Drives: 5th Gen Rental Join Date: Aug 2007
Reinforce Your Oe Fr. Radius Rod Bushings Yourself
Reinforce Your Oe Fr. Radius Rod Bushings Yourself !PEDDERS SNUBBERS REINFORCE THE OE RADIUS RODS Not everyone needs the full benefit of what our Pedders critical bushings have to offer. But all can benefit significantly, especially the DIYers, from some very simple, yet very effective upgrades. The front OE radius rod bushings are fluid filled and work just fine for normal driving. But for the highly spirited driver, you may want to add a lot of control and support to them. The best way is to add our Pedders complete bushing. But some may not want to replace the OE bushings and would appreciate an alternative that will help support and strengthen these very important bushings. PEDDERS TO THE RESCUE!. The Aussies call them SNUBBERS. In the states we can call them bumpers or inserts. What is the importance of the radius rod bushings? Literally, all the braking energy of the front goes thru these bushings and also they support and control the fore/aft movement of the front wheels and tires. When you consider a 60mph aggressive stop, and all the weight of the front, and the serious dynamic mass of the 50-60lb wheel and tire, these bushings are seriously important to control this movement. So adding strength to the radius rod bushing, to help with the control of the braking, and keeping the geometry of the front end tighter, is important and very benificial. We can increase the strength of the front radius rod bushings by replacing the OE Snubbers, or inserts with our Pedders Poly units P/N EP6578 HERE IS A PICTURE OF THE OE AND THE PEDDERS REPLACEMENT ![]() Upgrading the Radius rod inserts is one of the simplest suspension upgrades you can do. Requires only hand tools. You do not even have to take the wheels off. Here is the quick version to updating the Snubbers: 1. Put the front end on Jack stands 2. Remove the front radius rod nuts and bolts 3. Push the wheel and tire rearward and the radius rod will come out of them mount. HERE IS A PICTURE OF THE RADIUS ROD OUT OF THE RECIEVER ![]() 4. With a flat blade screw driver, pry off the 2 inserts or snubbers per bushing ![]() 5. The inserts are timed. you can see there is an alignment tab. Push in firmly the Pedders EP6578 inserts until they are totally seated. DO NOT USE ANY LUBRICANT ![]() 6. Here is a shot of both the inserts installed ![]() 7. Reinstall the bushing assembly back into the reciever. Then add the bolt, and torque the nut 8. Here is a picture of the assembly reinstalled ![]() Very soon, I will have a very detailed DIYer manual to install them. If you have any questions, just ask. thanks mike dms Last edited by Info@PeddersUSA.com; 05-19-2010 at 11:27 AM. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 1LT/RS M6 Join Date: Nov 2007
Nice write-up... looks pretty simple.
Trifecta tune, Vararam Intake, VMAX throttle body and manifold insulator, RxPerformance Catch Can, , MRT v1.0 and Louvers, Barton shifter, BMR strut tower brace, RED dome light and Plasma LED DRL's, fieldgoal00's Halo 1 harness, hood spears/side stripes, rain guards, custom bowtie, Team LLT badges, headlight and foglight covers, taillight and side marker covers, backup light covers, WeatherTech floormats
wow.. another amazing thread from pedders
![]() Drives: 2013 1SS LS3 Join Date: Mar 2010
I think that part number should be EP 6578:
https://secure.merlinsoftware.com.au...rodCode=EP6578 Cheers!
Dual Mode Exhaust | 6 Speed Manual | CAI Intake| BMR 1" Springs| Factory Reproductions 9" wheels
#5 | |
Fied my slip of the finger!. lol mike dms |
#6 |
![]() ![]() Drives: 73' VW Bug Join Date: Sep 2008
When will they be available?
#7 |
#8 |
![]() Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28 Join Date: May 2009
Does this modification generate vibration back into the steering wheel?
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected - Sold 1968 Camaro - Sold 2019 Corvette Grand Sport ![]() |
#9 |
| FRONT RADIUS ROD BUSH UPGRADE FROM EASY DIYer TO FULL RACE SETUP | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 4 | 08-25-2013 11:12 PM |
| Front radius rod bushing removal tips? | sting808 | Suspension / Brakes / Chassis | 3 | 05-12-2010 02:32 AM |
| Urethane Bushings from Energy Suspension | Bewenched | Suspension / Chassis / Brakes | 1 | 04-30-2010 06:12 AM |
| New to Suspension (look over list please) | Brokenlizrd | Suspension / Brakes / Chassis | 19 | 04-24-2010 12:31 AM |
| Drag Racing Suspension Kits | Info@PeddersUSA.com | Suspension / Chassis / Brakes | 25 | 02-21-2010 09:48 PM |
