 05-26-2011, 09:04 AM   #9
Snake Slayer
It sound like something is amiss in your tune. Are you working with a local tuner or did you do a mail order. Also are you using HP tuner, EFI Live or SCT?
Awaiting 2014 C7
Old 05-26-2011, 09:05 AM   #10
JANNETTYRACING
JANNETTYRACING's Avatar
What your Feeling is Transmission torque management, unfortunately there are no parameters to adjust with a Predator.
It is Best to return the car to stock and sell off your Predator and Purchase an SCT X3 from me then I can tune your Engine and Transmission to Perfection and give you the Performance you expect out of your L99.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Driveline Loss at High HP FASST 1 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 07-23-2010 12:15 PM
Drivetrain loss, What is the drivetrain loss? 2010ssraper Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 2 06-14-2010 11:59 AM
weight loss CamaroSpike23 Off-topic Discussions 8 09-17-2009 08:16 PM
Ford posts $2.3B profit for Q2, $424M operating loss MuscleCarz General Automotive + Other Cars Discussion 11 07-24-2009 08:57 PM
GM sees bright side despite $42b loss Mr. Wyndham General Automotive + Other Cars Discussion 2 11-08-2007 04:47 PM
