Old 06-02-2011, 04:16 PM   #1
C4m4r0
Man behind the wheel
C4m4r0's Avatar
Drives: 2011 Camaro 2SS/RS
Question Elite Engineering Oil Catch Can
What's up camaro5,
It's been a long while since I posted on here, but I have a question that I could use your expertise on.
I just bought an Oil Catch Can for my 2011 L99, and I wanted to know something about the install. I have read the instructions, and it seems very straightforward. I was just wondering if this should be installed during an oil change with all my oil drained out of the car, or if it can be installed just sitting in the garage. I'm just worried about pulling out one of the PVC lines, and having leakage from it. Is it cool to just start yanking those lines out?
When I ordered I requested the extra 3/8" tubing for the L99, any other tips reguarding the install would be helpful.
Best Regards
2011 Camaro 2SS/RS
Inferno Metallic Orange (w/ All Black Interior)
C4m4r0 is offline   Reply With Quote
Old 06-02-2011, 04:21 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Yes it's OK to just yank the lines out. Though you may want to use a flat head screwdriver to help you with the locking mechanism on the hoses.
Click to view my build thread
Old 06-02-2011, 04:29 PM   #3
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
You can install with oil filled.
ackeight is offline   Reply With Quote
Old 06-02-2011, 04:29 PM   #4
C4m4r0
C4m4r0's Avatar
Will do, thanks for the quick reply.
2011 Camaro 2SS/RS
Old 06-02-2011, 04:37 PM   #5
C4m4r0
C4m4r0's Avatar
I also just wanted to say for anyone reading this that is considering getting one that the Elite Engineering catch can is excellent. I can tell it's made with high quality materials, and it's also made in the USA. I chose the chrome version, with chrome fittings, and I'm very satisfied with the order. They are a bit on the expensive side, but once you receive it you'll be pleased with the solid craftsmanship.
2011 Camaro 2SS/RS
Old 06-02-2011, 09:35 PM   #6
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
I have the same set up.. love it...
MARINE1991 is offline   Reply With Quote
Old 06-02-2011, 09:52 PM   #7
Brister1
Brister1's Avatar
Drives: 2010 2SS/RS A6
Originally Posted by ssummit camaro View Post
i got the elite can and i cut my factory hard line coming from the back of the engine valve cover. i had alot of hissing noise using the supplied 3/8 hose which, might not bother you. i also ordered a extra replacement factory line for 17.00 just to have in case.
I had the same hissing noise with my Elite catch can. I did what what you did with the hard line and it cut the hissing down a lot.
Brister1 is offline   Reply With Quote
Old 06-03-2011, 01:52 PM   #8
Brister1
Brister1's Avatar
yes it was quite noticable and i traced it to long hose from the back of the valve cover to the can. once i replaced the hose with most of the hardline the noise was gone
I only used a small portion of hard line. I figured if I go back and use as much as I can, it will just about take care of the hissing sound. Can I ask where you got your extra piece of hard line from?
I think the Elite can is top notch and have no complaints at all, it's an AWESOME catch can that works VERY well.
Old 06-03-2011, 07:54 PM   #9
Brister1
Brister1's Avatar
Thanks for the part # and the pics!!!!!
Old 06-04-2011, 02:34 PM   #10
ADIO SS
ADIO SS's Avatar
Drives: 2010 White SS/RS L99
ditto.... wait to see the oil it catches - VERY happy with mine.
ADIO SS is offline   Reply With Quote
Old 06-04-2011, 10:38 PM   #11
kmcd
1,425 hp / supercharged
kmcd's Avatar
Drives: (2020 2SS/M6) (2025 GMC Yukon)
You might want to run some Sea Foam through your intake, depending on how many miles you've been driving it without the catch can. It'll clean out all that stuff that you're now stopping with the can.
kmcd is offline   Reply With Quote
Old 06-04-2011, 11:29 PM   #12
BUMBLEB
IN GOD WE THRUST
BUMBLEB's Avatar
Drives: 2010 RY 2SS RS M6 TVS2300 2015 Z06
Been their done that,Love Mine
BUMBLEB is offline   Reply With Quote
Old 06-05-2011, 01:23 AM   #13
C4m4r0
C4m4r0's Avatar
here are some pic of my install using the factory hardline
What are the clamps called that you used here?
2011 Camaro 2SS/RS
Old 06-06-2011, 04:33 PM   #14
flem
Drives: old
those type of clamps look factory
flem is offline   Reply With Quote
My V6 oil change experience convert Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 38 04-08-2014 05:15 PM
Elite Engineering Oil Catch Can SM0KE Camaro DIY & HOW-TO instructions & discussions 4 04-02-2011 08:34 PM
Oil Changes Dave McFly Off-topic Discussions 6 05-18-2010 05:50 PM
