Old 06-01-2011, 09:40 AM   #1
woodj
woodj's Avatar
Drives: 2SS/RS RJT Vert
Max A/C?
I had my wife thumb through the manual as I was driving but she couldn't find anything about the A/C. There is an A/C setting and then a Max A/C setting and I don't notice any difference between them. Normally the recirculate light would kick on when you go to Max A/C on most vehicles. Does anyone know what going to Max A/C is supposed to do in the Camaro?
K&N Typhoon CAI, Flowmaster Outlaw axle backs, Vertini 20" Wheels, Sparks Restorations SS Emblems, GM Wind Restrictor, Splash Guards
woodj is offline   Reply With Quote
Old 06-01-2011, 10:31 AM   #2
CamaroKid300
ace5.org
CamaroKid300's Avatar
Drives: 2017 ZL1 M6
From my experience if you turn the AC all the way cold and turn it up (push the little cold button on the left side of the knob) then it'll get cold...and then my MAX AC for me is the recirculate button. Its amazing how much colder it gets when that button is pushed.
Stock...For Now.
CamaroKid300 is offline   Reply With Quote
Old 06-01-2011, 10:36 AM   #3
Drew10
Enjoys a good train wreck
Drew10's Avatar
Drives: 2010 IBM Camaro 2SS/RS
The recirculate button is max ac. Recirculate closes off the door that draws the air in from the outside, thus you are re-using the already cool air which is much easier for the system to cool. Thats my understanding anyway.
Drew10 is offline   Reply With Quote
Old 06-01-2011, 10:40 AM   #4
woodj
woodj's Avatar
A lot of cars turn on that recirculate button when you go to Max A/C. The Camaro doesn't do that so I don't know what the point of having two different positions on the knob is.
Old 06-01-2011, 01:17 PM   #5
Ucantctchme
Ucantctchme's Avatar
Drives: 2010 ss. 1990 RS the faster one.
To the op I am a tech, the max ac words shouldn't be on the control. It doesn't make the record door close. This is the first car I've owned or worked on the is like this. If you don't push the record button it won't recirc. I bet they originally intended it to automatically go to recirculate when you go to max. Not sure why it doesn't.
Ucantctchme is offline   Reply With Quote
Old 06-01-2011, 01:38 PM   #6
1camaro70
1camaro70's Avatar
Drives: 2010 2SS RS L99
MAX A/C only works if the fan speed is above the II speed( between II and III etc., recirc. helps if very hot but not needed.
1camaro70 is offline   Reply With Quote
Old 06-04-2011, 02:38 PM   #7
Angelsilhouette
Angelsilhouette's Avatar
Drives: 2011 Camaro 2LT RS, Red Jewel
Related note: There is a recall (at least for Camaros made around mine) for the AC. They did the recall when they did my PDIM upgrade.
Still not quite done.
Angelsilhouette is offline   Reply With Quote
my dyno today(base for e85 tune) bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 51 06-08-2011 12:35 PM
Anyone else with A/C problems this summer? O2BQIK Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 13 08-01-2010 10:07 PM
A/C turned hot, and the engine temp rose Bonemaro 5th Gen Camaro SS LS LT General Discussions 17 07-20-2010 09:04 PM
Max A/C setting 1camaro70 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 06-25-2009 05:52 AM
