Old 01-07-2011, 03:51 PM   #1
ctk1
Camarofanatic
Drives: 1969 SS, 1998 RS, 2010 VR 2SS/RS
Dumb Question, but Why install a catchcan?
Sorry guys, I've noticed all of the catchcan topics lately. I must have missed something somewhere. Is there a known issue with these cars that has resulted in everyone installing catch cans? I did a quick search but there are way too many threads. I just want to be sure that I'm not missing anything important. Thanks guys.
2010 Victory Red R6P 2SS w/RS package. Gloss black Rallys, 6 speed manual, SLP Loudmouth I exhaust, LS7 style blackout panel, SS emblems front and rear, Custom 69 inspired headlight covers, Vararam no tune, Hurst Short Throw, and MTI Racing rear spoiler, SLP Front Splitter, ZL1 Side Skirts
ctk1 is offline   Reply With Quote
Old 01-07-2011, 03:53 PM   #2
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Catch cans are just a good way to keep recycled oil out of the intake...
PCV system routes oil vapor back into the engine's intake for emissions reasons.
The catch can collects that so it doesn't get into the intake, which overtime will reduce performance and gunk up the intake.
Old 01-07-2011, 03:56 PM   #3
MaRoFreK
MaRoFreK's Avatar
Drives: IOM 1SS w/factory Hurst
Originally Posted by MaRoFreK
Whats the function of a catch can? Might be a stupid question but i have no idea.
[SSMike]If you do a search you'll find quite a bit of information on catch cans. Basically it goes in line with the PCV system to condense out any oil vapor before it enters the intake manifold. The condensed oil fills the can and you can periodically drain it out. This improves performance under WOT conditions because no oil will mix into the combustion chambers. Therefore it reduces spark knock and keeps the internals cleaner! Hope this helps.
Hope this helps man i was asking the same thing.
MaRoFreK is offline   Reply With Quote
Old 01-07-2011, 03:56 PM   #4
ctk1
Camarofanatic
Thanks GTAHVIT! I appreciate it. I just saw all of the attention that they have been getting and wanted to make sure I wasn't missing and issue with these cars.
Old 01-07-2011, 03:56 PM   #5
Goliath
Goliath's Avatar
Drives: 2010 Camaro 1SS L99 A6
I wouldn't mess with it if I were you. If the design engineers didn't put the catch can into the engine, there must be a reason why. I haven't seen a single production car that has a catch can. Any Mechanical Engineer know why?
The Most Interesting Man in the World - On Muscle Cars
"I don't always drive muscle car, but when I do, I prefer the Camaro. "
Goliath is offline   Reply With Quote
Old 01-07-2011, 04:00 PM   #6
GTAHVIT
Blessed
GTAHVIT's Avatar
My understanding is the reason they don't use catch cans is the emisions laws requie the vapor to be recycled back into the engine.
Unfortuantely it will cause the intake to be coated with oil. eventually it will hurt performance.
Old 01-07-2011, 04:07 PM   #7
McBeevee
220/221 whatever it takes
McBeevee's Avatar
Drives: See sig....
The OP should do a search and read why a catch can should be installed. There are several threads on here to explain their benefit. Some cars will collect more than others, but it's a worthwhile mod for sure.
Brent
2022 BMW X5 M50i
2022 Ram TRX
2021 GT500 CFHP
2016 Challenger Hellcat A8 1058whp/898wtq
1970 Chevelle SS396 4spd
McBeevee is offline   Reply With Quote
Old 01-07-2011, 04:14 PM   #8
Goliath
Goliath's Avatar
I still don't understand why burnning vapor oil would be good for emissions? A catch can that catch vapor oil without burning it would make more sense of promoting good emissions. Is burning vapor oil not creating any kind of smog or ordor or I'm over analyzing?
Old 01-07-2011, 04:19 PM   #9
ctk1
Camarofanatic
Yeah, It seems that would accomplish the exact opposite of what emmissions regulations are trying for.
Old 01-07-2011, 04:21 PM   #10
GTAHVIT
Blessed
GTAHVIT's Avatar
I think the idea is the majority of it gets burned off the second time through instead of being sent out the exhaust..
But at this point you'd need one of the experts to chime in here.
That is about as much as I know.
Old 01-07-2011, 04:22 PM   #11
Goliath
Goliath's Avatar
Found the link for you. Long readings and I hope you understand a lot of technical write up.
http://www.camaro5.com/forums/showth...efit+oil+catch
I believe the writter is also selling catch cans. Use your judgement, it's your money my friend.
Old 01-07-2011, 04:26 PM   #12
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Beyond performance reduction. Oil vapors can cause the computer to adjust timing due to stoich and could lead to detonation. Believe us that have proper working cans when we say you do not want this stuff mixed in with your fuel charge.. You only want fuel! Not as big of deal on non SC cars because much less blow by but still a very very good idea.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
K&N (or any) CAI install question ... Bowtie Junkman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 08-11-2013 08:51 PM
Dumb Cruise Control Question USAFJeeper 5th Gen Camaro SS LS LT General Discussions 18 03-25-2010 03:02 PM
probably a dumb question shad2009 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 6 10-04-2009 12:29 PM
Dumb License Plate Question MightyT USA - California 6 09-27-2009 09:24 PM
dumb question time: 2LT door/dash bits in a 1LT? Dave McFly Cosmetics and Lighting Modification Discussions 8 08-19-2009 07:12 AM
