Old 06-08-2011, 10:21 PM   #1
gtfitter597
gtfitter597's Avatar
Drives: 2010 2SS/RS
Timing bushings
Does anyone have a write up? BMR says this will cure my front ride height issues w/ the 1.4" springs. I searched on here long enough. thanks.
gtfitter597 is offline   Reply With Quote
Old 06-08-2011, 10:43 PM   #2
Rob@WretchedMS
Drives: His Wife Crazy
Step 1. Pull the car up on to a drive uplift.
Step 2. Loosen the following bolts/nuts:
Front:
---Inner Control Arm Bushing
---Inner Radius Rod
Rear:
---Trailing Arm Bushings (both ends)
---Toe Rod Bushings (both ends)
---Lower Control Arm Bushings (Inner)
---Upper Control Arm Bushings (Rearward)
---Lower Strut Bushings
Step 3.
Grab the subframes or sway bars, and jounce the car up and down a few times.
Step 4.
Tighten all of the nuts/bolts to spec.
Step 5.
Align the car at the new ride height.
Rob@WretchedMS is offline   Reply With Quote
Old 06-08-2011, 10:52 PM   #3
gtfitter597
Drives: 2010 2SS/RS
Any pics of these would be greatly appreciated! BMR said theres a write up somewhere on here but just cant find it. Im assuming it would have pics. I have asked two alignment shops if they time bushing and they looked at me like I was from mars...
Old 06-08-2011, 11:00 PM   #4
Rob@WretchedMS
give me a bit, i'll see what i can make for you.
Old 06-08-2011, 11:35 PM   #5
caverman
caverman's Avatar
Drives: '69 SS Convertible
Definatley needed. Although I've already had my bushings timed we need a good thread to point people to.
Build Journal
Old 06-08-2011, 11:52 PM   #6
Rob@WretchedMS
Old 06-09-2011, 12:38 AM   #7
infernostripes!
Drives: 2010 1ssrs
Awesome thanks!!!
infernostripes! is offline   Reply With Quote
Old 06-09-2011, 12:46 AM   #8
JusticePete
Drives: Camaro Justice
Rob is d'Man!!!!
Old 06-09-2011, 12:53 AM   #9
Inuyashas_Brother
Inuyashas_Brother's Avatar
Drives: '10 Camaro LS - M6
Very useful, thank you! Can you please include the torque specs for the bolts/nuts when re-tightening?
Inuyashas_Brother is offline   Reply With Quote
Old 06-09-2011, 01:04 AM   #10
JusticePete
These bolts all need to be tight. They are all 'hardened'. The ferules the bolts pass through are robust. The German torque standard should be used. Gudentight. Getting a torque wrench into some of the spots while aligning the car just doesn't happen. The tech is using a wrench on each end of the fastner and watching the computer reading while tightening. Crank them down until you feel the metal bed and give it another grunt or two. If you think they are tight enough, grunt again and you are good to go.
Old 06-09-2011, 10:48 AM   #11
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
wow man you are simply awesome. im going to bring this to the allignment shop and hand them all these print outs
CAMARO
Old 06-10-2011, 06:10 PM   #12
JusticePete
We'll thank you for the compliment. I like to think I am awesome and love to have it confirmed. Oh, you probably meant the illustrations that Rob posted. Rob is OK, but I wouldn't go with awesome.
Old 06-10-2011, 06:55 PM   #13
mhog
mhog's Avatar
Drives: 2010 V6 Camaro 2LT/RS
In order to be the man hell have to beat the man!!
Is this something that has to be done after lowering or if you have problems?
mhog is offline   Reply With Quote
Old 06-10-2011, 09:17 PM   #14
Rob@WretchedMS
your still ugly
this has to be done on every car that is lowered, to do it right.
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 07:53 PM
Put More Power To The Pavement With Pfadt Engine Mounts And Differential Bushings!!!! Apex Motorsports Transmission / Driveline 28 11-27-2010 11:46 AM
Pfadt Street/Race Rear Differential Bushings, get more power to the pavement! Apex Motorsports Transmission / Driveline 5 08-10-2010 06:49 PM
Reinforce Your Oe Fr. Radius Rod Bushings Yourself Info@PeddersUSA.com Suspension / Brakes / Chassis 8 05-20-2010 12:52 AM
Urethane Bushings from Energy Suspension Bewenched Suspension / Chassis / Brakes 1 04-30-2010 06:12 AM
