![]() Drives: 2011 Camaro Blk/Blk. Base Model. Join Date: Nov 2010
Hi guys,
I have a LS V6 Camaro...and I can't for the life of me fill up the car with gas without holding the pump while it fuels up. If I let go of the pump to let it fuel itself until its filled, it just immediately stops fueling. It makes the sound like I am done. So i have tried 2093208 different ways to reposition the nozzle into the car, but I have to hold the nozzle down, but holding the handle up on an angle or it just stops fueling. This is extremely annoying because I want to just be able to plugin the nozzle, walk away and hear it click when it's done fueling. Anyone have this issue? I can't find it anywhere. Thanks! |
Yup your not alone, I have this happen occasionally. It just certain nozzles, I find most are fine but some you have to hold in. I found my stations with the good ones and try to use those when I can. Otherwise it’s not that bad to hold it till it’s finished.
Common safety feature for black Camaros. This forces you to monitor the fuel flow so that it won't be adversely effected by the excess energy absorbed by the black paint. Happens to me to.
2SS/RS, Black/Gray, 6M and GFX
2G1FT1EW3A9119245 Delivered: 07/07/09 |
I can't find any that work. I've tried like 5 different gas stations. This has got to be a factory issue. No cars should have this issue.
#5 | |
Paul
Sent from my iPhone 4 using Tapatalk!
#6 |
Don't Like it? Suggit.
I have this prob at certain pumps too. The 02 does this every. single. time....
"Tops off, tach up baby- loud and proud!" A Camaro lover from day one- 1996 3.8 V6 Camaro, to 1996 5.7 LT1 Camaro Z28, to the sold 2002 5.7 LS1 Camaro SS, and NOW, a [I]6.2 L99 VR 2SS/RS: XS Power stainless full exhaust, Airaid CAI, BMR drop springs and sways, custom tune by Cal Speed- 411rwhp |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 92 Camaro Convt RS,2011 Camaro RS Join Date: Mar 2009
I get this problem also but I really think it's not the car but more the nozzle.
![]() TEAM LLT 1992 Camaro Rs Convertible ![]() 2011 Camaro 1lt Rs ![]() |
#8 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
maybe GM doesn't want people walking away from a highly explosive liquid while they feel the need to go purchase a big gulp. When dealing with explosive fuels, people MAY need to pay attention to what they are doing so it's not going all over the ground, or someone forgetting about the nozzle in their tank as they pull away from the pump. Just a thought.
#9 | |
xbox360 tag
Drives: 2010 inferno orange 2SS Join Date: Apr 2010
i have this problem on my avalanche and i pull the handle out just a bit to let the gas escape easier. it seems to work for me (90% of the time)
#10 |
The Milano
Drives: 2017 Firefly ShipWorks Join Date: Jun 2010
You Are gonna kick yourself after reading this I know I did.... All modern pump nozels contain a latch and hook. If you push the nozzle a bit harder and down slightly it will latch onto a lip on the inside of th file filler neck and stay in place.
I do it at every fuel up and it works fine. When full push in a bit and loft slighty before removing. The real question - why didn't someone tell us sooner. :-)
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter. |
#11 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
To the OP, it's not an issue with your Camaro. I've had this issue with several of my other vehicles including my Camaro. Also noticed when it's happened to me, it's more prevalent when it's very hot outside. I used to pull the nozzle out just a little bit to help the vapors escape a little easier, but it was hit or miss depending on the pump. Now I hook the latch for slower pumping, get my gas in the morning when it's cooler and haven't had any issues.
#12 |
Okay guys I'll try the methods you mentioned! Hopefully I can get that to work!! Thanks for the help!
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: GM Vehicles Join Date: Jun 2010
I hope these suggestion help you.
Jeff Morris, Chevrolet Customer Service |
| Tags |
| annoying, fuel, gas, issue |
| ** Fore Precision Dual & Triple Billet fuel pump assembly ** | IPS Brandon | Forced Induction | 7 | 03-21-2011 01:29 PM |
| How many people will E-85 their new camaro? | Speed74SS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 57 | 01-03-2011 03:16 PM |
| Nitrous System ?????s | PoleCat2SSRS2010 | Forced Induction - V8 | 29 | 12-08-2010 06:55 PM |
| Momentum Autosports: Nitrous Plate and Stand Alone fuel system done RIGHT. | JordonMusser | Forced Induction - V8 | 3 | 11-23-2010 07:11 PM |
