Old 05-29-2011, 09:41 PM   #1
Bay Area SS
Bay Area SS's Avatar
Drives: 2010 rs/2ss
Installing Hurst Billet short throw tomorrow
My Hurst shifter came in yesterday! Im going to install it tomorrow. Im not that great at workin on cars but I have my pops help thank god..LOL. ANy tips or suggestions on the install? Thanks
Bay Area SS is offline   Reply With Quote
Old 05-29-2011, 09:53 PM   #2
ssmike
BL1ZZRD
ssmike's Avatar
Great! I have the same thing! The only thing I can say on the install is make sure you are carefull not to drop the little c clamps on the pin underneath! If you drop them they will probably land on the heat sheild and it'll be tough to find. Other than that piece of cake! Good luck!
Old 05-29-2011, 09:57 PM   #3
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Give this a watch
Old 05-29-2011, 10:04 PM   #4
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
I just installed my Barton yesterday. A friend has a lift so that made it a ton easier than trying it on jack stands. It was 90 minutes from pulling onto the lift and pulling out of his driveway.
One of the c-clips did pop off and land on the heat shield. We just removed the front two nuts on the shield and pulled down and the c-clip fell out.
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 05-29-2011, 10:15 PM   #5
csjcsj
csjcsj's Avatar
Drives: 2010 Camaro SS/RS 6spd
I dont have the hurst, but I did find that removing the tunnel brace and the heat sheild gave you more room to mess around with it! And also make SURE you put the rubber boot on correctly, and make sure it is secure. Mine fell off and I had to get a new one because it ripped.
csjcsj is offline   Reply With Quote
Hurst short throw LSU/LS3 Transmission / Driveline 9 01-14-2011 02:53 PM
The New and Improved Hurst Shifter alfie43 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 29 08-11-2010 11:47 PM
Can the hurst short throw void warranty ? Ex-stang Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 04-07-2010 08:52 AM
Short Throw Hurst Shifter Not Available Matster 5th Gen Camaro SS LS LT General Discussions 51 11-09-2009 11:03 AM
hurst short throw chelsea1 5th Gen Camaro SS LS LT General Discussions 4 03-12-2009 10:23 PM
