How important IS A catchcan?
how important is a catch can with a whipple sc. i am putting down 600 rwhp. .. what is the best catch can and easiest to install..
thanks for all the help C5 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
Well oil ingestion can cause knock so you may be able to push a little more timing if you car is sucking in a lot of oil. It will definitely help with longevity. More importantly with FI is to a complete crankcase evacuation system. I went with the RX can for FI and breather and it works really well.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
![]() ![]() ![]() ![]() Drives: LS3S/C Join Date: Aug 2008
i would like a recommendation on good catch can made for a whipple set up, thanks
MODS whipple 2.9L s/c, ADM race scoop, 600 rwhp 550 wrtq, .
#5 | |
knows 2 facts about ducks
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2 LT/RS YELLOW, AUTO., VIN NO. 602 Join Date: May 2010
RX seems to be one of the best product.
#7 |
Supercharged LSX
Drives: 2011 2SS/RS Black/Carbon Fiber Join Date: Dec 2010
+1 here. I have one, but I noticed there is a different one for FI cars.
#8 |
The top mount SC's use the single valve system....the turbo or front mount SC's use the dual valve.
#9 |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
The catch can removes oily contamination from the PCV system before it would have otherwise gotten into the intake. You do not want to breathe a bunch of oil into your engine. The deposits can form on the back of the valves and it can cause knock if the contamination is bad enough. GM designed an emissions control system to contain and burn the contaminants that requires no maintenance but your engine will be burning the crap if you do not add a separator (catch can) to remove it before it gets burned. You can do better if you are willing to spend a little money to buy a separator and do a small amount of maintenance once in a while by emptying the can.
Forced induction may require a different catch can setup than a normally aspirated car. The FI engine will not have vaccum during boost so the basic catch can will not do its job under boost. Any crankcase pressure and vapors would back up in to the intake at that point without something to prevent it. You dont want to just add a check valve because the excess pressure (and engine oil) WILL come out somewhere and it could be your engine seals. Not good! If you arent that worried about the contamination during boost because it does not happen that often then the standard can setup will work for you. A little bit of crud will try to back up into the intake under boost but not that much. Certainly less would get burned than what you would get without any catch can at all. If you want to eliminate the crud under all operating conditions you may need a special catch can designed for boosted cars or 2 separate cans would work as well. The second can needs to be one without a check valve as it would pass air in one direction during non-boosted operation and act as a separator when under boost when the air is flowing in the opposite direction. -Mark. |
#10 |
Supercharged LSX
So my original catch can I had before my Whipple install is the one to use? It has one inlet and one outlet.
#11 |
![]() Drives: 2007 Trailblazer SS Join Date: Nov 2010
Bump 1 for Norris Motorsports catch cans! Great product!
#12 |
#13 |
Drives: 8 second C5 Drag Car, C6 Road racer Join Date: Sep 2009
There's a reason why we include one with all our supercharger kits!
![]() (along with a breather too!) Doug @ ECS |
#14 | |
100% Chevy & Harley Man
Drives: 2010 2SS: Blown LSX 376-B15 Join Date: Feb 2009
I've also read where many with catch cans never find anything in them, especially hard driven cars with many miles and multiple runs down the strip. Is this because of how well they may be built (engine)? I know it can be a little tricky installing catch cans properly, but I doubt these in particular were (Lingenfelter customers-who installed mine during my build). I've also seen where others do have contents in the can to empty. Any idea why some have nothing, and others do?
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
| Wheels & Stance = Most Important | Nine Ball | Wheels and Tires Talk Sponsored by The Tire Rack | 59 | 03-28-2011 10:58 PM |
| Dumb Question, but Why install a catchcan? | ctk1 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 11 | 01-07-2011 04:26 PM |
| Can we use the catchcan made for the G8? | HaZe_X | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 16 | 05-05-2010 11:35 AM |
| Slow News Day - Important Delivery Tip | Croathlete | 5th Gen Camaro SS LS LT General Discussions | 31 | 04-15-2009 04:28 PM |
